Void PO Blank Title 57440
If you have your change log turned on, check to see if a buyer re-opened
the PO and then manually closed it or just manually closed it. If you
manually close a PO, it will remain unapproved and the system will
display void for the order.
Butch
Of Paul H. Smith
Sent: Monday, June 11, 2007 8:06 AM
To: Vantage
Subject: [Vantage] Void PO
Hello group. Quick question please? We are currently using Vantage ver
6.0
and I notice sometimes when the purchase is closed (when the last item
is
received) the PO will sometimes say void in the status box. It should
say
closed. Is\has anyone else experienced this, is it a known issue. Thanks
in
advance.
Paul H. Smith
Inventory Manager
Espey MFG.
233 Ballston Ave
Saratoga Springs, NY 12866
518-245-4358
Hello group. Quick question please? We are currently using Vantage ver 6.0
and I notice sometimes when the purchase is closed (when the last item is
received) the PO will sometimes say void in the status box. It should say
closed. Is\has anyone else experienced this, is it a known issue. Thanks in
advance.
Paul H. Smith
Inventory Manager
Espey MFG.
233 Ballston Ave
518-245-4358
