Anyone knows how to get a BAQ report TableGUID? I would like to run the report in Report Builder. I am on 10.1.500. Thanks.
It should be in your System Activity Monitor on the “Reports” tab in a column all the way to the right. Also set the Archive Period to a Day in your Print Dialog (not sure when it will otherwise Archive that Table from SSRS DB)
@hkeric.wci is the answer.
Also, you may have to set the archive period to 1 day so that the data persists long enough so you can test it.
