Have you been through any prototyping? If not...I would strongly
encourage it.
HHMES - There are several limitations...probably could write a book.
I know there is a user group and a few companies that are working
with Epicor to improve it...but will probably not be available until
Epicor 9.0
AMM - If your plans are to use it for standard issue and return from
MES...it is good.
Two things to note.
1. WIP Movement still does not work; which is a real bummer!!!
2. When the Shop Floor Employee Issues/Mass Issues or Returns, etc.
it does not write to the Part Tran table the Shop Employee ID.
Instead it uses the DCDUserID attached to the Shop Employee. So for
real tracking of "who did it" is not there. That is unless each and
every shop floor employee is setup with a user account on the
application side. We have generic user accounts designating the
area. So we have customizations, but isn't perfect. Once Capture is
run, it wipes out how we are storing the Shop Employee ID to the Part
Tran.
Patty Buechler
encourage it.
Epicor 9.0
MES...it is good.
Two things to note.
Tran.
Patty Buechler
--- In vantage@yahoogroups.com, "Matt Caldwell" <matt@...> wrote:
> We are about to implement these modules in Vantage 8.03.404A. Is
there
> anything major that we should be aware of before we begin? When we
> activated the CRM module, there was quite a bit of information that
we
> had to update before we could use it. I am wondering if AMM is
going
> to have the same issues.
> Matt Caldwell
> Technical Support Analyst
> KERUSSO
> P.O. Box 32
> Berryville, AR 72616
> Phone: 800-424-0943 Ext. 231 or 870-480-4530
> Fax: 870-423-3568
> Web Site: http://www.kerusso.com
> CONFIDENTIALITY STATEMENT:
> This message, from Kerusso Inc., contains information
> which is privileged and confidential and is solely for the use of
> the intended recipient. If you are not the intended recipient, be
> aware that any review, disclosure, copying, distribution, or use
> of the contents of this message is strictly prohibited. If you have
> received this in error, please destroy it and notify us immediately
> at: 800-424-0943
