Crystal Enterprise, Crystal Web Reporting
Erik,
I use Crystal 8.0 on my development machine (Win98). On the WCS machine I use NT 4.0 SP6a for the Operating System, Crystal Enterprise (version?? -- its the one that comes with Crystal 8.5) for the Web Component Server, along with IIS and Crystal 8.5 Professional. I applied the outjoin.reg fix on that machine, as well as my Crystal 8.0 workstation (Win98). Any report I design in 8.0 is instantly runable on the NT workstation just by copying the file to the appropriate directory. I've never had a file not run correctly with ODBC. For both of the above machines I am using the Merant 3.5 drivers from Datadirect. We utilize Procontrol to start the oibrkr32.exe program for the ODBC broker. We're on Vantage 5.1, Progress 9.1C.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Monday, November 18, 2002 11:08 AM
Subject: RE: [Vantage]Crystal Enterprise, Crystal Web Reporting
Troy,
What version of Crystal Reports, Crystal Enterprise and ODBC drivers are you
using on your WCS? And is the IIS running locally or also on the Vantage
server?
Erik Weiffenbach
Sent: maandag 18 november 2002 16:07
Subject: Re: [Vantage]Crystal Enterprise, Crystal Web Reporting
Erik,
I have reports with over 10 tables in them -- with the links happening
at various places in various tables.
Have you applied the outjoin.reg fix to the WCS machine? It has to be
applied on the machine running the report.
Troy Funte
Liberty Electronics
Sent: Monday, November 18, 2002 9:51 AM
Troy,
I'm already using the Crystal outjoin.reg fix.
The problem is that in Crystal I can link as much tables I want without
any
problems but starting the same report through the WCS will generate those
errors.
Are you or somebody else able to preview reports, based on 3 ODBC linked
tables?
Erik Weiffenbach
Macroscoop BV
Sent: donderdag 14 november 2002 14:49
Erik,
You probably need to apply the outjoin.reg fix, which adds the correct
procedure for outerjoins in the registry. There used to be both versions
(14 and 15) depending on the .dll files you have. I have another version
for Merant 3.5 that I use. Check here
http://groups.yahoo.com/group/vantage/files/Vantage%20Admin/Crystal.reg to
see if these work from Ted Kitch. (Merant v3.6 Registry Fix for Crystal
Reports ).
Troy Funte
Sent: Thursday, November 14, 2002 8:37 AM
Thank's Adam and Troy for the good advice!!! now it works fine till a
certain point and that is;
1) With the merant 3.6 odbc driver
If a report uses 3 linked tables I receive the message "Error detected
by
database DLL. [On Page Server: SERVERNAME.pageserver]"
Note: 2 tables is no problem.
2) Using the Merant Progress SQL92 v9.1D drivers it's the same problem,
the
only difference is that this happens with a 2 linked table report.
Searching in the knowledge base of crystal I could find this article,
but
does not solve my problem.
http://support.crystaldecisions.com/library/kbase/articles/c2011877.asp
Hope you can help me again with this one.
Erik Weiffenbach
Macroscoop BV
Sent: woensdag 13 november 2002 18:57
Erik,
You need to run all of the Crystal Enterprise services as
Administrator...not Local System account. I believe that is what fixed
it for me.
Good luck,
Adam Ellis
Senior Consultant - SaberLogic, LLC
Ph: (330) 335-6442
Mobile: (330) 697-3883
Erik Weiffenbach wrote:
>We are using Crystal Reports v8.5 and Crystal Enterprise v8.0 and we
would
>like to use Crystal Enterprise for distributing our Crystal reports.
>The problem I have is that I am not able to preview any report that
uses
>ODBC (Merant 3.6 or Merant Progress SQL92 v9.1D). When trying to open
such
a
>report a menu appears in which a User Id and a password is required.
I've
no
>idea which id or password I have to use.
>All other reports based on dbf preview fine.
>Does anyone know a solution for this?
>Erik Weiffenbach
>Macroscoop BV
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
have
>(1) To access the Files Section of our Yahoo!Group for Report Builder
and
>(2) To search through old msg's goto:
>(3) To view links to Vendors that provide Vantage services goto:
>Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
have
and
and
have
Yahoo! Groups Sponsor
ADVERTISEMENT
We are using Crystal Enterprise for distributing our Crystal reports. If a user runs more than 4 reports he suddenly gets the error that "(5199)no sql servers are available. Try again later (8839)."
