Oh and if you are planning on doing this with a lot of jobs (and these
jobs have a lot of subassemblies), let's talk off list.
I have a crystal report that will dump the info into excel and then
paste-insert the records in vista. To enter 400 records by hand would
take me about 4-5 hours. To run the report and insert into Vista takes
about 25 minutes.
And since you are on 6.1, I do not remember at all if you could do this.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Manasa Reddy
Sent: Friday, August 22, 2008 2:44 PM
Subject: RE: [Vantage] Re: Backflush, COS/Labor, MRP, PO Suggestions
Again sorry...it's Friday and I want out of here now! :)
I actually go to Labor Entry and do this.
Enter my date (today's date) and the backflush employee id.
Then new detail, enter the job number, subassembly and the last op,
usually only the last op will show up because it is labeled quantity
only.
Enter quantity (which is the required quantity for that subassembly on
that job) and save that record.
Repeat this is for all subassemblies on the job.
So if I have 10 subassemblies on a job, I have 10 records for that job.
This process actually backflushes all labor on that job for all ops.
Hope this is clear...let me know if it isn't. It took me 3 months to
get someone to help me out on this process last year! So I have 3
months of F%^& up jobs and bad GL numbers because of this process. And
actually I think it was Stephanie that helped clear up a lot of issues
we were having!
So test away, buddy!
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com>
P: 630-806-2000
F: 630-806-2001
Behalf
Of Ari Footlik
Sent: Friday, August 22, 2008 2:32 PM
So, just to be clear:
You use your dummy shop-employee to clock into MES, start work on the
job/op, you then basically immediately end work on the job/op, and then
running the backflush function does what it's supposed to?
Thanks again.
--Ari
Behalf
Of Manasa Reddy
Sent: Friday, August 22, 2008 2:14 PM
Yeah, basically...we don't have our guys clock in and out of jobs (long
story). So I have a dummy employee called Backflush. I use this to
create labor records manually through the Labor Entry program.
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Ari Footlik
Sent: Friday, August 22, 2008 2:11 PM
Manasa - what do you mean by "Create the Labor Records?" You mean go in
as a shop employee and clock into and out of the job?
--Ari
Behalf
Of Manasa Reddy
Sent: Friday, August 22, 2008 1:16 PM
And when you are in Job closing it will only ask about the material.
Ok, here are the steps you should take:
1) Create the job as stated before.
2) Create the labor records
3) Go to job closing and check the boxes.
Now everything should show as completed, ops and materials....
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Ari
Sent: Friday, August 22, 2008 12:07 PM
Subject: [Vantage] Re: Backflush, COS/Labor, MRP, PO Suggestions
Oh - wait - it isn't greyed-out, it just doesn't light-up until you
select the "Complete" box.
But, even after doing this and closing the job, the operations in
question did not show as "Closed" in Job Tracker. When I closed the
job, it asked if I was sure I wanted to backflush material, but didn't
mention labor at all.
--Ari
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
"Manasa Reddy" <manasa@> wrote:
about 25 minutes.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Manasa Reddy
only.
we were having!
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Ari Footlik
Thanks again.
--Ari
Behalf
Of Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Ari Footlik
--Ari
Behalf
Of Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Ari
--Ari
> Hmmm - the box to check-off "Backflush" in the "Job Completion" window
> is greyed out.
> BTW - this is all in v6 for the time being.
> > Now for the system to do this correctly, when you go to close a job,
> > check the backflush box first, hit save, then close or complete.
