Crazy amount of Ship Tos
Is the customer set to automatically save OTS addresses as ShipTos?  It could be that the system is automatically creating the ShipTos even though the orders are being entered as OTS addresses.
Bob Beaghan
---In vantage@yahoogroups.com, <jgiese@...> wrote:
Ah yes yes that’s more or less how we process our OTS shipments.  In a lot of cases we will only have a hand full of ship tos per customer and we save them for later use. It’s just this one customer that is really bad and seems to bird shot their product all over creation.  Thank you for the input!
Joshua Giese
CIO
920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
Wisconsin Converting, Inc.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Wednesday, October 9, 2013 1:32 PM
Subject: Re: Re: [Vantage] Crazy amount of Ship Tos
We don't have version 9, but from what I understand is if you use a dropship address, then the address is assigned to the order, and not the customer.  Basically, it's a one time use shipping address.
Steven G.
On Wednesday, October 9, 2013 2:00 PM, Joshua Giese <jgiese@...> wrote:
Great thanks. I don’t think we were aware we should be using drop ship addresses instead of shiptos I don’t reacall seeing drop ship addresses anywhere except generated from pack slips.  The BPM was pretty simple.
Customer.GetByCustID
Custom ABL
IF custID = “BADCUSTOMER” THEN DO:
                Assign withShipTo = FALSE.
END.
Again that only helped in customer entry, but not order entry at all.
Joshua Giese
CIO
Sent: Wednesday, October 9, 2013 12:51 PM
We are on 8.03.408a, but we had this problem on customer maintenance who had a large number of shipto records.  The solution was to write a customization that removed the tree view on the left side of the form.
There is no way that I know of to delete a shipto record once it has been used.  Since you are on version 9, using a dropship address instead of a shipto would prevent this going forward, it just wouldn't help with the current customer record you are having a problem with.
I would be interested in seeing the pre-process BPM you used.
Steven G.
On Wednesday, October 9, 2013 10:56 AM, "jgiese@..." <jgiese@...> wrote:
For Customer Entry adding a pre-process on GetByCustID that changed withShipTo to false when it is X customer worked. However did not help my situation in Order Entry. Evaluating this customer's record during order entry takes about 12 seconds a normal customer is 2.5 seconds.  Not sure what about this customer is making order entry so slow.
What version are you on?
Steven G.
On Wednesday, October 9, 2013 9:32 AM, "jgiese@..." <jgiese@...> wrote:
We have a customer in the system with 3600+ ship to addresses saved. It has made using this customer in the system very slow.  Is there any way we can purge those from the system.  We can't delete them manually because they are attached to orders. Not sure what to do. Considering creating a new ID for this customer and just not saving the ship tos for them. Thoughts?
Steven G.
<div id="ygrps-yiv-1088433173yiv4931778319ygrp-text">
  <div>We have a customer in the system with 3600+ ship to addresses saved. It has made using this customer in the system very slow. &nbsp;Is there any way we can purge those from the system. &nbsp;We can&#39;t delete them manually because they are attached to orders. Not sure what to do. Considering creating a new ID for this customer and just not saving the ship tos for them. Thoughts?</div>
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319 -- #ygrps-yiv-1088433173yiv4931778319ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mkp #ygrps-yiv-1088433173yiv4931778319hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mkp #ygrps-yiv-1088433173yiv4931778319ads {
margin-bottom:10px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mkp .ygrps-yiv-1088433173yiv4931778319ad {
padding:0 0;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mkp .ygrps-yiv-1088433173yiv4931778319ad p {
margin:0;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mkp .ygrps-yiv-1088433173yiv4931778319ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-sponsor #ygrps-yiv-1088433173yiv4931778319ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-sponsor #ygrps-yiv-1088433173yiv4931778319ygrp-lc #ygrps-yiv-1088433173yiv4931778319hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-sponsor #ygrps-yiv-1088433173yiv4931778319ygrp-lc .ygrps-yiv-1088433173yiv4931778319ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319activity span {
font-weight:700;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319activity span span {
color:#ff7900;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319activity span .ygrps-yiv-1088433173yiv4931778319underline {
text-decoration:underline;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 .ygrps-yiv-1088433173yiv4931778319attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 .ygrps-yiv-1088433173yiv4931778319attach div a {
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 .ygrps-yiv-1088433173yiv4931778319attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 .ygrps-yiv-1088433173yiv4931778319attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 .ygrps-yiv-1088433173yiv4931778319attach label a {
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 .ygrps-yiv-1088433173yiv4931778319bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 .ygrps-yiv-1088433173yiv4931778319bold a {
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 dd.ygrps-yiv-1088433173yiv4931778319last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 dd.ygrps-yiv-1088433173yiv4931778319last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 dd.ygrps-yiv-1088433173yiv4931778319last p span.ygrps-yiv-1088433173yiv4931778319yshortcuts {
margin-right:0;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div.ygrps-yiv-1088433173yiv4931778319attach-table div div a {
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div.ygrps-yiv-1088433173yiv4931778319attach-table {
width:400px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div.ygrps-yiv-1088433173yiv4931778319file-title a, #ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div.ygrps-yiv-1088433173yiv4931778319file-title a:active, #ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div.ygrps-yiv-1088433173yiv4931778319file-title a:hover, #ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div.ygrps-yiv-1088433173yiv4931778319file-title a:visited {
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div.ygrps-yiv-1088433173yiv4931778319photo-title a, #ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div.ygrps-yiv-1088433173yiv4931778319photo-title a:active, #ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div.ygrps-yiv-1088433173yiv4931778319photo-title a:hover, #ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div.ygrps-yiv-1088433173yiv4931778319photo-title a:visited {
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 div#ygrps-yiv-1088433173yiv4931778319ygrp-mlmsg #ygrps-yiv-1088433173yiv4931778319ygrp-msg p a span.ygrps-yiv-1088433173yiv4931778319yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 .ygrps-yiv-1088433173yiv4931778319green {
color:#628c2a;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 .ygrps-yiv-1088433173yiv4931778319MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 o {
font-size:0;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319photos div {
float:left;width:72px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319reco-category {
