Aaron,
How difficult would it be to setup a system? Say for inventory movement and data collection? This is for your Vantage "Expert" with no bar coding experience.
Eric L. Tyira
Tamglass Tempering Systems
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
hoyt@...]
Sent: Monday, September 13, 2004 11:08 AM
To:
vantage@yahoogroups.com
Subject: RE: [Vantage] Bar code scanner info
Todd,
I would have to disagree with you on one point.
I have found that if I force employees to scan "slowly" they type
instead. This brings in error after error.
Having all the information in one barcode makes it easier for the
employee to do it right then wrong, and I have seen greatly reduced
errors using that technique. I find the number of errors due to warning
messages are next to none, and here are limited to the job being closed
and they are still trying to work on it. They call me and say...I was
scanning the barcode for job XXXX and it keeps leaving me with numbers
where I they don't belong. I go in and reopen the job and they try
again, and all is well.
It comes down to a philosophy...If I make it easier to do right than
wrong, they will. Each time I come across data being entered wrong, I
find a way to make it easier to do it right. Also, the average person
on the floor here tends to "just want to do their job" and does not want
to "waste time" in front of the computer. I give a solution that has
keeps their computer transaction time to under 10 seconds and everyone
is happy.
Again, these are just my thoughts, and everyone is welcome to their
opinion.
PS, I love the Metrologic MS5900 Voyager series scanners. They can be
used with a trigger (code gate) or put in their stand and used as
proximity scanners. And they are relatively cheap, but reliable. I am
using several USB "plug and play" units right now, and a "keyboard
pass-through" as well. They work great.
Just another thought.
Aaron Hoyt
Hittite Microwave
caugheyt@...]
Sent: Friday, September 10, 2004 1:32 PM
To:
I have experimented with muli-field combos but for philisophical
reasons have resisted implmenting. I WANT the users to scan slowly,
carefully and visually verify what has been entered (just as when
typing) while also taking note of any warnings or error messages. The
slight loss of efficiency is more than made up for by fewer data errors.
The programming for mutl-field entry that I have done has been
in the barcodes themselves with appropriate special characters embedded
so that several fields are in one long bar - which brings the
recollection that the scanner has to be "programmed" for extended-ASCII
by scanning a special barcode in the user manual, if it was not already
set by default. All the actual barcodes themselves I have created in
Crystal (modified Job Traveler) or Report Builder (soon to be Crystal
too :( ). They are printed mostly on laser printers and use the
Dataworks-39 (code 39 bar code format) font. So in large part what you
do with bar coding depends a lot more on the printing side than the
scanner side. Using the "out of the box" bar codes in Vantage would be
almost zero work (just print, plug the scanner into the keyboard line
and scan away).
If you are going to get into printing labels for inventory then
things get a little more complicated and you would probably need a label
printer. We've been very happy with our Zebra Z4M printer printing to
4" X 6" direct thermal labels. No special programming on the printer
required - just treat it like any laser printer. All our shipping
labels are done with RB (for now). Very simple.
-Todd C.
eric.tyira@...]
Sent: Friday, September 10, 2004 10:17 AM
To:
Thanks for the info.
When you scan the barcode, does it propagate only one field, or
are they programmed to fill in multiple fields? And who does the
programming?
I've never seen any barcode system up close, so please forgive
my ignorance.
Thanks.
Eric L. Tyira
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
caugheyt@...]
Sent: Friday, September 10, 2004 11:05 AM
To:
I love our ImageTeam 3800 scanners. Very durable, plug-n-play
easy. Just plug into PC keyboard line and start scanning. In four years
never had a problem with one. Mostly used to let data collection users
avoid typing job traveler info but we've never made it mandatory other
than posting employee clock number bar code sheets at specific PCs to
encourage people to use the one closest to where they work (rather than
closest to the exit). One additional use....scanning the UPS bar code
(regular not 2-D) for the tracking number dirctly into the field in
customer shipment screen. No typos and it is available for customer
service to use to call up UPS site. Scans FedEx bar code too so would
work for them as well.
-Todd C.
eric.tyira@...]
Sent: Friday, September 10, 2004 9:49 AM
To: Vantage User Group (E-mail)
Subject: [Vantage] Bar code scanner info
6.00.521
Hey all. We are looking into a bar code scanner for our system.
Probably for inventory transactions and maybe labor transactions. I'm
gussing the ImageTeam 3800 (hand held) and 3900 (fixed mount) from HHP
(Hand Held Products).
Can anyone who has a bar code scanning system please comment on
how well they work? Are they worth it? Any problems/solutions
implementing? Anything?
Any input would be appreciated.
Thanks.
Eric L. Tyira
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You must have already linked your email address to a yahoo id to enable
access. )
(1) To access the Files Section of our Yahoo!Group for Report
Builder and Crystal Reports and other 'goodies', please goto:
Yahoo! Groups Sponsor
ADVERTISEMENT
http://us.ard.yahoo.com/SIG=129is2oji/M=295196.4901138.6071305.3001176/D
=groups/S=1705007183:HM/EXP=1094914561/A=2128215/R=0/SIG=10se96mf6/*http
://companion.yahoo.com> click here
http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups
/S=:HM/A=2128215/rand=755321455>
_____
Yahoo! Groups Links
<mailto:
vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service <
http://docs.yahoo.com/info/terms/> .
access. )
ADVERTISEMENT
http://us.ard.yahoo.com/SIG=1293i7o9e/M=298184.5285298.6392945.3001176/D
=groups/S=1705007183:HM/EXP=1094915116/A=2319498/R=0/SIG=11thfntfp/*http
://www.netflix.com/Default?mqso=60185352
D=groups/S=1705007183:HM/EXP=1094915116/A=2319498/R=0/SIG=11thfntfp/*htt
p://www.netflix.com/Default?mqso=60185352&partid=5285298>
&partid=5285298> click here
http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups
/S=:HM/A=2319498/rand=719878235>
_____
Yahoo! Groups Links
<mailto:
Terms of <
http://docs.yahoo.com/info/terms/> Service.
access. )
ADVERTISEMENT
http://us.ard.yahoo.com/SIG=1294oiuld/M=295196.4901138.6071305.3001176/
D=groups/S=1705007183:HM/EXP=1094916058/A=2128215/R=0/SIG=10se96mf6/*htt
p://companion.yahoo.com> click here
s/S=:HM/A=2128215/rand=535444679>
_____
Yahoo! Groups Links
<mailto:
of Service <
access. )
ADVERTISEMENT
click here
http://us.ard.yahoo.com/SIG=129blsoa8/M=298184.5285298.6392945.3001176/
D=groups/S=1705007183:HM/EXP=1094924010/A=2319498/R=0/SIG=11thfntfp/*htt
s/S=:HM/A=2319498/rand=211374969>
Yahoo! Groups Links
<mailto:
of Service <
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto:
ADVERTISEMENT
http://us.ard.yahoo.com/SIG=1292m5ui4/M=298184.5285298.6392945.3001176/D=groups/S=1705007183:HM/EXP=1095189099/A=2319498/R=0/SIG=11thfntfp/*http://www.netflix.com/Default?mqso=60185352&partid=5285298> click here
http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups/S=:HM/A=2319498/rand=672069091>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of <
