Epicor 9.05 - Inactivate Operations
Following Mark’s examps I do the same but I also made a Z_Inactive Resources, resource group, then I moved the ‘inactive’ resource to that group using the button Move Resource on the resource tab in addition to checking it inactive.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Monday, October 27, 2014 2:42 PM
Subject: Re: [Vantage] Epicor 9.05 - Inactivate Operations
Yes. And remember you can inactivate a resource but check to make sure you do not have that used in any existing MOMs. If you do before you inactive those resources make sure to make changes to any of those methods first. It can cause problems later on in labor reporting, scheduling, etc
On Monday, October 27, 2014 3:18 PM, "Kimberley White faepigrl@... [vantage]" <vantage@yahoogroups.com> wrote:
Agh...Yes, good idea. I am guessing I could do that anywhere I need to "Inactive" something but doesn't have a check box.
On Monday, October 27, 2014 3:09 PM, "Mark Wagner mjfw2003@... [vantage]" <vantage@yahoogroups.com> wrote:
Kim you can't make them inactive but you could put a Z in front of the description, write a quick search and make it default for the operations search, and just dont allow anything with a z in front of the description to be searchabl
On Monday, October 27, 2014 2:49 PM, "Kimberley White faepigrl@... [vantage]" <vantage@yahoogroups.com> wrote:
Is there a way to make Operations Inactive? They are attached to old jobs so I can't delete them.
Thanks Kim
Thanks Kim
<div id="ygrps-yiv-968300786yiv2237006643ygrp-text">
  <div></div><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"><div>Is there a way to make Operations Inactive?&nbsp; They are attached to old jobs so I can&#39;t delete them.</div><div><br></div><div>Thanks Kim</div></div>
</div>
<div id="ygrps-yiv-1433585310yiv0927968934ygrp-text">
  <div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;background-color:rgb(255, 255, 255);"><div id="ygrps-yiv-1433585310yiv0927968934yui_3_16_0_1_1414419289435_115913" dir="ltr"><span>Kim you can&#39;t make them inactive but you could put a Z in front of the description, write a quick search and make it default for the operations search, and just dont allow anything with a z in front of the description to be searchabl</span></div> <div class="ygrps-yiv-1433585310yiv0927968934qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-1433585310yiv0927968934yqt4173023489" id="ygrps-yiv-1433585310yiv0927968934yqt04331"><div class="ygrps-yiv-1433585310yiv0927968934yahoo_quoted" style="display:block;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div
dir=“ltr”> On Monday, October 27, 2014 2:49 PM, "Kimberley White faepigrl@… [vantage]" <vantage@yahoogroups.com> wrote:
  <div></div><div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;background-color:rgb(255, 255, 255);"><div>Is there a way to make Operations Inactive?&nbsp; They are attached to old jobs so I can&#39;t delete them.</div><div><br clear="none"></div><div>Thanks Kim</div></div>
</div>
</div>
<div class="ygrps-yiv-1433585310yiv0927968934yqt4173023489" id="ygrps-yiv-1433585310yiv0927968934yqt29716"><div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934 -- #ygrps-yiv-1433585310yiv0927968934ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mkp #ygrps-yiv-1433585310yiv0927968934hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mkp #ygrps-yiv-1433585310yiv0927968934ads {
margin-bottom:10px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mkp .ygrps-yiv-1433585310yiv0927968934ad {
padding:0 0;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mkp .ygrps-yiv-1433585310yiv0927968934ad p {
margin:0;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mkp .ygrps-yiv-1433585310yiv0927968934ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-sponsor #ygrps-yiv-1433585310yiv0927968934ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-sponsor #ygrps-yiv-1433585310yiv0927968934ygrp-lc #ygrps-yiv-1433585310yiv0927968934hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-sponsor #ygrps-yiv-1433585310yiv0927968934ygrp-lc .ygrps-yiv-1433585310yiv0927968934ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934activity span {
font-weight:700;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934activity span span {
color:#ff7900;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934activity span .ygrps-yiv-1433585310yiv0927968934underline {
text-decoration:underline;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 .ygrps-yiv-1433585310yiv0927968934attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 .ygrps-yiv-1433585310yiv0927968934attach div a {
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 .ygrps-yiv-1433585310yiv0927968934attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 .ygrps-yiv-1433585310yiv0927968934attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 .ygrps-yiv-1433585310yiv0927968934attach label a {
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 .ygrps-yiv-1433585310yiv0927968934bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 .ygrps-yiv-1433585310yiv0927968934bold a {
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 dd.ygrps-yiv-1433585310yiv0927968934last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 dd.ygrps-yiv-1433585310yiv0927968934last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 dd.ygrps-yiv-1433585310yiv0927968934last p span.ygrps-yiv-1433585310yiv0927968934yshortcuts {
margin-right:0;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div.ygrps-yiv-1433585310yiv0927968934attach-table div div a {
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div.ygrps-yiv-1433585310yiv0927968934attach-table {