font-size:77%;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319reco-desc {
font-size:77%;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 .ygrps-yiv-1088433173yiv4931778319replbq {
margin:4px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mlmsg select, #ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 input, #ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mlmsg pre, #ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 code {
font:115% monospace;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-mlmsg #ygrps-yiv-1088433173yiv4931778319logo {
padding-bottom:10px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-msg p#ygrps-yiv-1088433173yiv4931778319attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-reco #ygrps-yiv-1088433173yiv4931778319reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-sponsor #ygrps-yiv-1088433173yiv4931778319ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-sponsor #ygrps-yiv-1088433173yiv4931778319ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-sponsor #ygrps-yiv-1088433173yiv4931778319ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1088433173 #ygrps-yiv-1088433173yiv4931778319 #ygrps-yiv-1088433173yiv4931778319ygrp-vital ul li:last-child {
border-right:none !important;}
9.05.700B2.  Sorry I used to have that in a signature.
Steven G.
<div id="ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-text">
</div>
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 -- #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mkp hr {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mkp #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319hd {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mkp #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ads {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mkp .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ad {
padding:0 0;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mkp .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ad p {
margin:0;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mkp .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ad a {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-sponsor #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-sponsor #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-lc #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319hd {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-sponsor #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-lc .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ad {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319actions {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319activity {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319activity span {
font-weight:700;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319activity span:first-child {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319activity span a {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319activity span span {
color:#ff7900;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319activity span .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319underline {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319attach {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319attach div a {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319attach img {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319attach label {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319attach label a {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319bold {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319bold a {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 dd.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319last p a {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 dd.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319last p span {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 dd.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319last p span.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319yshortcuts {
margin-right:0;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319attach-table div div a {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319attach-table {
width:400px;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319file-title a, #ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319file-title a:active, #ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319file-title a:hover, #ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319file-title a:visited {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319photo-title a, #ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319photo-title a:active, #ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319photo-title a:hover, #ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319photo-title a:visited {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 div#ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mlmsg #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-msg p a span.ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319yshortcuts {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319green {
color:#628c2a;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 o {
font-size:0;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319photos div {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319photos div div {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319photos div label {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319reco-category {
font-size:77%;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319reco-desc {
font-size:77%;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 .ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319replbq {
margin:4px;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-actbar div a:first-child {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mlmsg {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mlmsg table {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mlmsg select, #ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 input, #ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 textarea {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mlmsg pre, #ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 code {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mlmsg * {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-mlmsg #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319logo {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-msg p a {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-msg p#ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319attach-count span {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-reco #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319reco-head {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-reco {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-sponsor #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ov li a {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-sponsor #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ov li {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-sponsor #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ov ul {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-text {
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1595985055 #ygrps-yiv-1595985055ygrps-yiv-1253832573 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319 #ygrps-yiv-1595985055ygrps-yiv-1253832573yiv4931778319ygrp-vital ul li:last-child {
Steven G.
