I have added $1.00 to the costing labor rates production field on the
resource group. My resources inherit from the groups. I am still not
using this process since I manually receive the job to stock and the
process only loks at what is complete through the operations so I
haven't played with this in quite awhile. I believe that the methods
that have already been set up will need to be rebalanced with the new
entries since they are not automatically updated when the resource group
is.
Kersten MacLennan
IT/ERP Analyst
Semrock
A Unit of IDEX Corporation
3625 Buffalo Road, Suite 6
Rochester, New York 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of opentoideas1
Sent: Wednesday, November 05, 2008 10:03 AM
Subject: [Vantage] Re: Auto Job CLosing / Completion
I have hit a wall with trying to get automated job completion/closing
to work.
where does the estimated operation cost come from?
it appears to be the value of labour associated with the operation
rather than the material cost that the system is looking for but I am
at a loss as to where this information is pulled from.
has anyone managed to get past this?
by entering a value against labour in resource group maintenance I
have managed to get jobs to complete in our test environment but still
with the error detailed below - which then close even prior to
shipping which is an issue!
by also entering a value into the Job tab under operation for quantity
per machine I have managed to get the job to complete without error
but it wont close.
at the moment I an stabbing wildly in the dark as the help files are
not very enlightening.
could anyone point me in the right direction?
Robert Brown <robertb_versa@...> wrote:
costing method would allow you to proceed.)
is.
Kersten MacLennan
IT/ERP Analyst
Semrock
585-594-7009
585-594-7095 fax
kmaclennan@...
it. Thank you
Of opentoideas1
to work.
but it wont close.
>your business operations in financial terms.
> The warning makes sense to me... ERP is all about tools to manage
>provide reporting against.
> Without an estimate, there can be no actual variance to it to
>received that result in this message? (I'm wondering if a different
> That said, I'm surprised it prevents you from proceeding.
> How have you set up the costing for the Parts on the jobs being
>the
> Rob
> --- On Mon, 7/14/08, Kersten MacLennan <kmaclennan@...> wrote:
> From: Kersten MacLennan <kmaclennan@...>
> Subject: RE: [Vantage] Auto Job CLosing / Completion
> Date: Monday, July 14, 2008, 11:02 AM
> I have played with it a little and have found the following:
> We do not use the auto receipt option to receive the job to stock. We
> manually process a receipt from manufacturing and the auto-close does
> not look at the receipt quantity only the quantity complete through
> operationsInstrumentation
> You must have an estimated dollar value on each operation whether you
> are really using it or not. Here is the exception message "Too much
> operation cost posted. No estimated operation cost available."
> All material must have an estimated value
> Kersten MacLennan
> IT/ERP Analyst
> Semrock, Inc.
> 3625 Buffalo Rd.,
> Suite 6
> Rochester, NY 14624
> 585-594-7009
> 585-594-7095 fax
> kmaclennan@semrock. com
>responsible
> for delivering this message to the intended recipient, you are herebyyou
> received this message in error, please reply to the message and deleteBehalf
> it. Thank you
> ____________ _________ _________ __
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
> Of Robert Brownon
> Sent: Sunday, July 13, 2008 12:24 PM
> To: vantage@yahoogroups .com
> Subject: Re: [Vantage] Auto Job CLosing / Completion
> Can't help you with this one as we are still in 'manual mode' with Job
> closing. We aren't that far from having gone live and reviewing the
> details of job closing exceptions is helping is correct inappropriate
> outliers in the legacy system data (and/or our assumptions of the
> Vantage representation of our business processes models) we massively
> converted & imported.
> Unless there are bugs in your version, I would assume the thresholds
> auto job closing work as advertised. You would want to (if using theoperations
> back-flush process) have that process running to 'complete' your jobs
> before running recurring scheduled closings.
> Rob Brown
> --- On Sun, 7/13/08, Lou Laird <loulrd@yahoo. com
> <mailto:loulrd% 40yahoo.com> > wrote:
> From: Lou Laird <loulrd@yahoo. com <mailto:loulrd% 40yahoo.com> >
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> Date: Sunday, July 13, 2008, 12:56 AM
> On the Auto Jobs complete/close.
> Do you have to run the complete first, then run close or can you just
> run the close, assuming it looks a the candidates, and processes them
> according to the thresholds set.
> ----- Original Message ----
> From: Mark Wagner <mjfw2003@yahoo. com>
> Sent: Friday, July 11, 2008 8:49:07 PM
> Backflush labor process will go and automatically report any
> on released jobs as complete, backflushing any material on thosewho
> operations where material is set to backflush. Works fine for those
> don't need to track operations and just want to use jobs for picklistsdefault
> and cost of goods sold
> Auto job complete/close is a little bit more touchy. It works but you
> need to be sure as to how you want to set your thresholds. If you use
> product groups and want to be selective on where you want to auto
> complete/close then tie your auto complete/close parameters to your
> product groups. If not set the auto complete/close parameters to
>[Non-text portions of this message have been removed]
> --- On Fri, 7/11/08, Lou Laird <loulrd@yahoo. com> wrote:
> From: Lou Laird <loulrd@yahoo. com>
> Subject: [Vantage] Auto Job CLosing / Completion
> Date: Friday, July 11, 2008, 5:32 PM
> Is anyone using these programs?
> If so, any problems/concerns?
> Also, backflush labor server process, anyone using, any concerns /
> problems.
> Thank you
