Contents of an installed solution?
Is there a way to see what items were installed with a specific solution in the Epicor UI?
The solution workbench shows what solutions have been installed but doesn’t have anything as far as the contents goes. We obviously don’t build any solutions in Production, just installs, so we can’t go to Solution Workbench, type in the solution id and see the contents.
Solutions are built in our Test Environments, which are reloaded on a regular basis, so we don’t have the original solution records that the solution was built from. All we have is the cab file.
The manifest in the cab file shows everything but that seems odd that I would have to go there, instead of the application, to see that info.
Might this discussion cover your question? Solution Manager - #10 by Kimberley - Feature Requests and Suggestions - Epicor User Help Forum
I think that discussion might be more tailored towards building the solutions. I’m more interested in figuring out how to see that same solution information after it has been installed in a different environment.
The Delete Solution functionality of SM seems to know what items were installed, I just don’t know how to view myself or if it’s even possible. I would be nice to know what it’s deleting. I have not used that functionality in Production but I have used it when going from my Dev environment(were I build the solution) to a Test environment(for user testing).
