Change it back to .tiff & it works fine was hoping someone on the group had a similar issue so I don't have to wait 2 months to get this resolved.
--- In vantage@yahoogroups.com, "Blake Clemens" <blake.clemens@...> wrote:
> So you can't even fax out of APM? Can you change it back to TIFF?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> Delmarva Millwork Corporation
> (800) 360-2364 x132
> Of mmcwilliams22
> Sent: Tuesday, July 06, 2010 3:08 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: APM PDFs
> I put a call in over at epicor. I tried the test and am getting errors
> in the event log.
> Event Type: Error
> Event Source: doc-link Output Management Service
> Event Category: Output Processing
> Event ID: 7
> Date: 7/6/2010
> Time: 1:42:07 PM
> User: N/A
> Computer: TBVANTAGE2
> Description:
> Processing of batch 2034 failed with the following error: -2147024864 -
> The process cannot access the file because it is being used by another
> process.
> Processing batch 2034
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Blake Clemens" <blake.clemens@> wrote:
> > We have Adobe Reader 8 installed. Try sending me a document from your
> > setup. Use my email address blake.clemens@
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > (800) 360-2364 x132
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of mmcwilliams22
> > Sent: Tuesday, July 06, 2010 9:48 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Was there any special setup? Do you need acrobat installed on the apm
> > server? I figured just check that as the output fomat and everything
> > should work.
> > > We have PDF working in our setup.
> > > Thanks,
> > > Blake Clemens
> > > IT Systems Engineer
> > > (800) 360-2364 x132
> > Behalf
> > > Of mmcwilliams22
> > > Sent: Tuesday, July 06, 2010 9:04 AM
> > > Subject: [Vantage] APM PDFs
> > > Anyone have APM PDF working? We tried changing from .tiff to
> PDF(tiff
> > > only)per customer request & now users are saying they cannot open
> the
> > > attatchements.
