Wanted to add to this topic as I found a native way to move field security with the solution workbench. Found this in 10.2.5 and above. Not sure if you ever found a solution to this @josecgomez
In the Solution Workbench there is a User Defined search option where you can use the Out Of the Box adapters to search for the pieces you need
The solution install worked with JUST the fields and marking âOnly Target Current Companyâ
Perhaps this wouldnât work in a case where you needed the other pieces in the same solution file. Since Field Security seems to be âownedâ by a company but can apply to all.