<div id="ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-text">
</div>
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 -- #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mkp hr {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mkp #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319hd {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mkp #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ads {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mkp .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ad {
padding:0 0;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mkp .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ad p {
margin:0;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mkp .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ad a {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-sponsor #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-sponsor #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-lc #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319hd {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-sponsor #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-lc .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ad {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319actions {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319activity {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319activity span {
font-weight:700;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319activity span:first-child {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319activity span a {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319activity span span {
color:#ff7900;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319activity span .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319underline {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319attach {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319attach div a {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319attach img {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319attach label {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319attach label a {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319bold {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319bold a {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 dd.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319last p a {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 dd.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319last p span {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 dd.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319last p span.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319yshortcuts {
margin-right:0;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319attach-table div div a {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319attach-table {
width:400px;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319file-title a, #ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319file-title a:active, #ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319file-title a:hover, #ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319file-title a:visited {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319photo-title a, #ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319photo-title a:active, #ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319photo-title a:hover, #ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319photo-title a:visited {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 div#ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mlmsg #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-msg p a span.ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319yshortcuts {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319green {
color:#628c2a;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 o {
font-size:0;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319photos div {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319photos div div {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319photos div label {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319reco-category {
font-size:77%;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319reco-desc {
font-size:77%;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 .ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319replbq {
margin:4px;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-actbar div a:first-child {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mlmsg {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mlmsg table {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mlmsg select, #ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 input, #ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 textarea {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mlmsg pre, #ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 code {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mlmsg * {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-mlmsg #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319logo {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-msg p a {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-msg p#ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319attach-count span {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-reco #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319reco-head {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-reco {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-sponsor #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ov li a {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-sponsor #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ov li {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-sponsor #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ov ul {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-text {
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1030668748 #ygrps-yiv-1030668748ygrps-yiv-1432539569 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319 #ygrps-yiv-1030668748ygrps-yiv-1432539569yiv4931778319ygrp-vital ul li:last-child {
Steven G.
<div id="ygrps-yiv-1293665652yiv7375108736ygrp-text">
  <div>For Customer Entry adding a pre-process on GetByCustID that changed withShipTo to false when it is X customer worked. However did not help my situation in Order Entry. Evaluating this customer&#39;s record during order entry takes about 12 seconds a normal customer is 2.5 seconds. &nbsp;Not sure what about this customer is making order entry so slow.&nbsp;</div> <div class="ygrps-yiv-1293665652yiv7375108736ygroups-quoted"><br clear="none"><br clear="none">---In vantage@yahoogroups.com, &lt;vantage@yahoogroups.com&gt; wrote:<br clear="none"><br clear="none"><div id="ygrps-yiv-1293665652yiv7375108736ygrps-yiv-1432539569"><div style="color:rgb(0, 0, 0);background-color:rgb(255, 255, 255);font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:12pt;"><div><span>What version are you on?</span></div><div style="color:rgb(0, 0, 0);font-size:16px;font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;background-color:transparent;font-style:normal;"><span><br clear="none"></span></div><div style="color:rgb(0, 0, 0);font-size:16px;font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;background-color:transparent;font-style:normal;"><span>Steven G.</span></div><div class="ygrps-yiv-1293665652yiv7375108736ygrps-yiv-1432539569yahoo_quoted"> <br clear="none"> <br clear="none"> <div style="font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:12pt;"> <div style="font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:12pt;"> <div dir="ltr"> <font size="2" face="Arial"> On Wednesday, October 9, 2013 9:32 AM, &quot;jgiese@...&quot; &lt;jgiese@...&gt; wrote:<br clear="none"> </font> </div>  <div class="ygrps-yiv-1293665652yiv7375108736ygrps-yiv-1432539569y_msg_container"><div id="ygrps-yiv-1293665652yiv7375108736ygrps-yiv-1432539569yiv4931778319"><div>
