Its been a while but as far as I can remember BPMs do carry from 8 to 9 and to 10 though in 10 they have to be manually converted. However if that didn't happen you can easily export / import them into 8- 9 and then they'll carry to 10 just fine.
Thinking about it now though if you are using the DUU it may very well not carry the BPMs to 9
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Mon, Apr 27, 2015 at 9:34 AM, chan213419@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Hmm so they have to be manually export/imported from 8 to 9 it looks like. Then from there, perhaps again manually from 9 to 10? You are correct, you do have to convert the ABL to C#, but I was hoping the BPMs that were done without code (using the designer instead) would just be brought up. I didn't expect these BPMs to work correctly coming from 8 to 10, but surely they would at least be available for adjustment.</p><div><br></div><div>If someone upgraded from 8 to 9 recently. Did your BPMs carry over to 9, or did you have to manually export/import?</div><p></p> </div> <div style="color:#fff;min-height:0;"></div>
