Is any one having problems with 9.05 Company configaration setup i.e. after the DB Migration to 9.05 it does not allow any changed to the Company configartions,All fields have been grayed out.
Â
Â
--- On Mon, 4/4/11, Zac Jason Woodward <zac@...> wrote:
Subject: RE: [Vantage] Re: Anyone running 9.05.604 yet - any gotchas
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Date: Monday, April 4, 2011, 8:15 AM
Â
Highly recommend test environment first. In our testing we have found out it broke several of our customizations and BPMS. No major fixes, but minor ones that took some time to locate the problem. Mostly GUID's that changed for no reason.
"Zac" Jason Woodward
Network Administrator
Intermountain Electronics, Inc.
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Creating customer confidence through extraordinary service and experienced industry experts.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of pcivantage
Sent: Friday, April 01, 2011 4:19 PM
Subject: [Vantage] Re: Anyone running 9.05.604 yet - any gotchas
Progress 32 Bit.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Len Hartka" <len.hartka@...> wrote:
> Good Day George:
> Are you SQL or Progress?
> len.hartka@...
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
> Of pcivantage
> Sent: Friday, April 01, 2011 4:34 PM
> We have been on it for a week. It fixed a lot of problems in .603 for
> us.
> You need to install a Progress HF prior to the installation, so I
> recommend downloading all the files you will need prior to the weekend
> to save time, as they can take awhile. I think the .604 SPK was
> something like 1.4GB to download.
> It seemed to take longer to run the updates etc. this time.
> I also have a 64Bit server, though I am running the 32 Bit install, and
> each time I do an upgrade, I have to run the fix file to repair the
> registry or the SPK will not load. I believe someone else mentioned
> this. It is called "xxxcleanup64.reg"
> I would also recommend that you have your license file for the product
> stored on the server so you can re-import that if needed, but you should
> not need to do that.
> Start early so that you have enough time to get it done and are not
> still running conversions 8:00AM Monday morning.
> DO NOT SKIP THE STEP OF COPYING YOUR EPICOR905 AND OE FOLDERS!! If
> things go badly, you can restore those and continue business,
> otherwise....
> Good Luck,
> George Hicks
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ,
> "p3zmcp" <dolender@> wrote:
> > We are planning on installing 9.05.604 this weekend to fix a handheld
> issue related to custxpart and the part master.
> > Unfortunately, we don't have enough time to completely test this
> version. So I was hoping someone RUNNING 9.05.604 in a live environment
> could give us a "heads up" on any show stoppers.
> > Thanks,
> > DaveO
> > Dave Olender
> This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
