OT-Making Crystal reports available for users to run
Here are a couple of things I have had to do to get Crystal to run on
clients:
1. Use a server DSN instead of a file DSN on the client, setup as
administrator using ODBC Administrator. Need to do this if you are using
subreports.
2. Change the users default printer to the one used when creating the
report, or you get this error "cannot open SQL server" during the setup.
3. Run the "left outer join fix" for each user, or you get this error
"error in database dll"
4. Make sure the user has a drive mapped to the data base or you get this
error "setup routines for the Merant 3.60 32-bit Progress ... could not
be loaded due to system error code 126".
5. The merant driver is installed with the progress client.
6. Merant error "The setup routines for the Merant 3.60 32-bit Progress
SQL92 v9.1D ODBC driver could not be accessed". Manually edit this registry
key:
HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI\MERANT 3.60 32-BIT Progress
SQL92 v9.1D
The “SETUP” value should be “U:\progress\bin\PGPRO915S.DLL”
The “S” was missing after the PGPRO915. This “S” is for “system” DSN.
Mark Dupuis
Ranor, Inc.
Bella Drive
Westminster, MA 01473
Tel: (978) 874-0591 X221
Fax: (978) 874-2748
mailto:dupuism@...
IMPORTANT NOTICE:
This email, together with any attachments, is confidential. It may be
legally privileged, and is for the intended recipient only. Access,
disclosure, copying, or distribution of it by anyone else is prohibited and
may be a criminal offense. Please delete if obtained in error; and email a
notification to the sender.
Sent: Friday, October 22, 2004 8:48 AM
Subject: [Vantage] Re: OT-Making Crystal reports available for users to
run
I've done all of that. On some user's machines it works great!
Some get an error when I run the setup.exe and won't work. On the
Citrix servers, they won't run at all through Vantage.
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
What are the options for users to run 'prewritten Crystal reports'.
As I understand it, you can create a shortcut icon on the users
Vantage favorites for the reports that they run. I have also heard
of a 'Crystal server'. I have hundreds of Report Builder reports
that I can just add to the Vantage menu. Is there any way to make a
Crystal report menu available for the users in Vantage?
Thanks!
Ann
AMFAB
In Vantage 6.1 with Cr 8.5 I use the distribution wizard and links from favorites. But with 8.0, CR report Distribution will be as "gone" as RB so no joy there.
I'm counting on lots of "answers" and affordable solution suggestions at Perspectives. I guess affordable for us would be $5,000 or less - about $200 per user max. Would love for it to be some sort of web interface that could be fired up via the Vantage captive browser (not IE).
-Todd C.
Sent: Thursday, October 21, 2004 2:29 PM
Subject: [Vantage] OT-Making Crystal reports available for users to run
Thanks!
Ann
AMFAB
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=1299ochv2/M=294855.5468653.6549235.3001176/D=groups/S=1705007183:HM/EXP=1098473403/A=2376776/R=0/SIG=11ldm1jvc/*http://promotions.yahoo.com/ydomains2004/index.html> click here
<http://us.adserver.yahoo.com/l?M=294855.5468653.6549235.3001176/D=groups/S=:HM/A=2376776/rand=161104913>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Todd,
You got that to work for you? You'll have to tell me your secrets
cause I am playing heck trying to get my reports to run within
Vantage on User's machines. Some will work, others will not. It's
crazy!
Shari
No much to it....
1. Downloaded the Report-Distribution add-in from Crystal Web site and installed on the development PC (mine)
2. Any report to be distributed is run thru the wizard (a couple check boxes reversed - distribute .dll files not the data)
3. Install distributed report (via setup.exe it created) on user machine
4. Add a shortcut to Favorites bar pointing to the report's .exe file on the user's PC
Downside is re-distributing reports to each userevery time there is a change.
-Todd C.
Sent: Thursday, October 21, 2004 2:51 PM
Subject: [Vantage] Re: OT-Making Crystal reports available for users to run
Todd,
crazy!
Shari
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129s7hnd1/M=295196.4901138.6071305.3001176/D=groups/S=1705007183:HM/EXP=1098474674/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=:HM/A=2128215/rand=672516619>
_____
Yahoo! Groups Links
Setup? Hmmmm...sounds like posible privilage problem. Or, by any chance are the ones that fail a different OS than the development machine? I've never had problems distributing from my Win2K PC to the Win98 PCs but if XP is involved all bets are off.
Citrix is totally alien to me - but if relying on the local DBF files for data then the location used on the development PC may be different than where it has to go look on the Citrix servers. In which case some kind of very specific drive mapping scheme might get around it.
-Todd C.
Sent: Friday, October 22, 2004 7:48 AM
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129a1lf61/M=294855.5468653.6549235.3001176/D=groups/S=1705007183:HM/EXP=1098535673/A=2376776/R=0/SIG=11ldm1jvc/*http://promotions.yahoo.com/ydomains2004/index.html> click here
<http://us.adserver.yahoo.com/l?M=294855.5468653.6549235.3001176/D=groups/S=:HM/A=2376776/rand=315023494>
_____
Yahoo! Groups Links