width:400px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div.ygrps-yiv-1433585310yiv0927968934file-title a, #ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div.ygrps-yiv-1433585310yiv0927968934file-title a:active, #ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div.ygrps-yiv-1433585310yiv0927968934file-title a:hover, #ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div.ygrps-yiv-1433585310yiv0927968934file-title a:visited {
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div.ygrps-yiv-1433585310yiv0927968934photo-title a, #ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div.ygrps-yiv-1433585310yiv0927968934photo-title a:active, #ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div.ygrps-yiv-1433585310yiv0927968934photo-title a:hover, #ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div.ygrps-yiv-1433585310yiv0927968934photo-title a:visited {
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 div#ygrps-yiv-1433585310yiv0927968934ygrp-mlmsg #ygrps-yiv-1433585310yiv0927968934ygrp-msg p a span.ygrps-yiv-1433585310yiv0927968934yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 .ygrps-yiv-1433585310yiv0927968934green {
color:#628c2a;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 .ygrps-yiv-1433585310yiv0927968934MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 o {
font-size:0;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934photos div {
float:left;width:72px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934reco-category {
font-size:77%;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934reco-desc {
font-size:77%;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 .ygrps-yiv-1433585310yiv0927968934replbq {
margin:4px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mlmsg select, #ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 input, #ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mlmsg pre, #ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 code {
font:115% monospace;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-mlmsg #ygrps-yiv-1433585310yiv0927968934logo {
padding-bottom:10px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-msg p#ygrps-yiv-1433585310yiv0927968934attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-reco #ygrps-yiv-1433585310yiv0927968934reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-sponsor #ygrps-yiv-1433585310yiv0927968934ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-sponsor #ygrps-yiv-1433585310yiv0927968934ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-sponsor #ygrps-yiv-1433585310yiv0927968934ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1433585310 #ygrps-yiv-1433585310yiv0927968934 #ygrps-yiv-1433585310yiv0927968934ygrp-vital ul li:last-child {
border-right:none !important;}
<div id="ygrps-yiv-1303966991yiv4894253264ygrp-text">
  <div></div><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"><div><span>Agh...Yes, good idea.&nbsp; I am guessing I could do that anywhere I need to &quot;Inactive&quot; something but doesn&#39;t have a check box.</span></div><div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;font-style:normal;background-color:transparent;"><span>Thanks</span></div><div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;font-style:normal;background-color:transparent;"><span><br clear="none"></span></div> <div class="ygrps-yiv-1303966991yiv4894253264qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-1303966991yiv4894253264yqt0217957442" id="ygrps-yiv-1303966991yiv4894253264yqt76580"><div class="ygrps-yiv-1303966991yiv4894253264yahoo_quoted" style="display:block;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div dir="ltr"> <font face="Arial" size="2"> On Monday, October 27, 2014 3:09 PM, &quot;Mark Wagner mjfw2003@... [vantage]&quot; &lt;vantage@yahoogroups.com&gt; wrote:<br clear="none"> </font> </div>  <br clear="none"><br clear="none"> <div class="ygrps-yiv-1303966991yiv4894253264y_msg_container"><div id="ygrps-yiv-1303966991yiv4894253264"><div>
  <div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;background-color:rgb(255, 255, 255);"><div dir="ltr" id="ygrps-yiv-1303966991yiv4894253264yui_3_16_0_1_1414419289435_115913"><span>Kim you can&#39;t make them inactive but you could put a Z in front of the description, write a quick search and make it default for the operations search, and just dont allow anything with a z in front of the description to be searchabl</span></div> <div class="ygrps-yiv-1303966991yiv4894253264qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-1303966991yiv4894253264yqt4173023489" id="ygrps-yiv-1303966991yiv4894253264yqt04331"><div class="ygrps-yiv-1303966991yiv4894253264yahoo_quoted"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div dir="ltr"> <font face="Arial" size="2"> On Monday, October 27, 2014 2:49 PM, &quot;Kimberley White faepigrl@... [vantage]&quot; &lt;vantage@yahoogroups.com&gt; wrote:<br clear="none"> </font> </div>  <br clear="none"><br clear="none"> <div class="ygrps-yiv-1303966991yiv4894253264y_msg_container"><div id="ygrps-yiv-1303966991yiv4894253264">
</div>
</div>
<div class="ygrps-yiv-1303966991yiv4894253264yqt4173023489" id="ygrps-yiv-1303966991yiv4894253264yqt29716"><div style="height:0px;color:rgb(255, 255, 255);"></div></div>
</div>
<div class="ygrps-yiv-1303966991yiv4894253264yqt0217957442" id="ygrps-yiv-1303966991yiv4894253264yqt36700"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264 -- #ygrps-yiv-1303966991yiv4894253264ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mkp hr {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mkp #ygrps-yiv-1303966991yiv4894253264hd {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mkp #ygrps-yiv-1303966991yiv4894253264ads {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mkp .ygrps-yiv-1303966991yiv4894253264ad {
padding:0 0;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mkp .ygrps-yiv-1303966991yiv4894253264ad p {
