Serial Numbered Part has two 'Ghost' items in stock that don't h
If you find that a serial number has the wrong status - in Serial number Maintenance – it will allow you to change  the status. You will get a nasty  warning.
You can change the status to Inventory and  it will show up in your list when you  do a quantity adjustment.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Sarah Colbaugh
Sent: Tuesday, February 18, 2014 12:27 PM
Subject: RE: [Vantage] Serial Numbered Part has two 'Ghost' items in stock that don't have Serial Numbers
Will it allow you to do a quantity adjustment?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Cathy
Sent: Tuesday, February 18, 2014 1:20 PM
I don’t know how many serial numbers you have for this part but, have you looked at Part Tracker?
There might be a serial number with the wrong status.
Example WIP instead of Inventory -
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Adrian Lauchlan
Sent: Saturday, February 15, 2014 2:51 AM
Cc: vantage@yahoogroups.com
Subject: Re: [Vantage] Serial Numbered Part has two 'Ghost' items in stock that don't have Serial Numbers
Ok that's the difference - we are on E9 - should have said - version 604
Sent from my iPad
On 14 Feb 2014, at 20:23, Chris Annable <CANNABLE@...> wrote:
That is interesting because in our system despite having inventory on hand and being clicked as quantity bearing it allows us to un-click the
Track serial number field. We are on version 8.03.409c.
Sent: Friday, February 14, 2014 3:08 PM
This doesn't work because the tick box is greyed out whilst there is stock
Sent: 14 February 2014 20:31
Will try that - will it link up the serial numbers again?
Sent from my iPad
On 14 Feb 2014, at 13:11, Chris Annable <CANNABLE@...<mailto:CANNABLE@...>> wrote:
Change the part number from serialized to un-serialized make your inventory adjustment. Then make the part serialized again.
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com] On Behalf Of adrian.lauchlan@...<mailto:adrian.lauchlan@...>
Sent: Thursday, February 13, 2014 5:43 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Subject: [Vantage] Serial Numbered Part has two 'Ghost' items in stock that don't have Serial Numbers
A serial numbered part in our stock shows 21 on hand for a bin, but we only have 19 S/N’s available I want to make the on hand balance match up with the S/N’s on hand, basically making 2 of them disappear from on hand. I cannot do that as it is asking me for the S/N’s and what we show for on hand S/N’s is correct. Any suggestions as to how to get rid of these two 'Ghost' items?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of adrian.lauchlan@...
Sent from my iPad
On 14 Feb 2014, at 13:11, Chris Annable <CANNABLE@...> wrote:
<div id="ygrps-yiv-1427060710ygrp-text">
  <p>Change the part number from serialized to un-serialized make your inventory adjustment.  Then make the part serialized again.
</div>
Sent from my iPad
Sent from my iPad
Sent from my iPad
<div id="ygrps-yiv-2043091384ygrp-text">
  <p>That is interesting because in our system despite having inventory on hand and being clicked as quantity bearing it allows us to un-click the
Sent from my iPad
</div>
I use the Web Service Tester to delete Serial numbers (SerialNo Service) that are blank.  What I do is:
- Use the the GetList method to verify that there is a blank serial number.  The whereClause is PartNum = 'AAAAA'.
- Call DeleteByID.  The PartNum parameter does not require quotation marks.  I leave the serial number parameter empty.
- Call GetList again to verify it is gone.
Thanks for this - I haven't used the Web Service Tester before - not even sure where it might be - is there any instructions/help available online for it?
On 18 Feb 2014, at 16:24, <dgodfrey@...> wrote:
<div id="ygrps-yiv-601714773ygrp-text">
  <p>I use the Web Service Tester to delete Serial numbers (SerialNo Service) that are blank.&nbsp; What I do is:<br>- Use the the GetList method to verify that there is a blank serial number.&nbsp; The whereClause is PartNum = &#39;AAAAA&#39;.<br>- Call DeleteByID.&nbsp; The PartNum parameter does not require quotation marks.&nbsp; I leave the serial number parameter empty.<br>- Call GetList again to verify it is gone.</p>
</div>
I think it comes with the Full client install.  We have it in the \\Epicor\mfgsys803400\Utilities directory.  Not much to it regarding documentation since it is kind of ‘use-it-at-your-own-risk’.  I think it was originally meant for the Epicor Developers to test their stuff.  Same with the BL Tester.
All you need is the URL of the specified discovery file for the Web Services (i.e.: LIVE or TEST or PILOT).  Your IT personnel should be able to help with that.  After you have entered the specific URL.disco file, then all of the loaded Web Services for that database should eventually show up.  Double click  any service and another form should pop up.  Enter in your Epicor user name and password on the left side.  You will only have to enter in this information at the beginning of each use of the WS Tester.  Meaning that if you call multiple methods from multiple web services, you only need to enter your info the first time until you close the form and reopen it again.
I use the BL Tester and WS Tester a lot.  To see what the data looks like before and after I make changes.
Sent: Tuesday, February 18, 2014 9:35 AM
Cc: <vantage@yahoogroups.com>
Subject: Re: [Vantage] RE: Serial Numbered Part has two 'Ghost' items in stock that don't have Serial Numbers
------------------------------------------------------------------------------------------------------------------------ CONFIDENTIALITY NOTICE: The data attached/enclosed may contain information (including technology and technical data) which is subject to the U.S. International Traffic in Arms Regulations (ITAR) or Export Administration Regulations (EAR). This information may not be exported, released, or disclosed to foreign persons either inside or outside the United States without first obtaining the proper U.S. export license or written authorization. In addition, the information and articles described herein are either patented or proprietary, and the copying or reproduction thereof is prohibited without ADVANCED Motion Controls prior written consent. If you are not the intended recipient (or have received this e-mail in error), please notify the sender immediately and destroy this e-mail. Any unauthorized copying, disclosure or distribution of the material in this e-mail is strictly forbidden. Thank you for your compliance. X3BTB534
Sent from my iPad
Sent from my iPad
Sent from my iPad
Sent from my iPad
