Dave,
It's sporatic, but it may be 10 or more seconds -- and while it's 'lagging' you may not be able to click on anything else on the computer either. And as I mentioned, this may happen at other places such as accessing Windows Explorer or clicking the Start button. And ALL the XP Pro users have complained about it (there are 5 in the company at the moment). These computers are plugged into the exact same network connect that their previous Win9x machines were on and they experienced no such lags. So I don't believe it is the network, but rather the operating system in conjunction with the Server (ie. permissions or something?).
Troy Funte
Liberty Electronics
Troy Funte
Liberty Electronics
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Tuesday, July 16, 2002 12:57 PM
Subject: RE: [Vantage] XP Pro very slow !
Troy,
How much lag time are you talking about? On my XP Pro workstation, 1.3 GHz
with 256mb memory, it take less than half a second to open a share on a
server with 31,438 cad files in 1,252 folders. On a XP Pro workstation
(used for data collection), 350 MHz AMD K6-2 with 128mb memory, it takes
less that 1 second to open the same share. This is on a 100mb switched
Ethernet LAN with fiber between the switches.
Dave Cole
Reeder & Kline
Sent: Tuesday, July 16, 2002 12:23 PM
Subject: Re: [Vantage] XP Pro very slow !
Dave,
XP Pro machines are the first and only machines that have the 'lag times'
relating to opening up network folders (at times). There are also lag times
related to simply clicking the START button, or opening Explorer as well.
All other machines (mostly Win95 and Win98 - which all log onto the LIBERTY
domain) have great access to the network.
Does that answer your question?
Troy
Sent: Tuesday, July 16, 2002 7:02 AM
Troy,
I have never worked with one domain name for the internet and a second
internal domain name. But, lets see what we can do.
First, two questions.
Are you having any network response problems when trying to get a
directory
from a server?
If so, are all of your machines slow or can you group them as fast or slow
by the way they are registered in DNS.
Dave Cole
Reeder & Kline
Sent: Tuesday, July 16, 2002 12:03 PM
Dave,
I'm trying to understand our situation in light of what you wrote
below.
We have a domain on the Win200Server called LIBERTY. Our Internet domain
is
libertyelectronics.com.
Our WinXP workstations run slowly as described in previous emails. At the
server: most workstations are listed in DHCP/Scope as
jdoe.libertyelectronics.com. However, the XP Pro workstations are listed
as
jdoe.liberty.libertyelectronics.com. At the workstation, there is nothing
listed under "DNS suffix for this connection". Also, "Register this
connection's addresses in DNS" is checked, but "Use this connection's DNS
suffix in DNS registration" is not checked.
How does this situation fit with what you are describing?
Troy Funte
Liberty Electronics
Sent: Tuesday, July 16, 2002 6:21 AM
My understanding is that if you are running DHCP on a Windows 2000
server
and NOT running Active Directory, the workstations do not resister
themselves properly with DHCP. You need to make some changes to the
workstations for this to happen. This is assuming you are set up as a
domain.
If you go to your DHCP server and open DHCP, look at "Address Leases"
under
"Scope". Check out your workstation names and see how they are listed.
If
the name is just the name of the workstation like "data1.", then they
are
not correct. It should be "data1.'your domain name'.com" or net or
whatever. Mine would be "cole.reederkline.com"
In order to correct this problem, go to each workstation and log in as
administrator or whatever account you have that has privileges. Open up
the
Local Area Connection and pick Properties. Under Properties pick
Internet
Protocol (TCP/IP) Properties, then pick Advanced. Under Advanced TCP/IP
Settings pick the DNS tab. In the box for 'DNS suffix for this
connection"
you should put 'your domain name.com' or net or whatever yours is. Mine
is
"reederkline.com". Make sure the boxes for "Register this connection's
addresses in DNS" and "Use this connection's DNS suffix in DNS
registration"
are both checked. It is then best at this point to reboot the
workstations
although with 2000 and XP you really don't have to.
You can make the workstation re-register with DNS immediately by opening
a
Command Prompt and typing: ipconfig/registerdns
Then, go back to your DHCP server and see if the registration is
correct.
This should really help your network lookups. If you still are having
problems, there are some things to look at on your DHCP server. Let me
know
how it goes.
By the way, on NT4.0 you would just put your domain name in the
'"Domain:"
box and you must reboot NT4.0.
Hope this helps,
Dave Cole
Reeder & Kline
Sent: Tuesday, July 16, 2002 7:34 AM
I do have DHCP and DNS setup on a Windows 2000 member server with an NT4
SBS as the primary domain controller. Can you give us some insight as to
what exactly needs to be different in our setup ?
