You can configure it to print from any screen using data from the form. You can also dynamically select the printer. We do this on the shop floor in report quanity, every machine has a printer. We also do this in the office from a UD table Here is an example
Dim UD01 As EpiDataView = Ctype(oTrans.EpiDataViews("UD01"),EpiDataView)
Dim Printer As String = UD01Form.Session.UserID
Dim TagNumber As String = UD01.dataView(UD01.Row)("Key1")
Dim strPath As String = "C:\Progra~1\Seagull\BarTender\8.0\bartend.exe"
Dim strParam As String = "/F=C:\Tags.btw /PRN= /P /X /?TagNumber="&TagNumber
Dim strParam2 As String = strParam.Insert(20,Printer)
Process.Start(strPath, strParam2)
--- In vantage@yahoogroups.com, "djojmis" <dougo@...> wrote:
> Chris,
> We are currently automatically printing a BarTender label for EDI shipments based on a checkbox on the Customer Shipment Entry form.
> The set up is a little cumbersome to replicate in this forum, however technical support will walk you through the set-up.
> Our process uses a Vantage printer and BPM.
> For your second option, Shopfloor/MES has an options to print labels at each operation. Do you have MES? If not you may want to consider.
> You can customize the labels based on the Operation, but I have not tried to change the size/type of label.
> Hope this helps,
> Doug Oswald
> Manager of Information Systems and Facilities
> FLEETWOOD
> Re: [Vantage] Configure Epicor to print to BarTender
> In addition, can you just use Crystal instead of Bartender?
> From: Chris Thompson <chriselectrix@>
> To: vantage@yahoogroups.com
> Sent: Wed, 23 March, 2011 8:45:44
> Subject: [Vantage] Configure Epicor to print to BarTender
> Â
> Hi All
> Is there a way that you can automatically print to bartender when you print out
> a job traveller?
> When we print our Job Travellers we then have to go to another PC to print
> several different types of labels for the products. Only one copy of a label may
> be required for some products, but others will require 2 or more. Generally each
> product will get more than one label.
> Is there anyway to link this in with Epicor so in the Job Traveller screen all
> the correct amount of labels can be printed?
> Alternatively, a better solution ...
> If we had label printers on the shopfloor in designated areas (where they
> require labels), how can we get the labels to print (or create a button) to
> print the labels for that particular operation?
> i.e. the 3rd operation may need one type of label and the last operation may
> need another type.
> The time between operations can be months, so often labels go missing.
> Any suggestions would be appreciated.
> Thanks,
> CHRIS
