Cannot "save" Serial Number assignment in Vantage 8.03 (error)
What version are you on compared to the other Mike?
If you are on E9, then I can see why it is not working for the other Mike...but if someone is on 8.03...please verify that this does work.
M. Manasa Reddy
manasa@...<mailto:manasa@...>
630.806.2000 x1515
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike McGee
Sent: Wednesday, November 21, 2012 11:04 AM
Subject: RE: [Vantage] Cannot "save" Serial Number assignment in Vantage 8.03 (error). Please help...
We have just been doing this like all the other serial number transactions.
This is the first time it has not worked.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Manasa Reddy
Sent: Wednesday, November 21, 2012 7:39 AM
Mike...how are you doing this?
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com> <mailto:manasa%40weldcoa.com> <mailto:manasa@...<mailto:manasa%40weldcoa.com>
<mailto:manasa%40weldcoa.com> >
630.806.2000 x1515
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Sent: Wednesday, November 21, 2012 7:10 AM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
We have been generating serial numbers on Sub-assemblies for years with no
problem. There is something else going on.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
Manasa Reddy
Sent: Tuesday, November 20, 2012 4:53 PM
I think that is because it is a subassembly....if you made Assembly 3 on its
own job, then added the serial number to it when you received it to
inventory then you can issue that serial part number to the new job.
Yes a pain in the $%^, but that is the only way I knew it worked. I could be
wrong...see if anyone else has done this a different way.
M. Manasa Reddy
<mailto:manasa@...<mailto:manasa%40weldcoa.com> <mailto:manasa%40weldcoa.com>
630.806.2000 x1515
Behalf Of Mike Abell
Sent: Tuesday, November 20, 2012 4:49 PM
You are correct, it is NOT the top level assembly they want to serialize, it
actually is Assembly 3. The only thing I that I can find that is strange is
when they select "assembly 3" for serial number assignment, the part number
box "grays out". It only show's "selectable" on Assembly 0. I don't know if
that matters or not, but that's the only strange thing that happens...
Mike Abell
Systems Analyst / Network Administrator
Flexial - BOA Group - Cookeville, Tennessee
Office: 931.432.1853 ext 302
Mobile: 615.418.3055
email: MAbell@...<mailto:MAbell%40flexial.com> <mailto:MAbell%40flexial.com>
Behalf Of Manasa Reddy
Sent: Tuesday, November 20, 2012 4:39 PM
So they are trying to issue serialized parts to a job to be worked on, or is
it the top level assembly they are trying to issue the serial number
to...that is my confusion. It sounds like the first to me, correct?
M. Manasa Reddy
<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa@wel
<mailto:manasa@wel%0bdcoa.com%20%3cmailto:manasa%40weldcoa.com%3cmailto:mana
sa@wel%0bdcoa.com%20%3cmailto:manasa%40weldcoa.com<mailto:manasa@wel%0b%3cmailto:manasa@wel%0bdcoa.com%20%3cmailto:manasa%40weldcoa.com%3cmailto:mana%0bsa@wel%0bdcoa.com%20%3cmailto:manasa%40weldcoa.com>>
dcoa.com
<mailto:manasa%40weldcoa.com<mailto:manasa@wel%0bdcoa.com%20%3cmailto:manasa
%40weldcoa.com<mailto:manasa%40weldcoa.com%3cmailto:manasa@wel%0bdcoa.com%20%3cmailto:manasa%0b%40weldcoa.com>>>
<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com>>
630.806.2000 x1515
<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
Sent: Tuesday, November 20, 2012 4:35 PM
I'm not sure what you are asking. What would be the correct procedure for
this to work? I am new to all of this but the people on the floor tell me
that they aren't doing anything different that they've done in the past for
this to work. The job and all the assemblies are created/released and
"track serial #'s" is on for the part in question. They then goto "Serial
Number Assignment", pick the job, then assembly they want to assign serial
numbers, then "generate" the serial numbers and then click "save" and that's
when this error pops up. I'm just trying to backtrack and figure out how it
is supposed to work as I can't see anything wrong. Any help on how we
"should" be doing this if we aren't doing it correctly would greatly help
me. Thanks!
Mike.
