Blanket PO Customization - Delete Line Error
I am new to E10, and in particular C#, so I am asking for some input on getting a customization to work for POs.
I have created a data directive to essentially treat the Release 1 of a PO like Release 1 of a Sales Order when Lock Line Quantity is set. I want to add more PO releases but keep the line quantity the same. I do that by adjusting Release 1 up/down as new releases are added/updated/deleted.
It works well except for when I try to delete the line. Epicor comes back with an error stating that at least one release must exist, even though one or more do.
Below is the data directive I have written:
// Blanket PO 7/26/2019 MLW
// Blanket PO functionality - treating like a locked line and master release for Release 1.
// Subsequent releases will decrement/increment Release 1, but leave the Line quantity the same.
//fetch PO releases
var NewRel = (from row in ttPORel
              select row).ToList();
foreach (var ttPORelRow in NewRel)
    decimal Rel1Qty = decimal.Zero;
    decimal XRel1Qty = decimal.Zero;
    decimal OpenPerc = decimal.Zero;
    decimal LineQty = decimal.Zero;
    MessageText = "";
    Balance = 0;
    var PORel = (from PORel_Row in Db.PORel
             where PORel_Row.Company == ttPORelRow.Company && PORel_Row.PONum == ttPORelRow.PONum && PORel_Row.POLine == ttPORelRow.POLine && PORel_Row.PORelNum == 1
             select PORel_Row).FirstOrDefault();
    // Adjust Release 1 based on action to other releases
    if (PORel != null)
        if (string.Equals(ttPORelRow.RowMod, IceRow.ROWSTATE_ADDED, StringComparison.OrdinalIgnoreCase) && ttPORelRow.PORelNum != 1)
            Rel1Qty = PORel.RelQty - ttPORelRow.RelQty;
            XRel1Qty = PORel.XRelQty - ttPORelRow.XRelQty;
            if (Rel1Qty < 0)
                CallContext.Current.ExceptionManager.AddBLException("Too large a quantity has been entered. Review the first release to see balance open on blanket.");
            else
                PORel.RelQty = Rel1Qty;
                PORel.XRelQty = XRel1Qty;
        if (string.Equals(ttPORelRow.RowMod, IceRow.ROWSTATE_UPDATED, StringComparison.OrdinalIgnoreCase) && ttPORelRow.PORelNum != 1)
            Rel1Qty = PORel.RelQty - (ttPORelRow.RelQty - ttPORelRow.ReqChgQty);
            XRel1Qty = PORel.XRelQty - (ttPORelRow.XRelQty - (ttPORelRow.XRelQty / ttPORelRow.RelQty * ttPORelRow.ReqChgQty));
            if (Rel1Qty < 0)
            else
        if (string.Equals(ttPORelRow.RowMod, IceRow.ROWSTATE_DELETED, StringComparison.OrdinalIgnoreCase) && ttPORelRow.PORelNum != 1)
            Rel1Qty = PORel.RelQty + ttPORelRow.RelQty;
            XRel1Qty = PORel.XRelQty + ttPORelRow.XRelQty;
            if (Rel1Qty < 0)
            else
        Balance = PORel.RelQty;
    Rel1Qty = 0;
    XRel1Qty = 0;
    OpenPerc = 0;
    LineQty = 0;
You are adjusting Release 1 directly instead of using the Business Object. I would offer that you change to that instead. This type of code will start causing issues in other tables that get updated when you change your PO. Also, you may want to look around at what others have done. It may save you time:
