Could someone explain how the Document Type Maintenance works with Document Association?
Example: When you attached a document to a customer, does vantage copy a version of the document to the URL listed in the Document Type Maintenance?
----- Original Message ----
Sent: Friday, May 18, 2007 10:33:36 AM
Subject: RE: [Vantage] Attaching a Document to a Quote
In 6.1 I have attached pdf's (and other documents) to quotes through
Document Association. To do this, first you'll need the string for the
print and view commands in Document Association set up. That you'll find in
system Management/Configur ation maintenance . For pdf's it is: View
AcroRd32.exe "&1" and Print is AcroRd32.exe /p "&1". Then on the quote,
each line has a Doc. Assoc. icon in the upper right corner. Just update the
line and click on the icon to add the path to the document.
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
mwliquidhappy
Sent: Friday, May 18, 2007 11:20 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Attaching a Document to a Quote
I am trying to figure out how I can write progress code to attach a
document to a quote. Has anyone done this before that would have a
code snippet or be able to tell me how to code this?
Thanks!
____________________________________________________________________________________Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545469
_____
mwliquidhappy
Thanks!
