We have a project that when we run Build Project Analysis the process hangs and won’t complete. We found two jobs out of the 12 linked to the project that, when removed from the project, the Build Project Analysis completes. There is nothing apparent as to why removing these two jobs allows the process to run. We noticed on one job that you cannot reschedule or unengineer it, it just hangs while the other job we can.
Anyone else running Build Project Analysis see this happen?
It just locks up. No error. I did find some labor detail dates where the AsofDate and AsofSeq values were null for the 2 jobs that were causing the problem. We fixed those through SQL in our test database and reran the Build Analysis but are still getting an error. It seems to be pointing towards a job header date but the error is pretty vague
