After 701 upgrade, cannot modify dashboards
Hi Joe,
Yes, there are two patch files for 701 relating to dashboards and customizations as they both have problems. Sometimes with customizations you make changes and they didn't stick.
You have to paste these files in to your client folders.
Epicor.Mfg.UI.Dashboard.dll
Epicor.Mfg.UI.EpiClientLib.dll
You can get them from Epicor support.
HTH,
Ross
--- In vantage@yahoogroups.com, Joe Rojas <jrojas@...> wrote:
> Hi All,
> I called Epicor but so far do not have an answer. I thought I would see
> if anyone in the group has seen this issue.
> We upgraded our database from 9.04.507a to 9.05.701 to start our testing
> of 701.
> We have a few databases that are deployed as DLLs so I went to redeploy
> them. When I opened them, the first thing I noticed was that layout of
> the dashboards were all messed up. I moved everything back into place
> but then noticed that I could not save the dashboard. The save icon is
> disabled. I also noticed that the Deploy menu item is disabled too.
> I checked out all the other dashboards that we made and the same is true
> for them too.
> Anyone else run into this? Did you get a fix from Epicor?
> Joe Rojas | Director of Information Technology | Mats Inc
> dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
> jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
> This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Hi All,
of 701.
for them too.
I am able to edit my dashboards and change an updatable dashboard and deploy again.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joe Rojas
Sent: Friday, February 22, 2013 2:22 PM
Subject: [Vantage] After 701 upgrade, cannot modify dashboards
Hi All,
of 701.
for them too.
jrojas@...<mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
I should add our DB went from 9.05.607A to 9.05.701. it has only been up for a week, but seems to run faster and the three things I checked so far have worked....well now 4 things.
Hi All,
of 701.
for them too.
