Activex error with Citrix Metaframe XP
I did intstall Progresss Client, Report Builder, and Query Results on
the Citrix server as the intsllation guide from Epicor.
I did not install Vantage on the Citrix server.
The error is happening every morning when users login. So I did
schedule to reboot the server early in the morning to avoid the
problem for now.
The Citrix was working fine for two years since the first
installation and i did not change anything but suddendly the error
occurs
--- In vantage@yahoogroups.com, "Mark Smith" <mark_smith@i...> wrote:
> I am having the same issue with my test environment. I have a
separate
> host for test environment and in the past set up a published app for
> testing remotely, etc. However, since upgrading to Metaframe XP
I've
> had the same issues. I was told to run the client installation on
the
> server under a different name referencing my test host, but to date
have
> not had time to do so. I ran the regocx.exe and it hosed the rest
of
> apps, so I had to run unregocx to undo the previous changes. Is it
> advisable to install a second client on the server under a different
> installation name? This is what Vantage support told me anyways.
> -----Original Message-----
> From: John Mansfield [mailto:johnm@g...]
> Sent: Wednesday, December 17, 2003 7:29 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Activex error with Citrix Metaframe XP
> We had a similar problem when we were on 91c and Vantage 5.1. We are
> using Citrix 1.8 though. I believe there is a program called
regocx.exe
> that registers your ocx files. Before you run it I would give Ben
Nixon
> a call at Vantage Tech support. He will be able to help you. Ben is
on
> the road a lot so he is had to get on the line.
> Where in Vantage does the error occur?
> Good Luck,
> John Mansfield
> General Sheet Metal
> From: nvong@m... [mailto:nvong@m...]
> Sent: Wednesday, December 17, 2003 8:20 AM
> Subject: [Vantage] Activex error with Citrix Metaframe XP
> Hi,
> We keep having this error every day. The only solution we can do
> right now is to restart the server.
> I did try to uninstall Progress Client and reinstall it but did not
> help.
> The Progress is 9.1C and Vantage 5.1
> Any idea?
> Please
> Thansks,
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> <http://groups.yahoo.com/group/vantage/files/>
> Yahoo! Groups Sponsor
> ADVERTISEMENT
<http://rd.yahoo.com/SIG=12c92kaup/M=267637.4116719.5338353.1261774/D=
eg
roupweb/S=1705007183:HM/EXP=1071753641/A=1853618/R=0/*http:/www.netfli
x.
> com/Default?mqso=60178338&partid=4116719> click here
> <http://us.adserver.yahoo.com/l?
M=267637.4116719.5338353.1261774/D=egrou
> pmail/S=:HM/A=1853618/rand=830475432>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms
of
> <http://docs.yahoo.com/info/terms/> Service.
must
access. )
Builder
> _____
> Yahoo! Groups Links
of
Hi,
help.
Any idea?
Please
Thansks,
using Citrix 1.8 though. I believe there is a program called regocx.exe
that registers your ocx files. Before you run it I would give Ben Nixon
a call at Vantage Tech support. He will be able to help you. Ben is on
Good Luck,
John Mansfield
General Sheet Metal
Hi,
help.
Any idea?
Please
Thansks,
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12c92kaup/M=267637.4116719.5338353.1261774/D=eg
roupweb/S=1705007183:HM/EXP=1071753641/A=1853618/R=0/*http:/www.netflix.
<http://us.adserver.yahoo.com/l?M=267637.4116719.5338353.1261774/D=egrou
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
On Citrix/Terminal Server installations you shouldnt have the Progress Networking Client installed. You should install a full version of Progress on the Citrix Server. There are detailed instructions on the Epicor web site.
Jeremy
Hi,
help.
Any idea?
Please
Thansks,
Yahoo! Groups Links
Your use of Yahoo! Groups is subject to:
I am having the same issue with my test environment. I have a separate
testing remotely, etc. However, since upgrading to Metaframe XP I've
had the same issues. I was told to run the client installation on the
server under a different name referencing my test host, but to date have
not had time to do so. I ran the regocx.exe and it hosed the rest of
Good Luck,
John Mansfield
General Sheet Metal
Hi,
help.
Any idea?
Please
Thansks,
ADVERTISEMENT
_____
Yahoo! Groups Links
_____
Yahoo! Groups Links
