I created a BAQ with a date column, I use a suggested format which is yyyy-MM-dd. When I run my BAQ, the date column display the data correctly matching the format I use. When I use my BAQ in a dashboard, the format of the date column become YYYY-MM-DD which display ma data incorrectly, any though???
Customize your dashboard, and click on your grid. In Properties there is a columns list. Click the drop down and find the field you want to change the format for.
I hope this helps!
Nate
