Jason,
Yes and No. Yes that is true that the Open Edge Progress Explorer Tool
GUI or "PET" WILL NOT work on Windows Server 2008. The reasoning is
because the PET GUI is based on the fact that Windows Server 2008 uses a
completely different MMC (Microsoft Management Console) and they are
incompatible with one another since our buddies at Microsoft decided to
change all of that. If you read up on the MMC change between 2003 and
2008 you will see what I mean. However Vantage may still run on
Windows Server 2008 just fine and just use the client on a local
workstation "Windows XP and/or Vista Business" to just remotely connect
to the AppServer to be administered. I have had NO issue's doing it
this way, because lets be frank, us IT Professionals are moving on with
our Server OS's, etc though I really am fighting the format of my hard
drive and moving to Vista. L
That's all it really is though, and I have not had any problems doing
so. Contact me if you need some help or guidance.
Christopher Ryhal
Microsoft Consultant
Perpetual Technologies, Inc
chris.ryhal@... <mailto:chris.ryhal@...>
http://www.perptech.com
Office: (317) 824-0393
Mobile: (317) 364-2134
Of Jason Claggett
Sent: Thursday, April 09, 2009 9:44 PM
Subject: RE: [Vantage] New Vantage server Setup?
What version of Vantage - I assume 8.03.4xx otherwise it would be Epicor
9?
I received an email from Ben Nixon Tuesday that 8.03.400 was not
supported on windows 2008, yes, 2003 32-bit and 64-bit is fine, but not
Windows 2008...below is his email from my question whether Vantage
8.03.400 is supported on Server 2008:
"Not supported on server 2008
Server 2003 32 and 64
Regards:
Ben Nixon
Manager / Systems Consulting
www.epicor.com<http://epicor.com/>
Cell: (651) 303-1619
Fax: (949) 341-3619
E-Mail: bnixon@... <mailto:bnixon%40epicor.com>
<mailto:bnixon@... <mailto:bnixon%40epicor.com> >"
<../../Application%20Data/Microsoft/Signatures/(EmptyReference!)>
This has to do mostly with OpenEdge 10.1b and the problems with Progress
Explorer Tool not working. There are a handful of problems with the
10.1b database not running correctly in 2008 as well, like tuning the
database has no effect on it so you run dog slow.
With 10.1c and E9, the problems with the databases not running correctly
have mostly disappeared, but the Progress Explorer Tool still does not
run on the server and you need another XP or 2003 box to run it on.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@... <mailto:jason%402wtech.com> <mailto:jason@...
<mailto:jason%402wtech.com> >
Behalf Of Alison Levy
Sent: Thursday, April 09, 2009 2:42 PM
I just got a server recommendation from Ben Nixon, he stated 64bit with
Server 2008 or 2003.
Alison Levy | IT Manager | Mats Inc.
dir: 781-573-0291 | cell: 781-964-1698 | fax: 781-232-5191
alevy@... <mailto:alevy%40matsinc.com>
<mailto:alevy%40matsinc.com> | www.matsinc.com Ask us about our clean,
green and beautiful matting and flooring
This message is intended only for the individual named. If you are not
the named addressee you should not disseminate, distribute or copy this
e-mail. Please notify the sender immediately by e-mail if you have
received this e-mail by mistake. Please note that any views or opinions
presented in this email are solely those of the author and do not
necessarily represent those of the company.
<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Of Dan Shallbetter
Sent: Tuesday, April 07, 2009 9:34 AM
Subject: [Vantage] New Vantage server Setup?
We are looking at a new Vantage server I have a few questions? The
local IBM VAR is quoting a Server running windows server 2008 downgraded
to server 2003 based on Epicor not supporting 64 bit, would it be better
to install with server 2008 in a 32 bit mode and have the option of
upgrading to 64 bit later? The VAR is quoting 25 hour for on boarding,
documentation and server setup with a Raid 1 array for the OS and Raid
10 array for Vantage (no Vantage related worked to be performed) seems
excessive to me, what is a realistic ? Any tips for moving the database
to a new server would be appreciated.
TIA.
Dan Shallbetter
States Electric Mfg.
Christopher Ryhal
Of Jason Claggett
9?
Regards:
Ben Nixon
Fax: (949) 341-3619
Jason Claggett
MCP #3856159
312.533.4033 x8039
On Behalf
Of Dan Shallbetter
TIA.
Dan Shallbetter
