Post-Process.
Travis L. McMullen
Senior Information Systems Support Technician
ComSonics, Inc.
Harrisonburg, VA 22801
Phone: 540-434-5965 x1274
Toll Free: 1-800-336-9681 x1274
Mobile: 540-435-1920
Fax: 540-434-9847
E-Mail: tmcmullen@...
Travis L. McMullen
ComSonics, Inc.
Fax: 540-434-9847
On Thu, Aug 18, 2011 at 6:41 PM, Ephraim Feldman <effgroups@...>wrote:
> Did you do the BPM in pre-process or in post-process?
> On Wed, Aug 17, 2011 at 11:44 AM, McMullen, Travis
> <tmcmullen@...>wrote:
> > I checked the appserver logs and there were no errors, it's just not
> > executing the code. If it is executing the code, something in the Issue
> > Material screen is changing the value back.
> > Travis L. McMullen
> > ComSonics, Inc.
> > Fax: 540-434-9847
> > On Wed, Aug 17, 2011 at 10:56 AM, reptcon <cheins@...> wrote:
> > > Travis, is the (From?)BinNum valid in the warehouse you are changing
> to?
> > If
> > > not the BO might reject it. You could check your appserver log to see
> if
> > > there are any error message. They don't always ripple back to the
> client
> > > session.
> > > --- In vantage@yahoogroups.com, "McMullen, Travis" <tmcmullen@...>
> > wrote:
> > > > An extra note. I know the OnChangePartNum BPM is being triggered
> > because
> > > I
> > > > added information messages that are appearing after the part number
> is
> > > > entered.
> > > > Travis L. McMullen
> > > > ComSonics, Inc.
> > > > Fax: 540-434-9847
> > > > On Tue, Aug 16, 2011 at 2:41 PM, McMullen, Travis
> > > > > The only conditions that I am using are related to the User ID that
> > is
> > > > > calling the method. The code is as follows.
> > > > > find first ttIssueReturn where ttIssueReturn.RowMod = "U":U
> > > > > no-lock no-error.
> > > > > if available ttIssueReturn and ttissuereturn.ToJobSeq = 10 then do:
> > > > > find first JobHead where JobHead.Company = Cur-COMP and
> > JobHead.JobNum
> > > > > ttIssueReturn.ToJobNum
> > > > > no-lock no-error.
> > > > > if available JobHead and JobHead.ProdCode = "101" then
> > > > > ttIssueReturn.FromWarehousecode = "VAMB-101".
> > > > > if available JobHead and JobHead.Prodcode = "102" then
> > > > > ttIssueReturn.FromWarehouseCode = "VAMB-102".
> > > > > if available JobHead and JobHead.Prodcode = "103" then
> > > > > ttIssueReturn.FromWarehouseCode = "VAMB-103".
> > > > > if available JobHead and JobHead.Prodcode = "105" then
> > > > > ttIssueReturn.FromWarehouseCode = "VAMB-105".
> > > > > if available JobHead and JobHead.Prodcode = "107" then
> > > > > ttIssueReturn.FromWarehouseCode = "VAMB-107".
> > > > > if available JobHead and JobHead.Prodcode = "110" then
> > > > > ttIssueReturn.FromWarehouseCode = "VAMB-110".
> > > > > if available JobHead and JobHead.ProdCode = "250" then
> > > > > ttIssueReturn.FromWarehouseCode = "VAMB-250".
> > > > > end.
> > > > > Else if available ttIssueReturn and ttIssueReturn.ToJobSeq = 30 or
> > > > > ttIssueReturn.tojobseq = 40 or ttIssueReturn.ToJobSeq = 60 then do:
> > > > > find first JobHead where JobHead.Company = CUR-COMP and
> > JobHead.JobNum
> > > > > no-lock no-error.
> > > > > end.
> > > > > Travis L. McMullen
> > > > > ComSonics, Inc.
> > > > > Fax: 540-434-9847
> > > > > On Tue, Aug 16, 2011 at 2:32 PM, Waffqle <waffqle@...> wrote:
> > > > >> What's your code look like? Do you have any conditions on your
> BPM?
> > > > >> On Tue, Aug 16, 2011 at 2:27 PM, subzerovi <tmcmullen@...>
> > > > >> wrote:
> > > > >> > I am attempting to create a BPM in the Issue Material screen
> that
> > > will
> > > > >> > change the warehouse we are issuing from based on the Product
> Code
> > > of
> > > > >> the
> > > > >> > Job. I have working code, however, I want to place it in the
> > > > >> > IssueReturn.OnChangePartNum Business Method.
> > > > >> > The code doesn't seem to work on this business method even
> though
> > it
> > > > >> > validates ok. It seems that the Issue Material screen has some
> > logic
> > > > >> behind
> > > > >> > it that will not allow my BPM to change the warehouse field. I
> had
> > > to
> > > > >> put my
> > > > >> > code in the IssueReturn.OnChangeFromBin Business Method in order
> > for
> > > it
> > > > >> to
> > > > >> > work.
> > > > >> > While my users were testing this, they found an issue that I
> need
> > to
> > > > >> find a
> > > > >> > way to resolve. However, if I could put my code in the
> > > OnChangePartNum,
> > > > >> I'm
> > > > >> > pretty sure it would no longer be an issue.
> > > > >> > Does anyone know how I can attach this BPM to the Business
> Method
> > > and
> > > > >> make
> > > > >> > it work?
> > > > >> *Waffqle Driggers*
> > > > >> *High End Dev, System Design, Profit Drinking
> > > > >> *:: 904.962.2887*
> > > > >> *:: waffqle@...*
> > > > >> *:: NO FAXES*
> > > > >> [Non-text portions of this message have been removed]
> > > > >> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > must
> > > > >> have already linked your email address to a yahoo id to enable
> > access.
> > > > >> (1) To access the Files Section of our Yahoo!Group for Report
> > Builder
> > > and
> > > > >> Crystal Reports and other 'goodies', please goto:
> > > > >> http://groups.yahoo.com/group/vantage/files/.
> > > > >> (2) To search through old msg's goto:
> > > > >> http://groups.yahoo.com/group/vantage/messages
> > > > >> (3) To view links to Vendors that provide Vantage services goto:
> > > > >> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