<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:
<mailto:%0bvantage%40yahoogroups.com%3cmailto:%0bvantage%40yahoogroups.com<mailto:%0b%3cmailto:%0bvantage%40yahoogroups.com%3cmailto:%0bvantage%40yahoogroups.com>>
vantage%40yahoogroups.com<mailto:%0bvantage%40yahoogroups.com>>
Manasa Reddy
Sent: Tuesday, November 20, 2012 4:25 PM
When are you trying to associate the serial number?
M. Manasa Reddy
<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40w
<mailto:manasa%40w%0beldcoa.com%3cmailto:manasa%40w%0beldcoa.com<mailto:manasa%40w%0b%3cmailto:manasa%40w%0beldcoa.com%3cmailto:manasa%40w%0beldcoa.com>>
eldcoa.com<mailto:manasa%40w%0beldcoa.com>> <mailto:manasa%40weldcoa.com>
630.806.2000 x1515
Sent: Tuesday, November 20, 2012 4:17 PM
Subject: [Vantage] Cannot "save" Serial Number assignment in Vantage 8.03
Got no response on this. Does anyone have "ANY" thoughts on this
problem????
Mike..
Behalf Of
Mike Abell
Sent: Monday, November 19, 2012 11:07 AM
The part for the assembly of a job is setup as "approved" and to "track
serial numbers". We go to Serial Number assignment and select the job and
assembly and part # and then generate the serial number range. When we goto
save, we get the following error:
Part Number entered does not match any part number for the job.
Any ideas????
Mike Abell
<mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com><mailto:MAbell%40f
<mailto:MAbell%40f%0blexial.com%3cmailto:MAbell%40f%0blexial.com<mailto:MAbell%40f%0b%3cmailto:MAbell%40f%0blexial.com%3cmailto:MAbell%40f%0blexial.com>>
lexial.com<mailto:MAbell%40f%0blexial.com>> <mailto:MAbell%40flexial.com>
The part for the assembly of a job is setup as "approved" and to "track serial numbers". We go to Serial Number assignment and select the job and assembly and part # and then generate the serial number range. When we goto save, we get the following error:
Any ideas????
Mike Abell
email: MAbell@...
problem????
Mike..
Mike Abell
Any ideas????
Mike Abell
email: MAbell@... <mailto:MAbell%40flexial.com>
M. Manasa Reddy
630.806.2000 x1515
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Abell
Subject: [Vantage] Cannot "save" Serial Number assignment in Vantage 8.03 (error). Please help...
problem????
Mike..
Mike Abell
Any ideas????
Mike Abell
me. Thanks!
Mike.
Manasa Reddy
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com> <mailto:manasa@...
630.806.2000 x1515
problem????
Mike..
Behalf Of
Mike Abell
Any ideas????
Mike Abell
So they are trying to issue serialized parts to a job to be worked on, or is it the top level assembly they are trying to issue the serial number to...that is my confusion. It sounds like the first to me, correct?
M. Manasa Reddy
630.806.2000 x1515
me. Thanks!
Mike.
Manasa Reddy
M. Manasa Reddy
630.806.2000 x1515
problem????
Mike..
Behalf Of
Mike Abell
Any ideas????
Mike Abell
You are correct, it is NOT the top level assembly they want to serialize, it actually is Assembly 3. The only thing I that I can find that is strange is when they select "assembly 3" for serial number assignment, the part number box "grays out". It only show's "selectable" on Assembly 0. I don't know if that matters or not, but that's the only strange thing that happens...
Mike Abell
email: MAbell@...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Manasa Reddy
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa@...<mailto:manasa%40weldcoa.com>>
630.806.2000 x1515
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mike Abell
me. Thanks!
Mike.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
Manasa Reddy
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com> <mailto:manasa%40weldcoa.com> <mailto:manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com>
630.806.2000 x1515
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
problem????
Mike..
Behalf Of
Mike Abell
Any ideas????
Mike Abell
email: MAbell@...<mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com> <mailto:MAbell%40flexial.com>
I think that is because it is a subassembly....if you made Assembly 3 on its own job, then added the serial number to it when you received it to inventory then you can issue that serial part number to the new job.
