In E9 there is a visualization change to the icon that once again shows you. You're right about Vista/Vantage, that's been an annoyance for some time.
The other nice thing about using the memo field instead of comments is that you can add memo's post PO closing. Otherwise with comments you have to reopen the PO/Line and then remember to close.
Ken Williams
Vice President, Administrative Services
Intermountain Electronics, Inc.
O: 877-544-2291
M: 801-918-7318
F: 435-637-9601
www.ie-corp.com
Creating customer confidence through extraordinary service and experienced industry experts.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Manasa Reddy
Sent: Friday, December 03, 2010 12:15 PM
Subject: RE: [Vantage] Re: Cancel a PO - Email found in subject - Email found in subject
Just a heads up on memos, I like the memo's as well, but with the newer
versions of Vista / Vantage, there is tell tale way to know that there
is a memo unless you click on it.
In the old versions they used to have a chevron (>>) to show that there
were notes.
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com> <mailto:manasa@...<mailto:manasa%40weldcoa.com>>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Nancy
Sent: Friday, December 03, 2010 1:08 PM
Subject: [Vantage] Re: Cancel a PO - Email found in subject
Ken and Manasa thanks so much for your replies.
I have relayed your current processes to our ops mgr. I had not looked
into that memo'ing business at all yet, and it does look like a nice
technique for placing easy to access extraneous info. It seems like a
good idea to categorize properly for decent recall later.
Nancy
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , Ken
Williams <kwilliams@...> wrote:
analysis we make sure to exclude voided orders.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Ken Williams
O: 877-544-2291
M: 801-918-7318
F: 435-637-9601
www.ie-corp.com
were notes.
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Nancy
Nancy
>the actions menu. This "voids" it....then for all reports & data
> We put a memo instead of a comment and just close the order through
> What does zero'ing the unit cost do for you?
> Ken Williams
> O: 877-544-2291
> M: 801-918-7318
> F: 435-637-9601
> www.ie-corp.com
>[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Sent: Tuesday, November 30, 2010 7:07 AM<mailto:manasa@...<mailto:manasa%40weldcoa.com>>
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Subject: RE: [Vantage] Cancel a PO - Email found in subject
> We usually put comments in the header as to why it was cancelled, zero
> out the unit cost, and then manually close the releases, lines, etc...
> Very simple...
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
On Behalf
> Of Nancy<mailto:vantage%40yahoogroups.com>
> Sent: Tuesday, November 30, 2010 8:03 AM
> Subject: [Vantage] Cancel a POa
> Hello,
> We are trying to determine a best practice for PO cancellation within
> Epicor 9. If you currently use epicor and occasionally need to cancel
> PO how do you go about it?[Non-text portions of this message have been removed]
> Thank you,
> Nancy
