Cool, we'll try that.
Sent: Friday, January 9, 2009 4:51:40 PM
Subject: RE: [Vantage] Any way to change a serial number?
select the void on the serial number maintenance and the new and re enter
the data.
Steve
From: Steven Gotschall [mailto:sgotschall@yahoo. com]
Sent: January 09, 2009 3:15 PM
To: vantage@yahoogroups .com
Subject: Re: [Vantage] Any way to change a serial number?
Nope. It says it can't be deleted because there are transactions against
it.
____________ _________ _________ __
Sent: Friday, January 9, 2009 4:02:19 PM
Can you change the status on the serial number from shipped to WIP or Stock
then delete?
Steve
From: Steven Gotschall [mailto:sgotschall@ yahoo. com]
Sent: January 09, 2009 2:56 PM
Because it has been shipped, Serial Number maintenance won't let you delete
it.
Sent: Friday, January 9, 2009 3:39:46 PM
You can save all the data in the serial number maintenance, then delete.
You can now enter the correct serial number and manually re enter the old
data.
Steve
Sent: January 09, 2009 2:14 PM
Subject: [Vantage] Any way to change a serial number?
Vantage 8.03.407 Progress
We shipped three items to a customer and later found the serial numbers
that were entered into Vantage were not correct. Any way to change the
serial numbers?
If I have to go into the tables using ODBC (Gulp!), what tables
referece the serial numbers?
the data.
Steve
it.
then delete?
Steve
it.
data.
Steve
serial numbers?
