Hi all,
Something completely abrupt happened last night - all 3 of our integrations just stopped working. The only error message that I get is that the printer stalled after bartender waits for about 30 minutes, I get the below message:
Failed to run action ‘Print Command Script’. Details: The print job for document ‘\<>\BARTENDER\LabelDesigns\Receipt_Label\ReceiptLabel.btw’ and printer ‘\<>\<>’ has stalled. A restart will be attempted. If the problem persists verify that the printer is online, able to process the print job, and the network connection (if present) is valid. If the print job is known to take a significant amount of time to print consider increasing the print scheduler’s unresponsive job timeout. See Seagull’s online knowledge base at support.seagullscientific.com for more details.
We didn’t change anything but all of the integrations stopped working! We just installed Sophos endpoint agent on all of the servers, but that shouldn’t have impacted anything, because from the server where the integration file is hosted and running, i tried to a) ping the print server and it worked b) install the label printer directly on that server using the UNC and again it worked c) do a test print via the print server as well as the server hosting bartender and it worked d) opened bartender label designer and sent the print command to the same printer via the UNC and it worked!
Let’s summarize the facts:
Label opens manually.
Label prints manually.
Data file is valid, all text within the data file is valid and how it was supposed to be .
Printer works.
Printer queue never receives a job from the integration.
Integration detects the file.
Integration renames the file.
Integration executes the Print Command Script.
All 3 integrations stopped working at the same time.
Started overnight with no intentional changes.
I have tried restarting all the services listed under Windows Services (Bartender system services, integration services, printer scheduler, windows print spooler)
I have tried changing the logon account in bartender integration service - changed it from local account to my account that was able to print on the label printer
Screenshot here
I’m at a loss. What do I do to fix this?