<div id="ygrps-yiv-1293665652yiv7375108736ygrps-yiv-1432539569yiv4931778319ygrp-text">
</div>
</div>
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736 -- #ygrps-yiv-1293665652yiv7375108736ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mkp hr {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mkp #ygrps-yiv-1293665652yiv7375108736hd {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mkp #ygrps-yiv-1293665652yiv7375108736ads {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mkp .ygrps-yiv-1293665652yiv7375108736ad {
padding:0 0;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mkp .ygrps-yiv-1293665652yiv7375108736ad p {
margin:0;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mkp .ygrps-yiv-1293665652yiv7375108736ad a {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-sponsor #ygrps-yiv-1293665652yiv7375108736ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-sponsor #ygrps-yiv-1293665652yiv7375108736ygrp-lc #ygrps-yiv-1293665652yiv7375108736hd {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-sponsor #ygrps-yiv-1293665652yiv7375108736ygrp-lc .ygrps-yiv-1293665652yiv7375108736ad {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736actions {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736activity {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736activity span {
font-weight:700;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736activity span:first-child {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736activity span a {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736activity span span {
color:#ff7900;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736activity span .ygrps-yiv-1293665652yiv7375108736underline {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 .ygrps-yiv-1293665652yiv7375108736attach {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 .ygrps-yiv-1293665652yiv7375108736attach div a {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 .ygrps-yiv-1293665652yiv7375108736attach img {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 .ygrps-yiv-1293665652yiv7375108736attach label {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 .ygrps-yiv-1293665652yiv7375108736attach label a {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 .ygrps-yiv-1293665652yiv7375108736bold {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 .ygrps-yiv-1293665652yiv7375108736bold a {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 dd.ygrps-yiv-1293665652yiv7375108736last p a {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 dd.ygrps-yiv-1293665652yiv7375108736last p span {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 dd.ygrps-yiv-1293665652yiv7375108736last p span.ygrps-yiv-1293665652yiv7375108736yshortcuts {
margin-right:0;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div.ygrps-yiv-1293665652yiv7375108736attach-table div div a {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div.ygrps-yiv-1293665652yiv7375108736attach-table {
width:400px;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div.ygrps-yiv-1293665652yiv7375108736file-title a, #ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div.ygrps-yiv-1293665652yiv7375108736file-title a:active, #ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div.ygrps-yiv-1293665652yiv7375108736file-title a:hover, #ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div.ygrps-yiv-1293665652yiv7375108736file-title a:visited {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div.ygrps-yiv-1293665652yiv7375108736photo-title a, #ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div.ygrps-yiv-1293665652yiv7375108736photo-title a:active, #ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div.ygrps-yiv-1293665652yiv7375108736photo-title a:hover, #ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div.ygrps-yiv-1293665652yiv7375108736photo-title a:visited {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 div#ygrps-yiv-1293665652yiv7375108736ygrp-mlmsg #ygrps-yiv-1293665652yiv7375108736ygrp-msg p a span.ygrps-yiv-1293665652yiv7375108736yshortcuts {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 .ygrps-yiv-1293665652yiv7375108736green {
color:#628c2a;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 .ygrps-yiv-1293665652yiv7375108736MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 o {
font-size:0;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736photos div {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736photos div div {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736photos div label {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736reco-category {
font-size:77%;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736reco-desc {
font-size:77%;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 .ygrps-yiv-1293665652yiv7375108736replbq {
margin:4px;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-actbar div a:first-child {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mlmsg {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mlmsg table {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mlmsg select, #ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 input, #ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 textarea {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mlmsg pre, #ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 code {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mlmsg * {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-mlmsg #ygrps-yiv-1293665652yiv7375108736logo {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-msg p a {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-msg p#ygrps-yiv-1293665652yiv7375108736attach-count span {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-reco #ygrps-yiv-1293665652yiv7375108736reco-head {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-reco {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-sponsor #ygrps-yiv-1293665652yiv7375108736ov li a {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-sponsor #ygrps-yiv-1293665652yiv7375108736ov li {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-sponsor #ygrps-yiv-1293665652yiv7375108736ov ul {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-text {
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1293665652 #ygrps-yiv-1293665652yiv7375108736 #ygrps-yiv-1293665652yiv7375108736ygrp-vital ul li:last-child {
Custom ABL
END.
