Vantage 8.03.408A Progress
Using shop tracker as outlined took approximately 14 seconds for 10,000 Records.
We are running two Intel Xeon X5650 processors with 32Gb ram on Windows 2008R2
Enterprise Server (PowerEdge R710). The database is on a PERC H700 Raid 10
controller with four SSD drives. No virtualization.
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Tue, February 22, 2011 9:16:27 AM
Subject: RE: [Vantage] Re: 8.03 Performance Monitoring and Troubleshooting (2011
Edition)
Â
Using shop tracker as outlined below returning 10,000 rows for me takes
approximately 15 - 17 seconds.
That being said I would like to point out that I am using a completely virtual
environment with the data stored on a SAN. I am curiously if you guys are on
dedicated hardware or virtualized?
"Zac" Jason Woodward
Network Administrator
Intermountain Electronics, Inc.
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Creating customer confidence through extraordinary service and experienced
industry experts.
cubcrafters_it
Sent: Monday, February 21, 2011 1:56 PM
Subject: [Vantage] Re: 8.03 Performance Monitoring and Troubleshooting (2011
Edition)
Yeah, ~10.8 to return 10,000 rows to my client (Win 7 VM). Haven't yet tried
directly on the server.
I was just trying to find something that other folks would have data against
without getting too heavy into the customizations.
Anyone else feel like posting some figures? :)
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Waffqle
<waffqle@...> wrote:
Edition)
Â
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
industry experts.
cubcrafters_it
Edition)
> How many records were you returning on that search? If you were getting 10k
> records a 10sec search wouldn't be considered too bad.
> On Mon, Feb 21, 2011 at 11:42 AM, cubcrafters_it <
> jason.navarrete@...> wrote:
> > So is anyone feeling particularly generous on this wonderful Monday to try
> > running the previously outlined 'benchmark'?
> > Or can someone think of another simple tests that might be repeatable
> > amongst various systems? It'd be handy to get some figures to compare the
> > speed of different setups.
>"cubcrafters_it" <jason.navarrete@>
> > wrote:
> > > So my perflogs didn't turn up anything completely out of the ordinary,
> > but there are a few small things I'll follow up on.
> > > Still need to schedule some time to restart the task and process agents,
> > so we'll see what that does.
> > > Here's what I timed:
> > > Production Management -> Job Management -> General Operations -> Shop
> > Tracker
> > > Picked a resource group with a lot of labor rows, then over on the labor
> > tab, clicked 'labor' to bring up Labor Detail Search. Changed the options to
> > return 10,000 rows max, and then clicked search. Timed the time it took to
> > return those rows on my test client. Just used a stopwatch rather than using
> > a trace, as I didn't want that additional overhead.
> > > Average over 5 runs: 10.8 seconds (on 8.03.409A, Progress 10.1B)
> > > If anyone feels like running this test, I'd greatly appreciate it. Or
> > please suggest another benchmark that would be repeatable on other systems.
><waffqle@> wrote:
> > > > I'd bump it up a bit and see what happens.You'll need to restart the
> > task
> > > > agent and the process agent. This won't throw kick everyone off, but
> > it'll
> > > > stop print jobs and service connect and possibly other stuff.
> > > > PERC should be good to go.
> > > > Have you timed any non-print/submitted processes? Adding lines or
> > saving
> > > > orders/jobs/etc?
> > > > You can run a trace and use the time info to do a rough benchmark.
> > That's a
> > > > good way to tell whether it's the server or the client.
> > > > On Thu, Feb 10, 2011 at 6:00 PM, cubcrafters_it <
> > > > jason.navarrete@> wrote:
> > > > > You may be onto something important here: my Processing Delay is
> > currently
> > > > > set to 2 (default is 10?). I've never seen my server on any sort of
> > > > > sustained processor load, however, so could that still be an issue?
> > Can I
> > > > > bump up the delay without having to restart anything?
> > > > > And as far as the RAID is concerned, it's on a PERC 5i with a BBU, so
> > I
> > > > > would hope it's a halfway decent setup.
> > > > > Still waiting on my performance logs to analyze this afternoon.
> > > > > -Jason
>Waffqle <waffqle@> wrote:
> > > > > > Print Jobs other 'Submitted Jobs' aren't always the best gauge of
> > > > > > performance as they use a polling system.
> > > > > > It may take you 20 seconds to see the print job even if it only
> > took the
> > > > > > system 2 seconds to produce it. The other 18 seconds, you're just
> > waiting
> > > > > on
> > > > > > the System Agent to poll.
> > > > > > You can reduce the polling time in the System Agent. Whatever
> > 'Processing
> > > > > > Delay' is set to is the maximum time it will take the system to
> > begin a
> > > > > > submitted job.
> > > > > > Note, be careful not to set it too fast lest it start stepping on
> > itself.