I've looked the errors up in both the Epicor and Crystal knowledgebases, but they really don't give me an answer that applies to our situation. I keep having to restart the page server, cache server, and web server.
Has anyone else had this problem?
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
Burton, Michigan
In the CR 8.5 version of Crystal Web, which they call Crystal Enterprise (as opposed to the former Crystal Web Component) there is a 5 license limit. This is CONCURRENT use, but we've run into occasional situations where the user will be asked for a login/password for a report when this occurs.
Perhaps your situation is a license issue, although I haven't seen the specific error you are speaking of.
We do occasionally have to reboot the NT workstation that is home for Crystal Enterprise due to the above issue.
Troy Funte
Liberty Electronics
Sent: Wednesday, April 24, 2002 11:21 AM
Subject: [Vantage] Crystal Web Reporting
Wendy Bowen
Burton, Michigan
We are using Crystal Reports v8.5 and Crystal Enterprise v8.0 and we would
The problem I have is that I am not able to preview any report that uses
ODBC (Merant 3.6 or Merant Progress SQL92 v9.1D). When trying to open such a
report a menu appears in which a User Id and a password is required. I've no
Erik Weiffenbach
Macroscoop BV
Erik,
it for me.
Good luck,
Adam Ellis
Ph: (330) 335-6442
>Erik Weiffenbach
>Macroscoop BV
Erik,
Adam's solution is the best option. I think you need to go to the Services and select the Crystal PageServer. Enter the Administrator username and password in that service.
A workaround solution is to run the service on your task bar. If you have to resort to that solution, I can look through the archives for the program path you need. If you still have Crystal support, they can help you with that as well. It's a known issue (called looping login) with Progress databases.
Troy Funte
Liberty Electronics
Sent: Wednesday, November 13, 2002 12:52 PM
Subject: [Vantage]Crystal Enterprise, Crystal Web Reporting
Erik Weiffenbach
Macroscoop BV
If a report uses 3 linked tables I receive the message "Error detected by
2) Using the Merant Progress SQL92 v9.1D drivers it's the same problem, the
Searching in the knowledge base of crystal I could find this article, but
Erik Weiffenbach
Macroscoop BV
Erik,
it for me.
Good luck,
Adam Ellis
Ph: (330) 335-6442
a
no
>Erik Weiffenbach
>Macroscoop BV
Erik,
You probably need to apply the outjoin.reg fix, which adds the correct procedure for outerjoins in the registry. There used to be both versions (14 and 15) depending on the .dll files you have. I have another version for Merant 3.5 that I use. Check here http://groups.yahoo.com/group/vantage/files/Vantage%20Admin/Crystal.reg to see if these work from Ted Kitch. (Merant v3.6 Registry Fix for Crystal Reports ).
Troy Funte
Erik Weiffenbach
Macroscoop BV
Erik,
it for me.
Good luck,
Adam Ellis
Ph: (330) 335-6442
a
no
>Erik Weiffenbach
>Macroscoop BV
Troy,
The problem is that in Crystal I can link as much tables I want without any
errors.
tables?
Erik Weiffenbach
Macroscoop BV
Erik,
Reports ).
Troy Funte
the
Erik Weiffenbach
Macroscoop BV
Erik,
it for me.
Good luck,
Adam Ellis
Ph: (330) 335-6442
would
such
a
no
>Erik Weiffenbach
>Macroscoop BV
have
have
Erik,
I have reports with over 10 tables in them -- with the links happening at various places in various tables.
Have you applied the outjoin.reg fix to the WCS machine? It has to be applied on the machine running the report.
Troy Funte
Liberty Electronics
Troy,
errors.
tables?
Erik Weiffenbach
Macroscoop BV
Erik,
Reports ).
Troy Funte
the
Erik Weiffenbach
Macroscoop BV
Erik,
it for me.
Good luck,
Adam Ellis
Ph: (330) 335-6442
would
such
a
no
>Erik Weiffenbach
>Macroscoop BV
have
have
ADVERTISEMENT
Troy,
server?
Erik Weiffenbach
Erik,
Troy Funte
Liberty Electronics
Troy,
any
errors.
tables?
Erik Weiffenbach
Macroscoop BV
Erik,
Reports ).
Troy Funte
by
the
but
Erik Weiffenbach
Macroscoop BV
Erik,
it for me.
Good luck,
Adam Ellis
Ph: (330) 335-6442
would
uses
such
a
I've
no
>Erik Weiffenbach
>Macroscoop BV
have
and
have
and
and
have
ADVERTISEMENT
