<div id="ygrps-yiv-2001629350yiv3822241477ygrp-text">
<div></div><div>Vantage 8.03.405</div><div><br clear="none"></div><div>Steve,</div><div><br clear="none"></div><div>I just had this same issue. I am assuming you first checked Part Tracker / On-Hand; then Part Transaction History; then Stock Status Report... all of them showing zero on-hand.</div><div><br clear="none"></div><div>I found my on-hand in Part Advisor / On-Hand. Somehow I had an on-hand quantity in an empty bin (empty defined as NO Bin ID). I had to get a 1-off Fix from Epicor. Once the fix was run, the on-hand quantity showed up everywhere, however the Bin ID was still blank (not an issue). I was then able to make the necessary adjustments to correct this inventory to zero and then mark my part as inactive.</div><div><br clear="none"></div><div>You will also want to run the conversion to fix up your allocations and everything else.</div><div><br clear="none"></div><div>HTH!</div><div><br clear="none"></div><div>Jeff<br clear="none" class="ygrps-yiv-2001629350yiv3822241477yui-cursor"></div>
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mkp #ygrps-yiv-2001629350yiv3822241477hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mkp #ygrps-yiv-2001629350yiv3822241477ads {
margin-bottom:10px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mkp .ygrps-yiv-2001629350yiv3822241477ad {
padding:0 0;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mkp .ygrps-yiv-2001629350yiv3822241477ad p {
margin:0;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mkp .ygrps-yiv-2001629350yiv3822241477ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-sponsor #ygrps-yiv-2001629350yiv3822241477ygrp-lc {
font-family:Arial;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-sponsor #ygrps-yiv-2001629350yiv3822241477ygrp-lc #ygrps-yiv-2001629350yiv3822241477hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-sponsor #ygrps-yiv-2001629350yiv3822241477ygrp-lc .ygrps-yiv-2001629350yiv3822241477ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477activity span {
font-weight:700;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477activity span span {
color:#ff7900;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477activity span .ygrps-yiv-2001629350yiv3822241477underline {
text-decoration:underline;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 .ygrps-yiv-2001629350yiv3822241477attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 .ygrps-yiv-2001629350yiv3822241477attach div a {
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 .ygrps-yiv-2001629350yiv3822241477attach img {
border:none;padding-right:5px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 .ygrps-yiv-2001629350yiv3822241477attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 .ygrps-yiv-2001629350yiv3822241477attach label a {
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 .ygrps-yiv-2001629350yiv3822241477bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 .ygrps-yiv-2001629350yiv3822241477bold a {
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 dd.ygrps-yiv-2001629350yiv3822241477last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 dd.ygrps-yiv-2001629350yiv3822241477last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 dd.ygrps-yiv-2001629350yiv3822241477last p span.ygrps-yiv-2001629350yiv3822241477yshortcuts {
margin-right:0;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div.ygrps-yiv-2001629350yiv3822241477attach-table div div a {
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div.ygrps-yiv-2001629350yiv3822241477attach-table {
width:400px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div.ygrps-yiv-2001629350yiv3822241477file-title a, #ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div.ygrps-yiv-2001629350yiv3822241477file-title a:active, #ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div.ygrps-yiv-2001629350yiv3822241477file-title a:hover, #ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div.ygrps-yiv-2001629350yiv3822241477file-title a:visited {
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div.ygrps-yiv-2001629350yiv3822241477photo-title a, #ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div.ygrps-yiv-2001629350yiv3822241477photo-title a:active, #ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div.ygrps-yiv-2001629350yiv3822241477photo-title a:hover, #ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div.ygrps-yiv-2001629350yiv3822241477photo-title a:visited {
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 div#ygrps-yiv-2001629350yiv3822241477ygrp-mlmsg #ygrps-yiv-2001629350yiv3822241477ygrp-msg p a span.ygrps-yiv-2001629350yiv3822241477yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 .ygrps-yiv-2001629350yiv3822241477green {
color:#628c2a;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 .ygrps-yiv-2001629350yiv3822241477MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 o {
font-size:0;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477photos div {
float:left;width:72px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477reco-category {
font-size:77%;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477reco-desc {
font-size:77%;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 .ygrps-yiv-2001629350yiv3822241477replbq {
margin:4px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mlmsg select, #ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 input, #ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mlmsg pre, #ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 code {
font:115% monospace;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-mlmsg #ygrps-yiv-2001629350yiv3822241477logo {
padding-bottom:10px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-msg p#ygrps-yiv-2001629350yiv3822241477attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-reco #ygrps-yiv-2001629350yiv3822241477reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-sponsor #ygrps-yiv-2001629350yiv3822241477ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-sponsor #ygrps-yiv-2001629350yiv3822241477ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-sponsor #ygrps-yiv-2001629350yiv3822241477ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-text {
font-family:Georgia;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-text tt {
font-size:120%;}
#ygrps-yiv-2001629350 #ygrps-yiv-2001629350yiv3822241477 #ygrps-yiv-2001629350yiv3822241477ygrp-vital ul li:last-child {
border-right:none !important;}