Joshua Giese
CIO
Steven G.
Steven G.
Steven G.
<div id="ygrps-yiv-1389849331yiv4999388059ygrp-text">
  <div class="ygrps-yiv-1389849331yiv4999388059WordSection1"><div class="ygrps-yiv-1389849331yiv4999388059MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">Great thanks. I don’t think we were aware we should be using drop ship addresses instead of shiptos I don’t reacall seeing drop ship addresses anywhere except generated from pack slips.&nbsp; The BPM was pretty simple.</span></div><div class="ygrps-yiv-1389849331yiv4999388059MsoNormal"><span style="font-size:11.0pt;color:#1F497D;"> &nbsp;</span></div><div class="ygrps-yiv-1389849331yiv4999388059MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">Customer.GetByCustID</span></div><div class="ygrps-yiv-1389849331yiv4999388059MsoNormal"><span style="font-size:11.0pt;color:#1F497D;"> &nbsp;</span></div><div class="ygrps-yiv-1389849331yiv4999388059MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">Custom ABL</span></div><div class="ygrps-yiv-1389849331yiv4999388059MsoNormal"><span style="font-size:11.0pt;color:#1F497D;"> &nbsp;</span></div><div class="ygrps-yiv-1389849331yiv4999388059MsoNormal"><span
style=“font-size:11.0pt;color:#1F497D;”>IF custID = “BADCUSTOMER” THEN DO:
END.
Joshua Giese
CIO
Steven G.
Steven G.
</div>
<div class="ygrps-yiv-1389849331yiv4999388059yqt4094067277" id="ygrps-yiv-1389849331yiv4999388059yqt80836"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059 -- #ygrps-yiv-1389849331yiv4999388059ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mkp hr {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mkp #ygrps-yiv-1389849331yiv4999388059hd {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mkp #ygrps-yiv-1389849331yiv4999388059ads {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mkp .ygrps-yiv-1389849331yiv4999388059ad {
padding:0 0;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mkp .ygrps-yiv-1389849331yiv4999388059ad p {
margin:0;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mkp .ygrps-yiv-1389849331yiv4999388059ad a {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-sponsor #ygrps-yiv-1389849331yiv4999388059ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-sponsor #ygrps-yiv-1389849331yiv4999388059ygrp-lc #ygrps-yiv-1389849331yiv4999388059hd {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-sponsor #ygrps-yiv-1389849331yiv4999388059ygrp-lc .ygrps-yiv-1389849331yiv4999388059ad {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059actions {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059activity {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059activity span {
font-weight:700;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059activity span:first-child {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059activity span a {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059activity span span {
color:#ff7900;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059activity span .ygrps-yiv-1389849331yiv4999388059underline {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 .ygrps-yiv-1389849331yiv4999388059attach {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 .ygrps-yiv-1389849331yiv4999388059attach div a {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 .ygrps-yiv-1389849331yiv4999388059attach img {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 .ygrps-yiv-1389849331yiv4999388059attach label {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 .ygrps-yiv-1389849331yiv4999388059attach label a {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 .ygrps-yiv-1389849331yiv4999388059bold {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 .ygrps-yiv-1389849331yiv4999388059bold a {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 dd.ygrps-yiv-1389849331yiv4999388059last p a {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 dd.ygrps-yiv-1389849331yiv4999388059last p span {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 dd.ygrps-yiv-1389849331yiv4999388059last p span.ygrps-yiv-1389849331yiv4999388059yshortcuts {
margin-right:0;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div.ygrps-yiv-1389849331yiv4999388059attach-table div div a {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div.ygrps-yiv-1389849331yiv4999388059attach-table {
width:400px;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div.ygrps-yiv-1389849331yiv4999388059file-title a, #ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div.ygrps-yiv-1389849331yiv4999388059file-title a:active, #ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div.ygrps-yiv-1389849331yiv4999388059file-title a:hover, #ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div.ygrps-yiv-1389849331yiv4999388059file-title a:visited {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div.ygrps-yiv-1389849331yiv4999388059photo-title a, #ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div.ygrps-yiv-1389849331yiv4999388059photo-title a:active, #ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div.ygrps-yiv-1389849331yiv4999388059photo-title a:hover, #ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div.ygrps-yiv-1389849331yiv4999388059photo-title a:visited {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 div#ygrps-yiv-1389849331yiv4999388059ygrp-mlmsg #ygrps-yiv-1389849331yiv4999388059ygrp-msg p a span.ygrps-yiv-1389849331yiv4999388059yshortcuts {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 .ygrps-yiv-1389849331yiv4999388059green {
