5.0.338 Crystal PO question
Thanks Troy, Mario, & Michael,
We went from 5.0.317 to 5.0.338. I should have known better. I cleared out my working folder, print previewed the PO again, reset my .dbf's location, then everything pulled-in and linked correctly.
Thanks!
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
(810) 743-1600 ext.323
wpursche@...
----- Original Message -----
Sent: Friday, January 11, 2002 11:25 AM
Subject: RE: [Vantage] 5.0.338 Crystal PO question
Wendy,
I just got the same problem with my terminal server and 5.1. You will have
the same problem with Customer Statements and other crystal forms. First,
clear your working directory. Run a PO again and search for the sidlabls.dbf
file and see where Vantage put it. If you did not modify your vtg file,
should be in c:\vntgwork or c:\vntgwk51.
Any users in 5.1 and using Citrix? I tried to put as temporary directory
D:\users\%username%\vntgwk51. Unfortunately, it does not recognize the user
name to direct their temp files to that directory. Any input from anybody?
Mario Aguirre
Information Systems Manager
Lakin General
Sent: Friday, January 11, 2002 9:52 AM
Subject: [Vantage] 5.0.338 Crystal PO question
I just installed the 5.0.338 patch last night. I'm now having a problem
with our customized Crystal PO form. No matter what I do it doesn't seem to
want to link "sidlabls" or link "porel" tables correctly. One of the errors
it is giving me is that the formula "RelJobLabel" is no longer known. Any
ideas what is going on?
Our Job Traveler form did not print correctly either, but a quick "set
location" and "verify database" fixed that.
Thanks!
Wendy Bowen
wpursche@...
Yahoo! Groups Sponsor
ADVERTISEMENT
I just installed the 5.0.338 patch last night. I'm now having a problem with our customized Crystal PO form. No matter what I do it doesn't seem to want to link "sidlabls" or link "porel" tables correctly. One of the errors it is giving me is that the formula "RelJobLabel" is no longer known. Any ideas what is going on?
Our Job Traveler form did not print correctly either, but a quick "set location" and "verify database" fixed that.
Thanks!
Wendy Bowen
wpursche@...
Depending on which patch you are moving FROM, there was a change to the number of digits in the PONum field. We did what you described below for the Job Traveler and it worked OK. The patch may have even replaced the POForm report, unless you have it renamed and reset in the Vantage Report Links Management (not the right name, you know, the place where you tell Vantage which report to use for the POForm).
So "set location" and "verify database" didn't work? Can you view the report in Crystal Designer?
Troy Funte
Sent: Friday, January 11, 2002 10:52 AM
Thanks!
Wendy Bowen
wpursche@...
ADVERTISEMENT
Wendy,
Mario Aguirre
Lakin General
Thanks!
Wendy Bowen
wpursche@...
