Allow Paste Insert into custom UltraGrid
I am working on a custom form with an UltraGrid control with its datasource bound to a data table. The data table is created when the form loads.
I am at a loss as to how I can enable “Paste Insert” behavior on this control.
I have tried setting the “EpiAllowPaste” and EpiAllowPasteInsert properties of the grid, but to no avail.
I have also tried un-binding the grid to see if it’s related to my binding, but the behavior is the same.
I’m guessing it’s something else, but is there a trick to getting an UltraGrid to allow paste insert?
Needed to create a custom EpiDataView, register it with oTrans, and then bind the grid to it via the control properties.
could you sure code?
Remind me on Monday and I’ll do it
wondering if you can share the code.
Obviously there is a lot more in here than you’ll need, but I create a data table and bind it to the transaction object. Then, I create an initialize layout event for that grid and turn on the allow paste insert/update properties.
// Custom code for UD01Form
// Created: 6/1/2018 12:10:31 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win.UltraWinToolbars;
using Infragistics.Win.UltraWinGrid.ExcelExport;
using Ice.Proxy.Lib;
using Ice.Core;
using Ice.Tablesets;
using System.Collections;
using System.Text;
using System.Linq;
public class Script
	DataTable dtInput = new DataTable();
	private EpiDataView edvInput;
	private StringBuilder builder;
	private BackgroundWorker worker;
	private System.Windows.Forms.ProgressBar pbProgress;
	private int totalRecCount = 0;
		this.grdInput.InitializeLayout += new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler(this.grdInput_InitializeLayout);
		this.btnProcesss.Click += new System.EventHandler(this.btnProcesss_Click);
		this.btnClear.Click += new System.EventHandler(this.btnClear_Click);
		dtInput.Columns.Add("Donor",typeof(string));
		dtInput.Columns.Add("OPO Name", typeof(string));
		dtInput.Columns.Add("OPO Donor Number", typeof(string));
		edvInput = new EpiDataView();
		edvInput.dataView = dtInput.DefaultView;
		oTrans.Add("edvInput", edvInput);
		grdInput.EpiAllowPaste = true;
		grdInput.EpiAllowPasteInsert = true;
		//grdInput.InsertNewRowAfterLastRow = true;
		builder = new StringBuilder();
		SetUpPB();
		this.worker = new BackgroundWorker();
		this.worker.DoWork += new DoWorkEventHandler(this.worker_DoWork);
		this.worker.ProgressChanged += new ProgressChangedEventHandler(this.worker_ProgressChanged);
		this.worker.RunWorkerCompleted += new RunWorkerCompletedEventHandler(this.worker_RunWorkerCompleted);
		this.worker.WorkerReportsProgress = true;
		this.worker.WorkerSupportsCancellation = false;
		this.grdInput.InitializeLayout -= new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler(this.grdInput_InitializeLayout);
		this.btnProcesss.Click -= new System.EventHandler(this.btnProcesss_Click);
		this.btnClear.Click -= new System.EventHandler(this.btnClear_Click);
		// Begin Custom Code Disposal
		// End Custom Code Disposal
		pbProgress.Dispose();
		pbProgress=null;
		this.worker.DoWork -= new DoWorkEventHandler(this.worker_DoWork);
		this.worker.ProgressChanged -= new ProgressChangedEventHandler(this.worker_ProgressChanged);
		this.worker.RunWorkerCompleted -= new RunWorkerCompletedEventHandler(this.worker_RunWorkerCompleted);
	private void SetUpPB()
		pbProgress = new System.Windows.Forms.ProgressBar();
		//Draw a textbox where you'd like the PB to be and get its Location from there then remove textbox
		pbProgress.Location = new System.Drawing.Point(14, 335);
		pbProgress.Name = "pbProgress";
		//Draw a TextBox where you'd like the PB to be and get its Size from there then remove textbox
		pbProgress.Size = new System.Drawing.Size(688, 20);
		//Get a Hold of the Parent Container where you'd like the PB to be
		Ice.UI.App.UD01Entry.DetailPanel pnl =(Ice.UI.App.UD01Entry.DetailPanel)csm.GetNativeControlReference("d5488fbc-e47b-46b6-aa3e-9ab7d923315a");
		//Add PB to the above container
		pnl.Controls.Add(pbProgress);
	private void UD01Form_Load(object sender, EventArgs args)
		// Add Event Handler Code
		// Hide Native Toolbar Controls
