Are you using ODBC to get at Vantage data? Try distributing it to the "development" PC and see if it works there. I assume it runs OK in development mode so the devlopment PC has an OK connection to the database. If it run there then check the ODBC connection settings on the user PC.
Also....I am wondering whether if in ODBC cases you must check the Include Files box in option 1. I have never distributed an ODBC based report so we are getting outside my experience scope. Perhaps someone else has more experience distributing ODBC driven CR.
-Todd C.
Sent: Tuesday, August 23, 2005 1:53 PM
Subject: RE: [Vantage] Crystal 8.5 Distribution
I did all you suggested and got the setup.exe to run on a machine. I found the report I compiled and tried to run. I got the following error: 'Error in File C:\Program Files\ Seagate Software\Distributed Reports\ScrapJeffD.rpt
.Failed to create Crystal Query Engine.'
Any suggestions??
Todd Caughey <caugheyt@...> wrote:
In the develpopment screen for a report click on "Report" on the menu bar then at the bottom of the drop down click on 'Report Disctibution Expert'.
Once this opens there are several tabs to walk through via the next buttons...
1. Options: UN-check include database files
Check include DLLs
Enter a destination directory wher the user(s) will install from - I have a special 'Crystal Distribution' folder in one of ny shared Vantage folders that users have read access to.
2-4 Next, Next, Build. It will list DLLs and such that it is including.
On user PC browse to folder for the report. I create a new subfolder in 'Crystal Distribution' for each report (and secure as needed). Find Setup.exe and run. This should create a Seagate folder path under Program Files for the compiled .exe and will also copy DLL's as needed. When installing several the first one always takes a bit longer.
I make links to the .exe in the user's Vantage Favorites bar(s) but they could just as well be desktop shortcuts.
-Todd C.
Sent: Tuesday, August 23, 2005 1:01 PM
To: Users Group
I've got the Report Dist Wizard installed. I have used the Compile and Distribute menus. What next for the other users to see and run reports?
Todd Caughey <caugheyt@...> wrote:The Epicor FTP site, in the Crystal folder, has the Report Distribution Wizard. Install it on the developer's PC. It will add commands to the menu bar items. Once this is done post again and I have some tips for distributing reports that I can share. In a nutshell though the wizard packages the proper files and a setup program which when run on the user's PC installs the compiled report - no Crystal license required. I use it only against DBF files created by Vantage but I am pretty sure it will run ODBC versions too if the user's PC has the ODBC connection set up.
-Todd C.
Sent: Tuesday, August 23, 2005 10:44 AM
To: Users Group
Subject: [Vantage] Crystal 8.5 Distribution
I am creating reports that I want other people to have access to and run. How do I do this without setting up Crystal on all machines? I know there is a way, but I haven't found it yet.
Any help and direction would be appreciated...
Melissa
UMC, Inc
Start your day with Yahoo! - make it your home page
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage < http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service < http://docs.yahoo.com/info/terms/> .
_____
SPONSORED LINKS
Technical support Vantage Database Database management software Membership database software Church database software
YAHOO! GROUPS LINKS
Visit your group "vantage" on the web.
_____
YAHOO! GROUPS LINKS
_____
YAHOO! GROUPS LINKS
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
-Todd C.
Any suggestions??
Check include DLLs
-Todd C.
To: Users Group
-Todd C.
To: Users Group
Melissa
UMC, Inc
_____
YAHOO! GROUPS LINKS
_____
SPONSORED LINKS
YAHOO! GROUPS LINKS
_____
YAHOO! GROUPS LINKS
_____
YAHOO! GROUPS LINKS
_____
YAHOO! GROUPS LINKS
_____
