Should have known I spoke too soon. The problem is back so time to wait for support to review the information I sent them.
--- In vantage@yahoogroups.com, "sbraudrick@..." <sbraudrick@...> wrote:
> It got worse this morning, randomly logging users out and such so I called support and they instructed me to delete the system agent and then re-create it using conversion 8180, then editing it to have the correct ports & paths.
> So far, so good, the errors have stopped and it appears everything is working again.
> Support thinks something got screwy with the system agent when we had the power outage.
> Thanks for your help Jose,
> SB
> --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > Make sure the server paths are right the port numbers should match
> > (production 9401 9400) test 9420 9421 etc..
> > Kill all your global alerts.*
> > Start the task agent after you've killed your GA and checked the System
> > Agent properties
> > *Jose C Gomez*
> > *Software Engineer*
> > *checkout my new blog <http://www.usdoingstuff.com> *
> > *T: 904.469.1524 mobile
> > E: jose@
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > *Quis custodiet ipsos custodes?*
> > On Tue, Jun 7, 2011 at 10:14 PM, sbraudrick@
> > <sbraudrick@>wrote:
> > > That stopped the errors. What settings should I be checking on the System
> > > Agent?
> > > > Ok turn on your main app server but leave the task agent off, as well as
> > > > whatever that otherone is that escapes me now. Just turn on the main App
> > > > Server. If you already have it on, stop it all , stop the DB, turn the db
> > > > back on and turn the main App Server back on.
> > > > If that stops it form throwing errors, login to your Epicor and disable
> > > all
> > > > your Global Alerts. Checkl the settings on the System agent and give it a
> > > > shot.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > On Tue, Jun 7, 2011 at 10:01 PM, sbraudrick@
> > > > <sbraudrick@>wrote:
> > > > > This appeared before the onslaught of the other message in the
> > > > > TaskAgent.server log entries.
> > > > > [11/06/07@18:44:21.020-0400] P-004640 T-004644 1 AS -- (Procedure:
> > > > > 'createTaskInstance agent/TaskAgent.p' Line:2072) Startup Process
> > > Started:
> > > > > Global Alerts \ Email Process (Program: si/sim100.p)
> > > > > --- In vantage@yahoogroups.com, "sbraudrick@" <sbraudrick@> wrote:
> > > > > > 750MB, we've only been live for about 6 weeks.
> > > > > > the 905 server log shows these entries, over and over:
> > > > > > [11/06/07@21:51:45.175-0400] P-003244 T-002392 1 AS -- Logging level
> > > > > greater than 1 must be specified either for ASPlumbing or for all types
> > > by
> > > > > using -logginglevel. (11072)
> > > > > > [11/06/07@21:51:45.176-0400] P-003244 T-002392 1 AS -- Logging level
> > > > > greater than 1 must be specified either for DB.Connects or for all
> > > types by
> > > set
> > > > > to = 1
> > > > > > [11/06/07@21:51:45.176-0400] P-003244 T-002392 1 AS -- No entry
> > > types
> > > > > are activated
> > > > > > ProcessServer.server shows:
> > > > > > [11/06/07@18:44:04.185-0400] P-004392 T-004396 1 AS -- (Procedure:
> > > > > 'agent\startup.p' Line:814) Connection failure for host localhost port
> > > 9403
> > > > > transport TCP. (9407)
> > > > > 'agent\startup.p' Line:814) Application server connect failure. (5468)
> > > > > 'agent\startup.p' Line:816) AppServer connection failure: -URL
> > > > > AppServerDC://localhost:9403
> > > > > > [11/06/07@18:44:14.219-0400] P-004392 T-004396 1 AS -- (Procedure:
> > > > > 'agent\startup.p' Line:843) Agent Started: SystemTaskAgent (Program:
> > > > > agent/TaskAgent.p
> > > > > > Think I found it, but what does it mean? This is repeated in the
> > > > > TaskAgent.server log:
> > > > > > [11/06/07@21:55:45.153-0400] P-004640 T-004644 1 AS -- (Procedure:
> > > > > 'processIMRecords agent/TaskAgent.p' Line:2188) Server is not
> > > connected.
> > > > > (5537)
> > > > > > > Do you see anything on your actual App server logs?
> > > > > > > \SERVER\Epicor905\Server\Logs?
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@
> > > > > > > On Tue, Jun 7, 2011 at 9:35 PM, Jose Gomez <jose@> wrote:
> > > > > > > > How big is your DB? Progress has a thing about if your DB is
> > > bigger
> > > > > than 2
> > > > > > > > GB or 4 GB you need to change some settings. Can't remember the
> > > exact
> > > > > number
> > > > > > > > or the setting :-S
> > > > > > > > *Jose C Gomez*
> > > > > > > > *Software Engineer*
> > > > > > > > E: jose@
> > > > > > > > <http://www.josecgomez.com/professional-resume/> <
> > > > > > > > On Tue, Jun 7, 2011 at 9:32 PM, sbraudrick@ <sbraudrick@
> > > > > > > > > wrote:
> > > > > > > >> OK, did that. Still happening, approximately every 10-12
> > > seconds.
> > > > > > > >> What's next?
> > > > > > > >> > Sean,
> > > > > > > >> > Kill all your BPM's and stop using any BAQ Report and see if
> > > > > continues
> > > > > > > >> to
> > > > > > > >> > happen.
> > > > > > > >> > *Jose C Gomez*
> > > > > > > >> > Software Engineer
> > > > > > > >> > E: jose@
> > > > > > > >> > On Tue, Jun 7, 2011 at 8:42 PM, sbraudrick@
> > > > > > > >> > <sbraudrick@>wrote:
> > > > > > > >> > > Our installation started acting wacky today for some reason
> > > > > today
> > > > > > > >> (random
> > > > > > > >> > > disconnections, etc). So I checked the logs and noticed this
> > > > > error
> > > > > > > >> message
> > > > > > > >> > > popping up in the Application Event logs several times every
> > > > > minute.
> > > > > > > >> I've
> > > > > > > >> > > stopped all non-essential servers using PET, and still it is
> > > > > > > >> happening. Has
> > > > > > > >> > > anyone seen this before?
> > > > > > > >> > > Windows Server 2008 R2 64-bit, Progress 64-bit 10.2A
> > > > > installation.
> > > > > > > >> > > ______________________
> > > > > > > >> > > Fault bucket , type 0
> > > > > > > >> > > Event Name: APPCRASH
> > > > > > > >> > > Response: Not available
> > > > > > > >> > > Cab Id: 0
> > > > > > > >> > > Problem signature:
> > > > > > > >> > > P1: _proapsv.exe
> > > > > > > >> > > P2: 10.2.1.1390
> > > > > > > >> > > P3: 4c0d2008
> > > > > > > >> > > P4: _proapsv.exe
> > > > > > > >> > > P5: 10.2.1.1390
> > > > > > > >> > > P6: 4c0d2008
> > > > > > > >> > > P7: c0000005
> > > > > > > >> > > P8: 00000000002e2669
> > > > > > > >> > > P9:
> > > > > > > >> > > P10:
> > > > > > > >> > > These files may be available here:
> > > C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash__proapsv.exe_737798f3582f7c14bf6b68e5a1c7979ff03b82_16bce438
> > > > > > > >> > > Analysis symbol:
> > > > > > > >> > > Rechecking for solution: 0
> > > > > > > >> > > Report Id: 9dee46a0-9165-11e0-8de3-001ec9290b90
> > > > > > > >> > > Report Status: 0
> > > > > > > >> > [Non-text portions of this message have been removed]
