I have a challenge to all of the code-slinging techno-wizards of Epicor!! You know who you are.
I’m wondering if you are able to code around Field Security.
It is pretty well documented that you can get around BO security through code, but have any of you ever tried getting around Field security? Consider yourself challenged.
It’s been a while since I needed to do it, but the last time I did this, if I recall correctly I set up a pre/post on update and/or masterupdate,
In pre I over-rode the RowMod = “U”/“A” line with the default, so that it wasn’t attempting to write that column, then i stuffed the value in callcontext.
Then in the post, I did a manual LINQ Query using the Db Object and .SaveChanges() - this bypasses field security (it is applied at the business object layer)
Acknowledging exploits about a company that makes no effort to hear about security oversights can be risky depending on which way they decide to respond in the moment. Proceed with caution.
When a company deletes exploit reporting, stop until they’ve demonstrated a compelling commitment away from adversarial escalation and towards ethical response.
Wow, turns out you don’t even need to be a hacker to bypass field security. I made all of the shipping tables read-only and was still able to create a pack with a user that did not have write access. I just used all of the buttons in Customer Shipment Entry and was able to get everything filled in and saved. The only thing I could not actually do was mark the pack as Shipped. But that is frightening that I was able to get as far as I did.
