Barcode On Traveler Not Printing with Crystal Runtime
Thank you all for the responses.
Brian's response was the one that worked. We had the font on the machines, I just needed to open them to get it to work.
Thanks again,
Eric
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> I've noticed sometimes you have to actually open the TTF file in
> Windows and then the barcode font will start working.
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> Picometrix
> bspolarich@... ~ 734-864-5618 ~
> www.advancedphotonix.com
> Of Rob Bucek
> Sent: Monday, March 23, 2009 12:05 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Barcode On Traveler Not Printing with Crystal
> Runtime
> I agree first check to see if the font is installed in the windows
> directory (DWBAR39.TTF). Weve also experienced problems with the
> Version of crystal runtime. Ive found the most consistent success
> across varied platforms to be CrystalReportsXIR2RT.msi. I uninstall any
> .net versions and just install that one. Ive yet to have any problems
> running in this fashion.
> Rob Bucek
> Manufacturing Engineer
> PH: 715-284-5376 ext 311
> FAX: 715-284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site)
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> Of Ari Footlik
> Sent: Monday, March 23, 2009 10:53 AM
> Runtime
> Are you sure your barcode-font is actually installed on the other
> machines? We had to manually add the font to each workstation.
> --Ari
> Behalf
> Of homestyleindustries
> Sent: Monday, March 23, 2009 10:18 AM
> Subject: [Vantage] Barcode On Traveler Not Printing with Crystal Runtime
> Hi all,
> I created a custom barcode for our job traveler that holds all the
> information to get through the "Start Production Activity" process in
> MES. It will fill in Job #, Assembly, and Operation #. The problem I am
> having is I am the only one that can print the barcodes. They will not
> print on any machine that is only running the runtime version of Crystal
> Reports. The only time the barcodes will print is when one of the three
> computers with a full Crystal license prints the traveler. Does anyone
> know of a way to get the runtime version to print a custom barcode like
> that on 8.03.404b?
> Thanks in advance.
> Eric
> Home-Style Industries
Hi all,
I created a custom barcode for our job traveler that holds all the information to get through the "Start Production Activity" process in MES. It will fill in Job #, Assembly, and Operation #. The problem I am having is I am the only one that can print the barcodes. They will not print on any machine that is only running the runtime version of Crystal Reports. The only time the barcodes will print is when one of the three computers with a full Crystal license prints the traveler. Does anyone know of a way to get the runtime version to print a custom barcode like that on 8.03.404b?
Thanks in advance.
Eric
--Ari
Hi all,
that on 8.03.404b?
Thanks in advance.
Eric
Are you getting text instead of a barcode where the barcode should be?
Try copying dwbar39.ttf from one that is working to C:\Windows\Fonts
folder of one that isn't working.
Ken
Sent: Monday, March 23, 2009 9:18 AM
Hi all,
that on 8.03.404b?
Thanks in advance.
Eric
Rob Bucek
FAX: 715-284-4084
Of Ari Footlik
Runtime
--Ari
Behalf
Hi all,
that on 8.03.404b?
Thanks in advance.
Eric
Barcode font needs to be installed. My guess it's either not on the server
or on the client or both.
You might be able to copy the font out of the font directory
homestyleindustries
Sent: Monday, March 23, 2009 11:18 AM
Hi all,
Thanks in advance.
Eric
Picometrix
Of Rob Bucek
Runtime
Rob Bucek
FAX: 715-284-4084
Behalf
Of Ari Footlik
Runtime
--Ari
Behalf
Hi all,
that on 8.03.404b?
Thanks in advance.
Eric