		baseToolbarsManager.Tools["NewTool"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["RefreshTool"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["DeleteTool"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["SaveTool"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["EditMenu"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["HelpMenu"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["ToolsMenu"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["ActionsMenu"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["FileMenu"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["AttachmentTool"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["ClearTool"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["CopyTool"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["CutTool"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["PasteTool"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["UndoTool"].SharedProps.Visible=false;
		baseToolbarsManager.Tools["PrimarySearchTool"].SharedProps.Visible=false;
		dtInput.Clear();
		txtProgress.Text = builder.ToString();
	private void grdInput_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs args)
		grdInput.InsertNewRowAfterLastRow = false;
	private void worker_DoWork(object sender, DoWorkEventArgs e)
		//sender is BackgoundWorker
		//this is where the background operation goes
		using(UD100Adapter adapterUD100 = new UD100Adapter(oTrans))
			adapterUD100.BOConnect();
			builder.Append("Start Process...").AppendLine();
			//foreach(DataRow dr in dtInput.Rows)
			for(int i = 0; i<dtInput.Rows.Count; i++)
				var dr = dtInput.Rows[i];
				string whereClause = string.Format("Key1 like '{0}-%'", dr["Donor"].ToString());
				//start log
				builder.Append(string.Format("Looking up Donor {0}...", dr["Donor"].ToString())).AppendLine();
				//the Hashtable stores the runtime search criteria
				System.Collections.Hashtable wcs = new Hashtable(1);
				wcs.Clear();
				wcs.Add("UD100", whereClause);
				Ice.Lib.Searches.SearchOptions opts = Ice.Lib.Searches.SearchOptions.CreateRuntimeSearch(wcs, Ice.Lib.Searches.DataSetMode.RowsDataSet);
				adapterUD100.InvokeSearch(opts);
				int rowCount = adapterUD100.UD100Data.UD100.Rows.Count;
				if(rowCount>0)
					foreach(DataRow udRow in adapterUD100.UD100Data.UD100.Rows)
						//modify here
						udRow.BeginEdit();
						udRow["Character04"] = dr["OPO Name"];
						udRow["Character05"] = dr["OPO Donor Number"];
						udRow["RowMod"] = "U";
						udRow.EndEdit();
						//update log
						builder.Append(string.Format("{0}: Success!", udRow["Key1"].ToString())).AppendLine();
						totalRecCount++;
					//update
					adapterUD100.Update();
					worker.ReportProgress(i);
				else
					//update log
					builder.Append(string.Format("******Failed to find UD100 recs for {0}******", dr["Donor"].ToString())).AppendLine();
			adapterUD100.Dispose();
			worker.ReportProgress(100);
	private void worker_ProgressChanged(object sender, ProgressChangedEventArgs e)
		//notifies progress bar when changed
		pbProgress.Value = e.ProgressPercentage;
	private void worker_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
		//On completed, do the appropriate task
		if(e.Error !=null)
			MessageBox.Show("Error while performing tasks!");
		else
			MessageBox.Show(string.Format("Complete. {0} records updated!", totalRecCount.ToString()));
		//re-enable the UI interface to prevent weird threading issues
		btnProcesss.ReadOnly = false;
		btnClear.ReadOnly = false;
	private void btnProcesss_Click(object sender, System.EventArgs args)
		if (dtInput.Rows.Count>0)
			try
				worker.RunWorkerAsync();
				builder.Clear();
				pbProgress.Value = 0;
				totalRecCount = 0;
				btnProcesss.ReadOnly = true;
				btnClear.ReadOnly = true;
			catch(Exception ex)
				MessageBox.Show(ex.Message);
		else
			MessageBox.Show("Add Inputs");
	private void btnClear_Click(object sender, System.EventArgs args)
		dtInput.Clear();
		builder.Clear();
		txtProgress.Text = string.Empty;
		totalRecCount = 0;
Just what I needed to do, thanks!
could you give an example for it? thanks before :grinning:
Hi Nail,
The example I posted in this post should get you going in the right direction
Aaron,
Is I been using this as a guide for a similar project I am working on in 11.2.400 and i can get the paste insert to somewhat work( I can get only one column to show which is useful) but i keep getting a error when trying to process. I have verified my code matches yours. There is one difference and that is Ice.Proxy.Lib isn’t available on this version. Any help would be great.