Yes a pain in the $%^, but that is the only way I knew it worked. I could be wrong...see if anyone else has done this a different way.
M. Manasa Reddy
630.806.2000 x1515
Mike Abell
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Manasa Reddy
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com>>
630.806.2000 x1515
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Mike Abell
me. Thanks!
Mike.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
Manasa Reddy
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com> <mailto:manasa%40weldcoa.com> <mailto:manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com>
630.806.2000 x1515
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
problem????
Mike..
Behalf Of
Mike Abell
Any ideas????
Mike Abell
email: MAbell@...<mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com> <mailto:MAbell%40flexial.com>
Manasa Reddy
M. Manasa Reddy
630.806.2000 x1515
Mike Abell
M. Manasa Reddy
dcoa.com <mailto:manasa%40weldcoa.com>
630.806.2000 x1515
me. Thanks!
Mike.
Manasa Reddy
M. Manasa Reddy
eldcoa.com>
630.806.2000 x1515
problem????
Mike..
Behalf Of
Mike Abell
Any ideas????
Mike Abell
Have you checked "serial numbers required from this operation" on the job operation?
Brian.
Sent: Wednesday, November 21, 2012 8:10 AM
Manasa Reddy
M. Manasa Reddy
630.806.2000 x1515
Mike Abell
M. Manasa Reddy
630.806.2000 x1515
me. Thanks!
Mike.
Manasa Reddy
M. Manasa Reddy
eldcoa.com>
630.806.2000 x1515
problem????
Mike..
Behalf Of
Mike Abell
Any ideas????
Mike Abell
M. Manasa Reddy
630.806.2000 x1515
Manasa Reddy
M. Manasa Reddy
630.806.2000 x1515
Mike Abell
M. Manasa Reddy
dcoa.com <mailto:manasa%40weldcoa.com<mailto:manasa@wel%0bdcoa.com%20%3cmailto:manasa%40weldcoa.com>>
630.806.2000 x1515
me. Thanks!
Mike.
vantage%40yahoogroups.com<mailto:%0bvantage%40yahoogroups.com>> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
Manasa Reddy
M. Manasa Reddy
eldcoa.com<mailto:manasa%40w%0beldcoa.com>> <mailto:manasa%40weldcoa.com> <mailto:manasa@...<mailto:manasa%40weldcoa.com>
630.806.2000 x1515
vantage%40yahoogroups.com<mailto:%0bvantage%40yahoogroups.com>> <mailto:vantage%40yahoogroups.com>
problem????
Mike..
Behalf Of
Mike Abell
Any ideas????
Mike Abell
Brian,
Where do I look for this, I cannot find it on Job tracker?
Mike Abell
email: MAbell@...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Brian Roberts
Brian.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mike McGee
Manasa Reddy
M. Manasa Reddy
630.806.2000 x1515
Mike Abell
M. Manasa Reddy
630.806.2000 x1515
me. Thanks!
Mike.
vantage%40yahoogroups.com<mailto:%0bvantage%40yahoogroups.com>> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Manasa Reddy
M. Manasa Reddy
eldcoa.com<mailto:manasa%40w%0beldcoa.com>> <mailto:manasa%40weldcoa.com> <mailto:manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com>
630.806.2000 x1515
problem????
Mike..
Behalf Of
Mike Abell
Any ideas????
Mike Abell
Manasa Reddy
M. Manasa Reddy
630.806.2000 x1515
Behalf Of
Manasa Reddy
M. Manasa Reddy
<mailto:manasa@... <mailto:manasa%40weldcoa.com>
630.806.2000 x1515
Mike Abell
M. Manasa Reddy
dcoa.com
%40weldcoa.com>>
630.806.2000 x1515
me. Thanks!
Mike.
<mailto:%0bvantage%40yahoogroups.com%3cmailto:%0bvantage%40yahoogroups.com>
Manasa Reddy
M. Manasa Reddy
<mailto:manasa%40w%0beldcoa.com%3cmailto:manasa%40w%0beldcoa.com>
630.806.2000 x1515
problem????
Mike..
Behalf Of
Mike Abell
Any ideas????
Mike Abell
<mailto:MAbell%40f%0blexial.com%3cmailto:MAbell%40f%0blexial.com>
