Compiled Crystal
Rhonda,
If you get around to remembering what it took to make the report default to
a specific location, please let me know. We are interested in doing this as
well.
Thaddeus Jacobs.
Sent: Wednesday, May 16, 2001 8:17 AM
Subject: RE: [Vantage] Compiled Crystal
Well, yes and no. I have been able to compile the reports and run them on
the client only after I reinstalled crystal reports. Don't know what was
up there but that is working now. The next problem is Visual basic. I
would rather for a user to push a button and the report export to a specific
file and not have the need to put in the path and file names themselves.
This is a text file that is being pulled by another program and there is no
need for the file to be viewed or printed. It works on my computer, I
finally got it to work on the computer I was testing but guess what. I did
so much that I don't know what finally got it to work so now it doesn't work
on the user's computer.
Sent: Tuesday, May 15, 2001 9:07 PM
Subject: Re: [Vantage] Compiled Crystal
Any success yet, Rhonda?
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Tuesday, May 15, 2001 10:36 AM
Subject: [Vantage] Compiled Crystal
I have tried compiling a crystal report and distributing it to a client
computer and all I get is the hourglass for a second and then nothing. I
am
using v.8 and have downloaded the add-in. I also have created a visual
basic program to print the report and still get the same thing....Nothing.
Since I am not getting an error message I don't know where to look for the
answer. I do have the odbc drivers on the clients computer but not
crystal
reports(I didn't think I needed them)Any thoughts?
Rhonda
Yahoo! Groups Sponsor
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
computer and all I get is the hourglass for a second and then nothing. I am
answer. I do have the odbc drivers on the clients computer but not crystal
Rhonda
Did you run the setup.exe file on the client PC? It was created during the compile process. This installs the necessary dll files so that the client computer can run the compiled report.
Troy Funte
Liberty Electronics
Rhonda
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
Yes I have run both the setup created by Crystal and the setup I created
when I made a distribution copy of my Visual Basic program. Neither on
works. I also have tried this on a non-progress database and still get the
same thing.
Sent: Tuesday, May 15, 2001 9:44 AM
Troy Funte
Liberty Electronics
am
crystal
Rhonda
Rhonda,
I know this sounds like a dumb question, but did you install the ODBC
drivers on the client?
Warren R. Eddy
Information Services Manager
National Tube Form, LLC
Phone: (219) 478-2363 ext 217
Fax: (219) 478-1043
Warren.Eddy@...
Sent: Tuesday, May 15, 2001 9:50 AM
same thing.
Troy Funte
Liberty Electronics
am
crystal
Rhonda
Troy Funte
Liberty Electronics
Rhonda
Troy Funte
Liberty Electronics
am
crystal
Rhonda
I know early on with our Crystal implementation there were a lot of .dll issues. The versions on the client have to match the versions on the 'designer' computer. mfc40.dll was one culprit. I don't remember the others. These would be dll's located in the c:\windows\system folder that Crystal accesses.
You may find that when you install a second CR on the same client, that suddenly the first one quits working again. If so, then it's .dll issues. Crystal Decisions tech support can usually track down the problem fairly well.
Troy Funte
Liberty Electronics
Sent: Wednesday, May 16, 2001 9:17 AM
Troy Funte
Liberty Electronics
am
crystal
Rhonda
Say you love them
with a DOMAIN NAME!
www.
