XP Workstation & Progress Report
Isn't it always the time you publicly ask for help, that you end up solving
the problem yourself?
I went into Display properties, Settings tab, pressed the Advanced key,
dropped down the fonts list and selected "Other...". I reduced the font
size to only 90% of the Normal font size.
Signed on to Vantage and it did not display all those nasty error messages!
Viola!
Thanks for your help, Ted and Steve!
Steven
I am having a situation where our new XP-Business workstation users are
running Progress Reports, such as "Scheduled Shipments" under "Order
Management". Report Builder reports and Crystal Reports have no trouble at
all.
When she does a print preview of any Progress Reports, a series of about
five errors pop up, with only an "OK" button response. The error basically
says "**All or part of BUTTON CLOSE-BTN is being placed outside of
DIALOG-BOX DIALOG-1 by setting ROW. (5905)".
Once you have pressed "OK" on all of the messages, the report appears, fine
and dandy.
Her screen resolution is at 1024 X 768. When I put it at 800 X 600, she
signs off and then back on, and the errors do not appear. Of course it
would drive her insane to have her resolution at 800 X 600 all the time.
I found an article on Eranet regarding a W98 station (340.639MPS: PM error
5905 for One Windows98 workstation) but it did not provide any insight.
Does anyone know how to resolve this issue, allowing her to keep her 1024 X
768 resolution?
Will upgrading to the new 5.1 system help? Will upgrading only the Progress
software help?
Thanks for any advice!
Steven
C & S Machine Products, Inc.
Steven,
We have run into this problem before and found a fix that works about 90% of
the time.
1. Log out of Vantage on the affected workstation.
2. Clear the entire contents of C:\VntgWork.
3. Reinstall the Vantage client and Progress client on the workstation
(over the top of the existing installation).
Hope this works for you.
Steve Sanders
Delta Centrifugal Corp
From: Steven Collings Russell [mailto:srussell@...]
Sent: Thursday, December 27, 2001 10:30 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] XP Workstation & Progress Report
at
all.
basically
fine
and dandy.
X
768 resolution?
Progress
software help?
Steven
Yahoo! Groups Sponsor
One other thing to look at is the size of her fonts. Many of the progress
routines use a fixed size font and the larger fonts will cuase errors. The
larger fonts cause things to run off the side of the widget.
The only solution to this problem is to make sure that the user is using
small fonts or live with the error messages.
HTH,
Ted Kitch
ted@...
Sent: 12/27/2001 10:30 AM
at
all.
basically
fine
and dandy.
error
1024 X
768 resolution?
Progress
software help?
Steven
<http://rd.yahoo.com/M=214563.1778827.3296761.1261774/D=egroupweb/S=1705
007183:HM/A=867009/R=0/*http://www.crystalvoicelive.com/whatFamily.asp?A
ffiliateId=00120002>
<http://us.adserver.yahoo.com/l?M=214563.1778827.3296761.1261774/D=egrou
pmail/S=1705007183:HM/A=867009/rand=368598372>
