Cannot "uncomplete" operation in subassembly
Thanks for the reply, but this operation did not have anybody clock-in to complete, so there was nothing to edit using "Labor Entry."
--tj
--- In vantage@yahoogroups.com, Adam Puchalski <a.puchalski@...> wrote:
> I've dealt with this issue by modifying the labor entry where the mistake was made.
> It always works fine for me to either uncheck "OP Complete" or to just delete the entry altogether depending on the circumstances.
> AP
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cooner_55421
> Sent: Friday, March 25, 2011 12:26 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Cannot "uncomplete" operation in subassembly
> I think Op Complete is a hidden field in the Job Entry screen operation grid.
> I think I've unhid it and toggled op complete before.
> But... didn't work on all ops, can't remember the details.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "sanfranc415" <sanfranc415@> wrote:
> > There is an open job in which a sub-assembly operation was mistakenly completed.
> > Using Job Adjustment, we unchecked the operation that was complete and saved, but upon reentering the job, the operation is still complete.
> > The change log even shows that the operation was changed from complete yes -> no
> > Any ideas?
> > I'm sure our procedure is correct, since we tested this on another job and worked fine.
> > --sf
Any ideas?
--sf
What about "uncompleting" the operation on the labor record that
completed it? Usually that will work...but all too time consuming when
"looking " for it!
Manasa
630.806.2000 x1515
Of sanfranc415
Sent: Friday, March 25, 2011 1:43 PM
Subject: [Vantage] Cannot "uncomplete" operation in subassembly
completed.
yes -> no
Any ideas?
and worked fine.
--sf
I think you can go into the last labor entry for that particular sub-assembly and uncheck the COMLETE box on the bottom left side. That should open the operation as well as the sub-assembly. This will not work if the last labor entry is in a closed period (i.e. you've already run your WIP).
Marjorie Nadeau
Sent: Friday, March 25, 2011 3:26 PM
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "sanfranc415" <sanfranc415@...> wrote:
> Any ideas?
> --sf
So, is there a scenario in which you CANNOT remove completion of a job operation? Although, you can remove job completion of different assemblies and operations?
--sf
> Marjorie Nadeau
> > Any ideas?
> > --sf
AP
> Any ideas?
> --sf
