We had a similar issue and found that if you did the conversion on a
physical box that it cut the time down to a fraction of what it took on
a virtual box.
Of bob.herold
Sent: Wednesday, August 25, 2010 11:04 AM
Subject: [Vantage] Vantage 8.03 conversion to Epicor 9/9.05 performance
issues (large database)
I am in the process of converting my SQL server based Vantage 8.03.409A
database to Epicor 9.04.506b3 and am experiencing performance problems.
The conversion is currently running 13 to 14 days. I am wondering if
anyone else has had a similar experience. I am running the conversion on
what I would call intermediate hardware. I don't want to make a new
server purchase prior to seeing what Epicor 9 or 9.05 looks like so I am
willing to have the conversion run a little longer than it should on new
server equipment, but 13 days seems unreasonable. I am hoping that my
current Progress settings can be tweaked to improve the conversion time.
Our production database is currently 108 GB. We went live on Vantage
8.03.403C in March 2008.
Here are the upgrade systems hardware setup and software settings:
The physical system is a Dell Precision T7500 running VMware ESX 4.1. It
is configured with dual 4 core Intel Xeon processors running at 2.53
GHz. The system has two 300 GB 7200 RPM SAS hard drives and 28 GB of
memory.
The virtual system which has Epicor 9 installed is configured as a
Windows 2008 Enterprise R2 system. I setup the system with 4 processors,
22 GB of memory and created C: and E: drives to split the database
files. The initial conversion is going to run against SQL Server 2005 32
bit. All available patches and hot fixes have been applied.
The Progress settings are DB buffers set at 100000, lock table entries
set at 409600 and spin locks at 80000. I've tried running the conversion
with the Progress database in Read Only mode but it actually seemed to
lengthen the conversion time and Epicor support advised against it.
There is one good aspect to the conversion, it finishes without any
errors and initial testing of Epicor 9 looks pretty clean.
Bob
a virtual box.
Of bob.herold
memory.
Bob