color:#628c2a;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 .ygrps-yiv-1389849331yiv4999388059MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 o {
font-size:0;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059photos div {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059photos div div {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059photos div label {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059reco-category {
font-size:77%;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059reco-desc {
font-size:77%;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 .ygrps-yiv-1389849331yiv4999388059replbq {
margin:4px;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-actbar div a:first-child {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mlmsg {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mlmsg table {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mlmsg select, #ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 input, #ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 textarea {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mlmsg pre, #ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 code {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mlmsg * {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-mlmsg #ygrps-yiv-1389849331yiv4999388059logo {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-msg p a {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-msg p#ygrps-yiv-1389849331yiv4999388059attach-count span {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-reco #ygrps-yiv-1389849331yiv4999388059reco-head {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-reco {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-sponsor #ygrps-yiv-1389849331yiv4999388059ov li a {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-sponsor #ygrps-yiv-1389849331yiv4999388059ov li {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-sponsor #ygrps-yiv-1389849331yiv4999388059ov ul {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-text {
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1389849331 #ygrps-yiv-1389849331yiv4999388059 #ygrps-yiv-1389849331yiv4999388059ygrp-vital ul li:last-child {
Ah yes yes that’s more or less how we process our OTS shipments. In a lot of cases we will only have a hand full of ship tos per customer and we save them for later use. It’s just this one customer that is really bad and seems to bird shot their product all over creation. Thank you for the input!
Joshua Giese
CIO
920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
Wisconsin Converting, Inc.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Wednesday, October 9, 2013 1:32 PM
Subject: Re: Re: [Vantage] Crazy amount of Ship Tos
We don't have version 9, but from what I understand is if you use a dropship address, then the address is assigned to the order, and not the customer.  Basically, it's a one time use shipping address.
Steven G.
On Wednesday, October 9, 2013 2:00 PM, Joshua Giese <jgiese@...> wrote:
Great thanks. I don’t think we were aware we should be using drop ship addresses instead of shiptos I don’t reacall seeing drop ship addresses anywhere except generated from pack slips.  The BPM was pretty simple.
Custom ABL
                Assign withShipTo = FALSE.
END.
Again that only helped in customer entry, but not order entry at all.
Joshua Giese
CIO
Sent: Wednesday, October 9, 2013 12:51 PM
We are on 8.03.408a, but we had this problem on customer maintenance who had a large number of shipto records.  The solution was to write a customization that removed the tree view on the left side of the form.
There is no way that I know of to delete a shipto record once it has been used.  Since you are on version 9, using a dropship address instead of a shipto would prevent this going forward, it just wouldn't help with the current customer record you are having a problem with.
I would be interested in seeing the pre-process BPM you used.
Steven G.
On Wednesday, October 9, 2013 10:56 AM, "jgiese@..." <jgiese@...> wrote:
For Customer Entry adding a pre-process on GetByCustID that changed withShipTo to false when it is X customer worked. However did not help my situation in Order Entry. Evaluating this customer's record during order entry takes about 12 seconds a normal customer is 2.5 seconds.  Not sure what about this customer is making order entry so slow.
Steven G.
On Wednesday, October 9, 2013 9:32 AM, "jgiese@..." <jgiese@...> wrote:
We have a customer in the system with 3600+ ship to addresses saved. It has made using this customer in the system very slow.  Is there any way we can purge those from the system.  We can't delete them manually because they are attached to orders. Not sure what to do. Considering creating a new ID for this customer and just not saving the ship tos for them. Thoughts?