> > > > > 10
> > > > > > seconds is probably a safe starting point if it's currently set to
> > a
> > > > > large
> > > > > > number. You might be able to get away with 5 seconds if your server
> > is
> > > > > under
> > > > > > a pretty low load. A bit of trial and error will get you to the
> > right
> > > > > > number.
> > > > > > Also, if your system has been locking up and you find that the
> > processing
> > > > > > delay is set especially low ...you probably just found the culprit.
> > > > > > Lastly, I didn't think to ask, but you're not running a white box
> > or
> > > > > cheap
> > > > > > (god forbid software) RAID? If your RAID isn't being handled by a
> > proper
> > > > > > controller, all bets are off as far as performance goes.
> > > > > > On Thu, Feb 10, 2011 at 2:00 PM, cubcrafters_it <
> > > > > > > @cooner
> > > > > > > Yeah, 15 regular/15 MES seems like it ought to be fairly
> > lightweight,
> > > > > and
> > > > > > > it's probably less than 10 regular users on a regular basis.
> > > > > > > What sort of transactions are you talking about and how would I
> > check?
> > > > > The
> > > > > > > bulk of any sort of interaction with the system would be around
> > > > > > > manufacturing/production, if that makes any sense.
> > > > > > > We're using the same box since I started 7 months ago; it's
> > probably
> > > > > been
> > > > > > > formatted once somewhere along the lines, but it's got its fair
> > share
> > > > > of
> > > > > > > updates. We've got a new server waiting for Epicor 9, but again,
> > I have
> > > > > a
> > > > > > > nagging feeling the current server might be underutilized.
> > > > > > > I didn't have too much trouble going through the db tuning guide,
> > and
> > > > > so
> > > > > > > far it looks like we had a few things over-configured, so I'm not
> > sure
> > > > > what
> > > > > > > that means for us either.
> > > > > > > @waffqle
> > > > > > > We're not virtualized.
> > > > > > > I stared at perlogs for a few minutes this morning and the max I
> > saw
> > > > > > > Current Disk Queue Length was 2. I'm running Microsoft's PAL tool
> > (has
> > > > > > > anyone else ever used this? I just found it today) this afternoon
> > and
> > > > > > > logging data for 5 hours, to see if that turns up anything
> > useful.
> > > > > > > No termserv. Most of our MES computers are old, but even some of
> > our
> > > > > new
> > > > > > > machines seem to take longer than it should for some operations
> > or
> > > > > > > particular reports (but what's normal?).
> > > > > > > Network issues are a whole other ball of wax, but should be
> > readily
> > > > > > > identifiable if I run a client instance directly on the server.
> > We've
> > > > > got
> > > > > > > entry-level server Gb switches.
> > > > > > > Out of curiosity, can someone tell me how long it takes them to
> > > > > > > preview a Menu Security Report for APRP4100 (1099 Processing),
> > > > > unchecking
> > > > > > > 'New Page Per User/Group' but leaving all the other defaults? I
> > get a
> > > > > 19
> > > > > > > page report, and it took an average of 9.3 seconds to run
> > directly on
> > > > > the
> > > > > > > server.
> > > > > > > Thanks for all the help so far. The cumulative information here
> > has
> > > > > been
> > > > > > > more beneficial than anything I've gotten elsewhere.
>"cooner_55421" <cooner_55421@>
> > wrote:
> > > > > > > > Hi,
> > > > > > > > Looks like you have 15 regular users and 15 MES users?
> > > > > > > > That doesn't sound like it would be a big strain on your
> > system.
> > > > > > > > Just wondering about transactions. Amount, type, etc...?
> > > > > > > > History of your install. Fresh or a long history of upgrades on
> > the
> > > > > same
> > > > > > > box?
> > > > > > > > >the Progress DB tuning guide,
> > > > > > > > >but I should probably go back through that again
> > > > > > > > I find the guide a little confusing.
> > > > > > > > I called Epicor Support several times - Tech/Install (option 3
> > & 1)
> > > > > > > > I got lucky and connected with a guy who put in some extra
> > effort.
> > > > > > > > I don't have his name handy right now, anyway...
> > > > > > > > He was able to explain a couple of things to me I never would
> > have
> > > > > > > figured out from the guide.
> > > > > > > > I'm assuming you aren't virtualized, correct me if I'm wrong.
> > > > > > > > If your buffer hits are already at >98% then more RAM isn't
> > going to
> > > > > get
> > > > > > > you
> > > > > > > > anywhere.
> > > > > > > > Perfmon should be able to tell you pretty definitively whether
> > or not
> > > > > > > your
> > > > > > > > disks are your issue. (Though I would tend to assume they're
> > the
> > > > > > > > bottleneck.) Load it up and monitor your Average and Current
> > Disk
> > > > > Queue
> > > > > > > > Length. If your queue length is higher than "1.5 x # of
> > spindles(4)"
> > > > > your
> > > > > > > > disks are holding you back.
