With the LS2208 you have to scan barcodes to set your rules correct? I haven't had much luck with those. I tried using the Scan123 software that is made available... but I had no luck.
--- In vantage@yahoogroups.com, "psiebers" <psiebers@...> wrote:
> I am using the Symbol LS2208 USB scanners... What are you doing with the datawedge? Does it let you slow down or pause between barcoded characters?
> I have downloaded the app that lets you configure some of the hardware settings. It allowed me to set a keystroke delay of 40ms, but that is still too fast for the Assembly or Operation fields to become available...
> According to Tech Support data verification takes place ot each of the three levels. Epicor 9 works the same way...
> Paul
> --- In vantage@yahoogroups.com, "tomrippity02" <bateman_aaron@> wrote:
> > I accomplished the same thing by using the datawedge to define my delimiters. What kind of scanners are you using and do you have some wedge software for them? I like that solution better as I don't have to concern myself with changes to the reports in the future. I can add as many items to barcodes and what not as I want as well, and it always tabs correctly.
> > --- In vantage@yahoogroups.com, "psiebers" <psiebers@> wrote:
> > > I am wondering if anyone has found a way to concatenate the Job/Assy/Op
> > > into a single bar code that can be used on the 8.03 traveler?
> > > In 6.1 you could use "*" + trim({jobhead.JOBNUM} + "$I" +
> > > trim(totext({JobAsmbl.AssemblySeq},0)) + "$I"
> > > + trim(totext({JOBOPER.OPRSEQ},0))) + "$I" + "*" to print all three in a single
> > > bar code. That function broke in 8.03. I submitted a request to Epicor this
> > > morning, and the answer was that it was turned into an enhancement request...
> > > TIA,
> > > Paul
