seconds
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
Sent: Monday, February 14, 2011 10:19 AM
Subject: Re: [Vantage] Re:Auto email reports
What is the interval measured in? Seconds, minutes etc
From: Blake Clemens <blake.clemens@... <mailto:blake.clemens%40d-m-c.com> >
Sent: Mon, 14 February, 2011 13:18:53
Subject: RE: [Vantage] Re:Auto email reports
I have a few BAQ's exporting round the clock in our Vantage System.
First create and define the schedule. In order to export the BAQ go to
and open System Management -- Utilities -- Business Activity Query
Export Process. Search and find your query ID or just type it in. Next
select your output format, xml or csv. Give it a file name. Then
select the schedule you want to add it to which would be the one you
previously created. Next hit submit. That should be all you have to
do. If you are having troubles getting your Schedule to run make sure
you defined a date & time for it to start. No matter what interval you
select it will need a date & time start time. Then if all else fails
just restart your appservers.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
Of Chris Thompson
Sent: Monday, February 14, 2011 6:10 AM
How do you set up a BAQ to export on a schedule?
I have found the scheduled bit in System Agent but cant figure out how
it will
only export the baq I need on a regular basis.
From: "robertb_versa@... <mailto:robertb_versa%40yahoo.com> <mailto:robertb_versa%40yahoo.com> "
<robertb_versa@... <mailto:robertb_versa%40yahoo.com> <mailto:robertb_versa%40yahoo.com> >
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Sent: Wed, 5 August, 2009 14:56:55
Once you've tied a task (such as a BAQ export) to a recurring schedule
process
set, it will run per your schedule (as it runs on the server). You don't
have to
log in to a client session.
Rob Brown
--- Original Message ---
Sent:Tue 8/4/09 10:46 pm
To:"vantage@yahoogroups .com" <vantage@yahoogroups .com>
Subj:[Vantage] Re:Auto email reports
Hopefully, someone will have an answer. I was told by Epicor support a
year or
so ago that scheduled tasks happen upon user login. I had scheduled a
daily
report to run and the only way it ever would run is when I logged in. As
far as
emailing the report, you could use APM to automate that process.
I honestly hope there is a work around for this.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@2wtech. com<mailto:jason@2wtech. com>
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Chris Thompson
it will
process
have to
Rob Brown
year or
daily
far as
Jason Claggett
MCP #3856159
312.533.4033 x8039