> > > > > > > > It's tempting to look at Read/Write and other IO measurements,
> > but at
> > > > > the
> > > > > > > > end of the day if your queue is long, your disks are
> > overloaded.
> > > > > > > > Also have you looked at your clients? The Vantage/Epicor client
> > is
> > > > > not a
> > > > > > > > lightweight piece of software. If you're running a term serv,
> > check
> > > > > the
> > > > > > > load
> > > > > > > > on that as well.
> > > > > > > > Look at your network out as well. As you're only running 15
> > users, I
> > > > > > > imagine
> > > > > > > > your network isn't too huge or overloaded; but it's certainly
> > worth
> > > > > > > > checking. Check the load on your switches/routers.
> > > > > > > > On Thu, Feb 10, 2011 at 11:28 AM, cubcrafters_it <
> > > > > > > > > We're only using 5 out of our 8 GB of RAM. Can I devote more
> > of it
> > > > > to
> > > > > > > the
> > > > > > > > > DB or App servers? Would that be beneficial? Buffer Hits are
> > > > > already at
> > > > > > > > > ~98%.
> > > > > > > > > Disks are 15k SAS 3Gb/s drives, but yes, everything Epicor is
> > on
> > > > > the
> > > > > > > same
> > > > > > > > > RAID 10. Does anyone happen to have documentation on moving
> > temp
> > > > > dirs
> > > > > > > to
> > > > > > > > > different spindles? I'll also try monitoring disk access to
> > see
> > > > > what
> > > > > > > that
> > > > > > > > > tells me.
> > > > > > > > > I'm a little hesitant to throw hardware at the problem when
> > I'm not
> > > > > > > > > completely convinced that it will solve the problem
> > (partially
> > > > > because
> > > > > > > I'm
> > > > > > > > > cheap).
> > > > > > > > > --- In
>vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "markbetts66"
><markbetts66@>
> > > > > wrote:
> > > > > > > > > > Hi,
> > > > > > > > > > You may want to try more RAM. What type of disks are you
> > using in
> > > > > > > your
> > > > > > > > > server? When you say RAID10(EPICOR) do you mean DB,
> > Appserver,
> > > > > progress
> > > > > > > Temp
> > > > > > > > > Dir and report Temp Dir on the same disk?
> > > > > > > > > > --- In
>vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "cubcrafters_it"
> > > > > <jason.navarrete@>
> > > > > > > > > wrote:
> > > > > > > > > > > First off, very glad to have found this group.
> > > > > > > > > > > Secondly:
> > > > > > > > > > > Vista 8.03.409A on Progress 10.1B
> > > > > > > > > > > Dual Core Xeon 5160 3GHz, 8GB RAM
> > > > > > > > > > > RAID 1 (OS) + 10 (Epicor)
> > > > > > > > > > > d1: 2.21GB, b1: 341MB
> > > > > > > > > > > ~15 Standard + ~15 MES Users
> > > > > > > > > > > We're currently plagued with performance/speed/lockup
> > issues,
> > > > > and
> > > > > > > would
> > > > > > > > > love to be able to mitigate as much of it as possible in our
> > > > > journey to
> > > > > > > > > Epicor 9.
> > > > > > > > > > > I ran a dump and load at the beginning of the year, and
> > while
> > > > > it
> > > > > > > took
> > > > > > > > > the scatter factor down significantly, it didn't appear to
> > make a
> > > > > > > noticeable
> > > > > > > > > different in the end user experience (but it made me feel a
> > whole
> > > > > lot
> > > > > > > > > better). I also did look at the Progress DB tuning guide, but
> > I
> > > > > should
> > > > > > > > > probably go back through that again.
> > > > > > > > > > > Right now I'm lucky if we go a couple of weeks without
> > > > > something
> > > > > > > > > bringing down the system. I feel like I don't have any
> > visibility
> > > > > into
> > > > > > > > > what's causing the issues.
> > > > > > > > > > > I'd like to be able to monitor the server with something
> > like
> > > > > > > Nagios to
> > > > > > > > > help identify if something is out of order, but it's
> > frustrating
> > > > > that I
> > > > > > > > > rarely see the CPU get higher than 25%. There are some simple
> > > > > processes
> > > > > > > > > (searching for all Report Styles or Data Defs) that on
> > occasion
> > > > > seem to
> > > > > > > take
> > > > > > > > > a whole lot longer than they ought to.
> > > > > > > > > > > We're trying to work with a big Epicor guru for some paid
> > > > > advice,
> > > > > > > but
> > > > > > > > > it's been a little tricky to coordinate scheduling so far.
> > > > > > > > > > > Any thoughts, ideas, or suggestions would be helpful at
> > this
> > > > > point.
> > > > > > > I'm
> > > > > > > > > only 6 months in supporting the system, so just about
> > everything is
> > > > > new
> > > > > > > > > information for me.
> > > > > > > > > > > Thanks in advance!
