11.2 REST API Pagination?
Is there no pagination functions in 11.2. skip and top do not page past first limits( default 100) of rows. I have used paginations in other API rest services but at a lost with EPICOR functions.
I would assume you’d need to implement your own pagination in a function by adding parameters similar to skip and top.
Can you share some details about your function?
Pagination does generally work depending on the BO what BO are you using.
Also version 2 of the API or V1?
Please don’t ban me :rofl:
forgive me monica GIF
We’ll I did see that but it wouldn’t make sense to pagínate on your own function. I took that as I’m lost in Epicor related things :pleading_face:
You can’t pagínate on your own function unless you yourself so it
The BO is V2 “/{currentCompany}/Erp.BO.PartSvc/Parts(‘{Company}’,‘{PartNum}’)”. After a deeper review I have found Epicor’s implementation is different from other versions when it comes to pagination. Other APIs allows me to limit and page through filtered data. Going forward I will use dynamically defined SQL queries to extract data, convert to JSON and use Epicor APIs to transactionally process the data.
Thanks to everybody who replied.
You do you, but I would use the API.
Have you considered using the DynamicQuery service and use a BAQ?
I would prefer an all API approach but Epicor’s pagination is a stumbling block. When extracting 3 to 4 thousand rows of data without pagination is a long process when compared with(Infor ION API) or using SQL queries( example 750ms for a SQL query to extract 6400 rows from Parts/W UDs limiting columns of course).
Curious, what are you doing?
Can you do any of that processing you need to do on the Epicor side?
Bi-directional inventory, pricing, customer info updates between dissimilar systems using pure APIs with non-Epicor dynamic queries(SQL), BTW using Python and Windows Server Task Scheduler.
You can do this Pagination fairly easily (with filters) with BAQ
For example there is a standard query zCustomer01 we all have (Built in) returns customer master
You can ask on the API to return Top 100, Skip 100, $filter and it all behaves as it should
Like this First 100 Customers whose name contains A
https://Domain.TLD/EpicorInstance/api/v2/odata/C001/BaqSvc/zCustomer01/Data?$select=Customer_CustID,Customer_Name&$filter=indexof(Customer_Name,'a') gt 0&$top=100&$skip=0
Second 100 Customers (Skip the first 100) whose name contains A
https://Domain.TLD/EpicorInstance/api/v2/odata/C001/BaqSvc/zCustomer01/Data?$select=Customer_CustID,Customer_Name&$filter=indexof(Customer_Name,'a') gt 0&$top=100&$skip=100
Third 100 Customers (Skip the first 200) whose name contains A
https://Domain.TLD/EpicorInstance/api/v2/odata/C001/BaqSvc/zCustomer01/Data?$select=Customer_CustID,Customer_Name&$filter=indexof(Customer_Name,'a') gt 0&$top=100&$skip=200
Etc
Thanks for the reply, but I was trying not to add anymore BAQs to a system with hundreds of them already. I thought about changing the “DefaultMaxRowCount” but that seems like a poor solution.
Awkward Kenan Thompson GIF by Saturday Night Live
… but
BAQs cost (zero) to the system unless they are run and only consume resources when they are being explicitly run / called. So have XX number of BAQs in the system is generally just fine…
Yes, of course your right and I do understand that they’re no performance penalty when the BAQ is not in use. Maybe I’m just tired of Epicor ERP complaints when it’s just some users un-optimized BAQs causing the problems and not Epicor itself. Still I wish there was a usable pagination feature in pure Epicor API/V2. I would even accept the lousy Apex Connector Framework used by Saleforce where I have to declare the QUERY_PAGINATION_SERVER_DRIVEN capability.
What happens when you run the equivalent BAQ from PowerShell?
$stopWatch = New-Object -TypeName System.Diagnostics.Stopwatch
$c = Get-Credential
$stopWatch.Start()
Invoke-RestMethod "https://(Server)/(Instance)/api/v1/BaqSvc/(YourBaqName)" -Authentication Basic -Credential $c -outfile "records.txt"
$stopWatch.Stop()
$stopWatch.Elapsed
I had the BAQ limit set to 6000 and included every field in PartTran. It ran in 5.229 seconds, including writing the output to a file.
Here is the function version:
//Epicor Function function-5
  List<PartTran> list = (from t in Db.PartTran select t ).Take(6000).ToList();
  output = JsonConvert.SerializeObject(list);
//Call Function Powershell Post V2 API
$c = Get-Credential
$stopWatch.Start()
$header = @{
'X-API-Key' = 'Your-API-KEY'
#Post
Invoke-RestMethod https://(Server)/(Instance)/api/v2/efx/(Company)/DEMO/function-5 -Credential $c -outfile "parttran2.txt" -Method Post -Headers $header
$stopWatch.Stop()
$stopWatch.Elapsed
Mine was 17 seconds, but be aware I’m cloud and my pilot is run on a 486 DX2/66.
