Just did a hot-swap on the code to use some of Joses old recommendations on the same post. I get the following error:
Server Side Exception
BPM runtime caught an unexpected exception of ‘EntityException’ type.
See more info in the Inner Exception section of Exception Details.
Error Detail
Correlation ID: 752e7d57-0fd4-4758-b5a6-733e6c159a3e
Description: BPM runtime caught an unexpected exception of ‘EntityException’ type.
Inner Exception: The partner transaction manager has disabled its support for remote/network transactions. (Exception from HRESULT: 0x8004D025)
Program: EntityFramework.dll
Method: EnlistTransaction
Original Exception Type: EntityException
Framework Method: SaveChanges
Framework Line Number: 352
Framework Column Number: 17
Framework Source: SaveChanges at offset 404 in file:line:column C:_Releases\ICE\ICE4.1.100.0\Source\Server\Framework\Epicor.System\Data\IceDataContext.cs:352:17
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet dataSets)
at Erp.Proxy.BO.SalesOrderImpl.MasterUpdate(Boolean lCheckForOrderChangedMsg, Boolean lcheckForResponse, String cTableName, Int32 iCustNum, Int32 iOrderNum, Boolean lweLicensed, Boolean& lContinue, String& cResponseMsg, String& cCreditShipAction, String& cDisplayMsg, String& cCompliantMsg, String& cResponseMsgOrdRel, String& cAgingMessage, SalesOrderDataSet ds)
at Erp.Adapters.SalesOrderAdapter.MasterUpdate(Boolean lCheckForOrderChangedMsg, Boolean lcheckForResponse, String cTableName, Int32 iCustNum, Int32 iOrderNum, Boolean lweLicensed, Boolean& lContinue, String& cResponseMsg, String& cCreditShipAction, String& cDisplayMsg, String& cCompliantMsg, String& cResponseMsgOrdRel, String& cAgingMessage)
at Erp.UI.App.SalesOrderEntry.Transaction.Update()
Inner Exception
The underlying provider failed on EnlistTransaction.
Inner Exception
Inner Exception
using (var txScope = IceContext.CreateDefaultTransactionScope())
foreach(var UD01 in (from row in Db.UD01 select row))
Db.UD01.Delete(UD01);
Db.Validate();
txScope.Complete();
/* Find current record in dataset */
using(var UD01svc = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.UD01SvcContract>(Db))
foreach (var recOrderHed in (from row in Db.OrderHed where row.OpenOrder == true select row))
/* Find all lines for Order */
foreach (var recOrdDetail in (from row in Db.OrderDtl where row.Company == Session.CompanyID && row.OrderNum == recOrderHed.OrderNum && row.OpenLine == true select row))
foreach (var recOrdRel in (from row in Db.OrderRel where row.Company == Session.CompanyID && row.OrderNum == recOrdDetail.OrderNum && row.OrderLine == recOrdDetail.OrderLine && row.OpenRelease == true select row))
/* Update UD Record */
UD01Tableset ds = new UD01Tableset();
UD01svc.GetaNewUD01(ref ds);
ds.UD01[0].Company = Session.CompanyID;
ds.UD01[0].Number01 = recOrdRel.OrderNum;
ds.UD01[0].Number02 = recOrdRel.OrderLine;
ds.UD01[0].Number03 = recOrdRel.OrderRelNum;
ds.UD01[0].Date01 = recOrdRel.ReqDate;
UD01svc.Update(ref ds);
Does anyone have an idea what could be causing this?