margin:0;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mkp .ygrps-yiv-1303966991yiv4894253264ad a {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-sponsor #ygrps-yiv-1303966991yiv4894253264ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-sponsor #ygrps-yiv-1303966991yiv4894253264ygrp-lc #ygrps-yiv-1303966991yiv4894253264hd {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-sponsor #ygrps-yiv-1303966991yiv4894253264ygrp-lc .ygrps-yiv-1303966991yiv4894253264ad {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264actions {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264activity {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264activity span {
font-weight:700;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264activity span:first-child {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264activity span a {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264activity span span {
color:#ff7900;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264activity span .ygrps-yiv-1303966991yiv4894253264underline {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 .ygrps-yiv-1303966991yiv4894253264attach {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 .ygrps-yiv-1303966991yiv4894253264attach div a {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 .ygrps-yiv-1303966991yiv4894253264attach img {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 .ygrps-yiv-1303966991yiv4894253264attach label {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 .ygrps-yiv-1303966991yiv4894253264attach label a {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 .ygrps-yiv-1303966991yiv4894253264bold {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 .ygrps-yiv-1303966991yiv4894253264bold a {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 dd.ygrps-yiv-1303966991yiv4894253264last p a {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 dd.ygrps-yiv-1303966991yiv4894253264last p span {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 dd.ygrps-yiv-1303966991yiv4894253264last p span.ygrps-yiv-1303966991yiv4894253264yshortcuts {
margin-right:0;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div.ygrps-yiv-1303966991yiv4894253264attach-table div div a {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div.ygrps-yiv-1303966991yiv4894253264attach-table {
width:400px;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div.ygrps-yiv-1303966991yiv4894253264file-title a, #ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div.ygrps-yiv-1303966991yiv4894253264file-title a:active, #ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div.ygrps-yiv-1303966991yiv4894253264file-title a:hover, #ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div.ygrps-yiv-1303966991yiv4894253264file-title a:visited {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div.ygrps-yiv-1303966991yiv4894253264photo-title a, #ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div.ygrps-yiv-1303966991yiv4894253264photo-title a:active, #ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div.ygrps-yiv-1303966991yiv4894253264photo-title a:hover, #ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div.ygrps-yiv-1303966991yiv4894253264photo-title a:visited {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 div#ygrps-yiv-1303966991yiv4894253264ygrp-mlmsg #ygrps-yiv-1303966991yiv4894253264ygrp-msg p a span.ygrps-yiv-1303966991yiv4894253264yshortcuts {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 .ygrps-yiv-1303966991yiv4894253264green {
color:#628c2a;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 .ygrps-yiv-1303966991yiv4894253264MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 o {
font-size:0;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264photos div {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264photos div div {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264photos div label {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264reco-category {
font-size:77%;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264reco-desc {
font-size:77%;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 .ygrps-yiv-1303966991yiv4894253264replbq {
margin:4px;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-actbar div a:first-child {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mlmsg {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mlmsg table {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mlmsg select, #ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 input, #ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 textarea {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mlmsg pre, #ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 code {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mlmsg * {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-mlmsg #ygrps-yiv-1303966991yiv4894253264logo {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-msg p a {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-msg p#ygrps-yiv-1303966991yiv4894253264attach-count span {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-reco #ygrps-yiv-1303966991yiv4894253264reco-head {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-reco {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-sponsor #ygrps-yiv-1303966991yiv4894253264ov li a {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-sponsor #ygrps-yiv-1303966991yiv4894253264ov li {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-sponsor #ygrps-yiv-1303966991yiv4894253264ov ul {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-text {
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1303966991 #ygrps-yiv-1303966991yiv4894253264 #ygrps-yiv-1303966991yiv4894253264ygrp-vital ul li:last-child {
