Vic-
We are using Symbol LS2208 SR2000-7R-UR scanners with Code39 font, I will check out the file you referenced to solve my issue. Thanks so much for your speedy and accurate response, that is why this group is great!
Paul
This message (including any attachments) is intended only for the use of the named addressee(s), and may contain information that is legally privileged, confidential or exempt from disclosure under applicable law. If you are not a named addressee, you are hereby notified that any use, dissemination, distribution or copying of this message is strictly prohibited. If you have received this message in error, please notify the original sender immediately by telephone or by return E-mail and delete this message, along with any attachments, from your computer. Thank you.
Paul