Raymond Quesnel
Systèmes Norbec
Soutien technique, T.I.
Tel: (450) 449-1499
Fax: (450) 641-4657
mailto:rquesnel@...
Sent: Monday, July 15, 2002 4:57 PM
By any chance are you running DHCP and/or DNS on a Windows 2000 Server
that is part of a domain controlled by Windows NT 4.0 Primary server?
If so, I think you have to set DHCP up just a little differently on the
work stations so that they register properly.
Dave Cole
Reeder & Kline
Sent: Monday, July 15, 2002 3:39 PM
I've been doing a lot of searching on the net and the major cause I can
determine is if you have a XP pro joining a domain and the domain
controller (most information is referring to a 2000 server) is not
configured or incorrectly configured for DNS. It is apparently vital to
the network performance with XP. I will be testing the articles I have
found and will leave feedback Wednesday.
Jim Carnes
IS Administrator
Kenlee Precision Corp
jcarnes@...
1700 Morrell Park Ave
Baltimore, MD 21230
Sent: Monday, July 15, 2002 2:40 PM
Subject: [Vantage] XP Pro very slow !
Hi all,
Just wanted to add my two cents worth on XP Pro. We have recently added
a labtop with XP Pro and have experienced the same performance lag as
some of you mentionned. The machine is a Dell latitude with a 1.6 ghz
pentium processor with 256mb of ram. The machine runs a lot slower than
most of my win 2000 pc's. It is very slow to open up network folders
and seems to stall randomly for no reason when you are clicking from
menu to menu in Explorer or any office applications that are opened !
The antivirus I am running is Norton Corporate 7.6. The machine is very
quick to boot though, almost twice as fast as win 2000. So far I haven't
been too impressed by XP pro.
Raymond Quesnel
Systèmes Norbec
Tel: (450) 449-1499
Fax: (450) 641-4657
mailto:rquesnel@...
Yahoo! Groups Sponsor
Click here to find your contact lenses!
<http://rd.yahoo.com/M=225674.2075964.3644785.1829184/D=egroupweb/S=1705
<http://rd.yahoo.com/M=225674.2075964.3644785.1829184/D=egroupweb/S=1705>
<http://rd.yahoo.com/M=225674.2075964.3644785.1829184/D=egroupweb/S=1705> >
0071
0071
83:HM/A=1153174/R=7/*http://www.lensexpress.com
<http://www.lensexpress.com>
<http://www.lensexpress.com <http://www.lensexpress.com> >
<http://www.lensexpress.com <http://www.lensexpress.com> > >
<http://www.lensexpress.com <http://www.lensexpress.com> > > >
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/files/.> > >
<http://groups.yahoo.com/group/vantage/files/.> > > >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/messages> > >
<http://groups.yahoo.com/group/vantage/messages> > > >
<http://groups.yahoo.com/group/vantage/links> >
<http://groups.yahoo.com/group/vantage/links> > >
<http://groups.yahoo.com/group/vantage/links> > > >
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/>
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > >
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > > >
ADVERTISEMENT
<http://rd.yahoo.com/M=228862.2128520.3581629.1829184/D=egroupweb/S=1705
<http://rd.yahoo.com/M=228862.2128520.3581629.1829184/D=egroupweb/S=1705>
<http://rd.yahoo.com/M=228862.2128520.3581629.1829184/D=egroupweb/S=1705> >
0071
83:HM/A=1155068/R=0/*http://adfarm.mediaplex.com/ad/ck/990-1736-1039-302
<http://adfarm.mediaplex.com/ad/ck/990-1736-1039-302>
<http://adfarm.mediaplex.com/ad/ck/990-1736-1039-302> >
<http://adfarm.mediaplex.com/ad/ck/990-1736-1039-302> > >
ADVERTISEMENT
<http://rd.yahoo.com/M=228862.2128520.3581629.1829184/D=egroupweb/S=17050071
83:HM/A=1155066/R=0/*http://adfarm.mediaplex.com/ad/ck/990-1736-1039-302
have
and
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > > .
ADVERTISEMENT
and
<http://rd.yahoo.com/M=225674.2075964.3644785.1829184/D=egroupweb/S=17050071
83:HM/A=1153156/R=0/*http://www.lensexpress.com/tracker/trackclick.aspx?Page
<http://www.lensexpress.com/tracker/trackclick.aspx?Page>
=ACUVUE%202%20Colors&AffUrl=273&AffCode=14> Click here to visit our
exclusive feature of ACUVUE2 Colours at LensExpress.com!
have
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
83:HM/A=1155069/R=0/*http://adfarm.mediaplex.com/ad/ck/990-1736-1039-302>
ADVERTISEMENT
