BAQ - Summary Tables
My memory isn't perfect and it's been a couple years since we were on 8, but
I believe there was an issue with this. You may wanna check with support and
see if they sorted it out.
On Wed, Jun 8, 2011 at 12:10 PM, mustardbuzzards <
c.edwards@...> wrote:
> Vantage 8.03.405A
> Table Project
> UD06 - Summarized
> UD19 - Summarized
> Using the project table as my base...I can get the BAQ to work when working
> with either summary table. It does not report correctly when I try to use
> both summary tables. The calculated fields return zero, when it should not.
> Is it possible to use two summary table is this version of Vantage?
> Thanks
> Clinton
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Vantage 8.03.405A
Table Project
UD06 - Summarized
UD19 - Summarized
Using the project table as my base...I can get the BAQ to work when working with either summary table. It does not report correctly when I try to use both summary tables. The calculated fields return zero, when it should not.
Clinton
