How do I add a menu item to the overflow menu of a child page in Kinetic 2025.2? More specifically to both the sales order and quote screens, the header screen, not the grid screen with all orders listed. Anyway I try to add it, the item appears on every screen, including the main screen.
I tried the following:
In Application Studio, from the Application map, I selected Sale Order. I then find the Tools on the right and add an item.
On the Sales Order, I have successfully hid my Tools from the overflow menu on the landing page with the rule above.
I have not been successful in doing this for the Quote landing page. How is this one different? What other options are there?
I set no conditions and nothing happens, so it may not be binding to my tool. I deleted the rule and recreated from scratch, not copied, and still nothing. However, the rule I have to disable the tool works fine. Other than the conditions, the rules are identical.
If one rule is working but another is not… I guess I would just scrutinize your binding… I don’t know what your binding is and can’t see the full binding here. But can you find any typos?
Do you need to manually type your field or does the list populate with all TransView fields? Mine is empty and I need to manually type it.
Visually, the field is spelled correctly. I copied and pasted the field from the other rule to this one and now it works. I don’t how they were different, but it didn’t like it the first time.
Not on mine. I have my fields defined in TransView. Any time I have done, I have never had them show up in the dropdown. However, they do show up in component bindings.
