Anyone using Windows Server 2003 - 64bit Edition for running Va
I believe the $2500 difference in price includes 25 CALs which makes it
slightly more attractive.
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
Of hussain555
Sent: Monday, January 29, 2007 10:28 AM
Subject: [Vantage] Re: Anyone using Windows Server 2003 - 64bit Edition
for running Vantage 8.x
I could use Windows 2003 Enterprise but that is $2500 difference in
my server price.
we are using progress database are there any known issues or
limitation with that?
"rstulce" <rstulce@...> wrote:
> You could also use Server 2003 Enterprise edition and get up to 8GB
of RAM.
> What version of SQL Server are you using, or are you going with the
Progress
> database?
> If you're SQL 2000 Server Standard, it only uses 2GB of RAM. For
more you'd
> also need SQL 2000 Enterprise edition or SQL 2005. I'm not sure
of the
> specs for 2005 standard as we aren't thinking of moving to that
until
> Vantage 9 comes out.
> _____
Behalf Of
> hussain555
> Sent: Thursday, January 25, 2007 1:32 PM
> Subject: [Vantage] Anyone using Windows Server 2003 - 64bit Edition
for
> running Vantage 8.x
Vantage 8.x
> I just speced out a Dell 2950 Server for running Testing Vantage
8.0,
> but was limited to 4GB of RAM due to Windows Server 2003 Standard
> Edition. Vantage consultant advised me of using Windows Server
2003 -
> 64bit Edition so I can go up to 8GB. Does anyone know of any
> compatibility issues that might arise in this situation please
share.
> Hussain Ali
> IT Manager
> National Signs Ltd.
> Houston, TX
Anyone using Windows Server 2003 - 64bit Edition for running Vantage 8.x
I just speced out a Dell 2950 Server for running Testing Vantage 8.0,
Edition. Vantage consultant advised me of using Windows Server 2003 -
compatibility issues that might arise in this situation please share.
I have posted my server Spec Below for your comments: Base
Unit: Dual Core Xeon Processor 5140 4MB Cache, 2.33GHz, 1333MHz FSB, PE
2950 (222-3387) Processor: Dual Core Xeon 2nd Processor 5140, 4MB
Cache, 2.33GHz 1333MHz FSB, PE 2950 (311-6220) Memory: 8GB 533MHz
(8x1GB), Dual Ranked DIMMs (311-5732) Keyboard: No Keyboard Selected
(310-5017) Video Card: Broadcom TCP/IP Offload EngineNot Enabled
(430-1765) Video Memory: Riser with 3 PCIe Slots for PowerEdge 2950
(320-4607) Hard Drive: 36GB, SAS, 3.5-inch, 15K RPM Hard Drive
(341-3027) Hard Drive Controller: PERC 5/i, x6 Backplane Integrated
Controller Card (341-3066) Floppy Disk Drive: No Floppy Drive for x6
Backplane (341-3685) Operating System: Windows Server 2003 R2 Standard
x64 Edition,Includes 5 CALs (420-5798) Mouse: Mouse Option None
(310-0024) NIC: Embedded Broadcom NetXtreme II5708 GigabitEthernet NIC
(430-1764) CD-ROM or DVD-ROM Drive: 24X IDE CD-RW/DVD ROM Drive for
PowerEdge 2950 (313-3934) Sound Card: Bezel for PE 2950 (313-3920)
Speakers: 1x6 Backplane for 3.5-inch Hard Drives (311-5747)
Documentation Diskette: Electronic Documentation and OpenManage CD Kit,
PE2950 (310-7415) Additional Storage Products: 36GB, SAS, 3.5-inch,
15K RPM Hard Drive (341-3027) Feature Integrated SAS/SATA RAID 10 PERC
5/i Integrated (341-3061) Feature Rack Chassis w/Sliding Rapid/Versa
Rails and Cable Management Arm,Universal (310-7412) Service: Dell
Hardware Warranty Plus Onsite Service Inital YR (984-1399) Service:
Basic Enterprise Support: Business Hrs 5X10 Tech Support 4HR Onsite
Service Post Problem Diagnosis Init YR (970-4100) Service: Dell
Hardware Warranty, Extended YR (984-1417) Service: Basic Enterprise
Support: Business Hrs 5X10 Tech Support 4HR Onsite Service Post Problem
Diagnosis 2YR Ext (960-8212) Service: BASIC Enterprise Support:
Business Hrs 5x10 Hardware Only Tech Phone Support, 3Yr, Declined
Software Support (960-8242) Installation: On-Site Installation
Declined (900-9997) Misc: Redundant Power Supply with Y-Cord for
PowerEdge 2950 (310-7421) Misc: 36GB, SAS, 3.5-inch, 15K RPM Hard
Drive (341-3027) Misc: 20GB OS Partition Override forMicrosoft OS
Options, PowerEdge (420-4080) Misc: 36GB, SAS, 3.5-inch, 15K RPM Hard
Drive (341-3027)
Hussain Ali
IT Manager
National Signs Ltd.
Houston, TX
You could also use Server 2003 Enterprise edition and get up to 8GB of RAM.
What version of SQL Server are you using, or are you going with the Progress
database?
If you're SQL 2000 Server Standard, it only uses 2GB of RAM. For more you'd
also need SQL 2000 Enterprise edition or SQL 2005. I'm not sure of the
specs for 2005 standard as we aren't thinking of moving to that until
_____
hussain555
Subject: [Vantage] Anyone using Windows Server 2003 - 64bit Edition for
running Vantage 8.x
Drive (341-3027)
Hussain Ali
IT Manager
National Signs Ltd.
Houston, TX
Windows 2003 Server Enterprise edition supports greater than 4GB RAM
(upto 32GB) on a x86-based server.
Of hussain555
Sent: Thursday, January 25, 2007 3:32 PM
running Vantage 8.x
<snip>
Hussain Ali
IT Manager
National Signs Ltd.
Houston, TX
We are live with 8.00.810b on Windows Server 2003 x64 along with SQL
Server 2005 x64 (in 2000 compatibility mode) - no problems with this
environment. Our test server is a Dell 2950 similar to the one you've
described and it runs well.
Brad Feazell
IT Manager | Dril-Quip, Inc.
Vantage 8.x
8.0,
2003 -
share.
FSB, PE
Selected
2950
Integrated
x6
Standard
GigabitEthernet NIC
for
3920)
Kit,
inch,
PERC
Rapid/Versa
Service:
Enterprise
Problem
Hard
> Drive (341-3027)
> Hussain Ali
> IT Manager
> National Signs Ltd.
> Houston, TX
> Edition.
You can also use Windows 2003 Enterprise Edition to get around the 4GB limit.
Mark W.
my server price.
of RAM.
Progress
> database?
more you'd
of the
until
> _____
Behalf Of
> hussain555
for
> running Vantage 8.x
Vantage 8.x
8.0,
2003 -
share.
> Hussain Ali
> IT Manager
> National Signs Ltd.
> Houston, TX
